wierd total electrical failure
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by flutediva, Oct 28, 2007.
  1. flutediva
    flutediva New Member
    Yesterday, I went to the beach and when I tried to start my 2005 Prius, nothing happened. The doors were unlocked, I couldn't lock them, key wouldn't release from the ignition, couldn't roll up my windows. I had to have it towed to a secure parking lot until the dealership opens tomorrow. Has anybody had anything like this happen? Any idea whats wrong?
  2. Bob64
    1,540
    92
    Virginia
    dead 12v aux battery sounds likely. Did you leave a door open or a light on?
  3. flutediva
    No, I was inside the car for about an hour, but the doors were closed, lights were off. I turned it on once during that time to roll down the windows then I turned it off again.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Are you still on the original 12V battery? It sounds like it's time for a new one.
    Tom
  5. IndyDoug
    IndyDoug New Member
    120
    Indianapolis, IN
    Possibly a UFO was nearby affecting the electrical system in your Prius.
  6. richard schumacher
    7,663
    1,040
    United States
    <div class='quotetop'>QUOTE(flutediva @ Oct 28 2007, 01:06 PM) [snapback]531615[/snapback]</div>
    Hmm, I'd bet a quarter that you didn't actually turn it OFF, but instead to ACC and ran down the 12V battery.
  7. flutediva
    I hope everyone is right and its just the battery, the small one....Thanks.
  8. PriusLove
    PriusLove New Member
    31
    <div class='quotetop'>QUOTE(flutediva @ Oct 28 2007, 07:53 PM) [snapback]531734[/snapback]</div>
    I call it the Prius Freakout. I've seen it three times on our 04. Once we went the route of having the car towed (Toyota replaced a processor unit then).
    It happened again when we ran completely out of gas, and again when I left the key in my purse on the floorboard of the car, and tried to lock it with the outside door button. It gave me a warning beep, but I ignored it, and the Smart Key system went screwy.
    The first thing to keep in mind, when you can't get your key out of the lock is that your foot has to be on the brake in order for the keypod to be released. After that, take the manual key out and use it to close and lock/unlock the doors. That resets the SKS somehow. At least, it has worked for us the last two time.
  9. richard schumacher
    7,663
    1,040
    United States
    If this 12V battery is drained once it's usually still useable, but if it gets drained twice it's never right again. So be careful.
  10. wyounger
    wyounger New Member
    69
    Atlanta, GA USA
    Do you drive with your lights on? Did you open the driver's door after you turned it off and before you sat for an hour?
    The auto-off feature on Toyota headlights only takes effect once you turn off the car AND open the driver's door. Otherwise you can sit in the driver's seat and happily drain your battery.
