Windshield wiper replacement on the 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tlo, Mar 18, 2010.
  1. tlo
    tlo
    Expand Collapse
    New Member
    I'm having trouble figuring out the correct windshield wipers to purchase online. Can someone provide guidance on sizing. I think that it's 26inch, 18inch and 16inch for the rear window but I'm not sure if I can just got any wiper or if I need particular fittings.
    Thanks.
    Tony
  2. Paradox
    Paradox
    Expand Collapse
    Prius Enthusiast / Moderator
    29,021
    8,517
    201
    2014 Prius v wagon
  3. pjksr02
    pjksr02
    Expand Collapse
    Member
    258
    32
    Connecticut
  4. Prius_in_Paradise
    Prius_in_Paradise
    Expand Collapse
    Junior Member
    Ponte Vedra Beach, FL
    I just purchased and installed Rain-X Lattitude:
    26" Front Driver;
    19" Passenger.
    Note: Specifications for passenger call for 18";
    19" Rain-X Lattitude work well on Prius 10 V passenger side.
    Question:
    Is there a Rain-X or Bosch that works on the rear window of a 2010 Prius?
    Thank you.
  5. xpcman
    xpcman
    Expand Collapse
    Senior Member
    1,284
    262
    California - SF Bay area
    I just bought a new rear blade for my 2008. It's similar to the 2010 in that the mounting post is offset so that the arm can be parallel to the blade. Only the Toyota blade will fit and it costs $15.
  6. lenjack
    lenjack
    Expand Collapse
    Active Member
    666
    26
    Pennsylvania USA
    26-18 also works vey well.
  7. suhlhorn
    suhlhorn
    Expand Collapse
    New Member
    FL
    Does anyone know where I an order the Toyota wiper inserts online (2010)? My local dealer is charging way to much for the refills.
    Thanks-
    -stephen
  8. oxnardprof
    oxnardprof
    Expand Collapse
    Member
    242
    Oxnard, CA
    I need new blades, and the dealer quoted $68 to change them. I guess I can buy them and do it myself. I think he said the rear wiper is the whole assembly and the front is the blades. 2004 model year.
  9. hsiaolc
    hsiaolc
    Expand Collapse
    New Member
    617
    44
    UK
    Just get the rubber. YOu don't need the whole wiper arm.
    I changed mine at 5000k for free so I don't know how much the rubbers are but I think they are about £15-20?
  10. hsiaolc
    hsiaolc
    Expand Collapse
    New Member
    617
    44
    UK
    How much are they charging for the rubber refills?
  11. suhlhorn
    suhlhorn
    Expand Collapse
    New Member
    FL
    Just picked them up at the parts department... $20 for all three inserts.
    (I thought they were going to charge $20 each!)
    I guess I'll just pick up a set when I get my oil done every 10K... ends up being about the right time... ~6 months. Unfortunately I run about 20K/year!
    -stephen
  12. hsiaolc
    hsiaolc
    Expand Collapse
    New Member
    617
    44
    UK
    3 for $20 is very cheap. Not sure what the fuss is about. For that price one can change all 3 every 6 months.
  13. duffasaurus
    duffasaurus
    Expand Collapse
    Senior Member
    177
    35
    Charlotte, NC
    Anyone have the toyota part #s for the rubber refills??
  14. Dark_matter_doesn't
    Dark_matter_doesn't
    Expand Collapse
    Prius Tinkerer
    677
    141
    Seattle, WA
    Part #'s for inserts:
    Rear: 85214-0E050
    Driver: 85214-30390
    Passenger: 85214-68020
    FinToy and Hokeysmoke like this.
  15. toyolover
    toyolover
    Expand Collapse
    Member
    396
    48
    toronto, canada
    Recently bought from Costco their "exclusive" Michelin curve blades 26" and 18". They were on sale for USD8 per piece. The same 26" is selling for almost 3 times more in other retail stores. When I compared the difference between the factory original and the Costco blades, I found that the Toyota original blade has a special design housing which deflects the wind. Would it make any difference in performance? I don't know but I'd suppose so.
    A call to Toyota parts department turns out that the refill for 26" and 18" are also about USD8. If I had known about it, I would not have purchased the Costco blades.
  16. jdcollins5
    jdcollins5
    Expand Collapse
    Senior Member
    4,903
    1,063
    Wilmington, NC
    Minor detail but the Driver and Passenger refill numbers above are backwards. I just bought a set of three from my Toyota dealer for $22.57. This is the rubber refill minus the metal strip that creates the proper curvature for the windshield. The parts guy told me that you remove the metal strip from the old rubber piece and place them in the grooves on the new rubber refills. Easy to swap out.
    The parts guy also told me that Toyota is using these new style wiper blades on all of their newer model vehicles, not just the Prius.
    I tried using standard Trico refills. They fit but the ends would not contact the windshield due to the curvature. I thought about using the curved metal strips with the Trico refills in the future but the connecting ends do not match. For $22 I will continue to use the Toyota refills until I need a new complete blade assembly.
    xs650 likes this.
  17. Mendel Leisk
    Mendel Leisk
    Expand Collapse
    Lapsed Cargo Cultist
    3,255
    78
    Greater Vancouver, BC, Canada
    If you're replacing wipers because they're juddering or skipping somehow, something to try first:
    Get a spray can of automotive glass cleaner, the foaming stuff with cleaners and solvents. Thoroughly go over the windshield following instructions, typically to spray on and thoroughly wipe off with a cloth. Then moisten (the same) cloth with the cleaner, pinch the wiper blade at one end, and wipe along the full length a few times. Maybe repeat.
  18. jdcollins5
    jdcollins5
    Expand Collapse
    Senior Member
    4,903
    1,063
    Wilmington, NC
    For anyone with the tech manuals for the 2010 Prius, there is a section that demonstrates how to remove each one of the wiper blades, remove the rubber pieces, remove the curved metal pieces, install the metal pieces in the new rubber refills and re-install the wiper blade. It even shows how to remove the wiper blade from the rear window and replace the wiper refill.
  19. LulzChicken
    LulzChicken
    Expand Collapse
    Prius Enthusiast
    791
    133
    Alabama
    Does anyone have those tech manuals?
  20. jdcollins5
    jdcollins5
    Expand Collapse
    Senior Member
    4,903
    1,063
    Wilmington, NC
    Several people were able to purchase a low cost CD on Ebay before they were eventually pulled.
