Wish List for the PIP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ukr2, Mar 20, 2012.
  1. jimm58
    jimm58 New Member
    Berkeley, CA
    Re: Hello Toyota...Feature requests...
  2. drash
    drash Senior Member
    2,457
    1,235
    Upstate NY
    Now that I've had mine for 10 days, I'd like to amend my wish list.
    The Prius v polycarbonate moonroof seems a better fit that the Prius Four solar powered roof because of weight. And it would seem a little more hi-tech if they did imprint clear solar cells within it.
    Have the seat heaters come on, when selected on, using line (household) current, for 10 minutes at a time while charging. If a finish time is selected, the last 10 minutes.
    The battery seems the perfect fit for me. Not sure I want to trade extra range for stale gas.
  3. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    I was very surprised to have found that my 1999 Solara's Heat and AC controls were recycled into the PHEV Advanced model.
    Especially when there is a novel one-knob system in the Prius V that seems MADE for an Advanced PHEV. (below)
  4. blakemster
    blakemster Member
    130
    23
    huntington beach, ca
    how about a locking door for the charge port??? It will be a perfect spot for gum from some prius-hater ...
  5. jimm58
    jimm58 New Member
    Berkeley, CA
    An option to keep bluetooth connected for a few minutes on those rare occasions when I do need to stop for gas, or just generally during brief shutdowns like when stopping the hybrid system and then turning on accessory mode.
  6. csolsen
    csolsen New Member
    CA
    1) Spare tire
    2) removed beeping at low speeds (reverse indicator)
    3) docking iphone starts playing music (turn this feature off)
    4) alarm on charging cable (if you don't have key fob)
    5) a little more EV range... 15-20miles
    Chris
    (currently running at 45-50% EV)
  7. retired4999
    2,652
    625
    Eau Claire, Wi.
    #2 You can have your dealer change to one beep.
  8. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
  9. longterm
    longterm Member
    152
    Nashville, TN
    Yes, and it's a bit annoying; even when I'm driving at a leisurely pace, the slightest touch can cause the ICE to come on.
  10. longterm
    longterm Member
    152
    Nashville, TN
    Although I'm sure this thread is an exercise in futility, I'll post my wish list, after having the car for 2 weeks:
    1. User-adjustable threshhold for when the ICE kicks in; even when going up the tiniest hill sometimes, the ICE will kick in, and then I have to wait for the warmup cycle before it'll turn off again.
    2. A hard button for GPS; I had it in my Gen II Prius and I miss it. It ought to be on the steering wheel.
    3. Charge port on the DRIVER'S SIDE like it was in the prototype; In two weeks, I've probably sat in the car at least 4 times, only to have to exit the car to unplug the charger. If the charge port were near the driver's door, I'd see it as I'm entering the car.
    4. More EV range.
    5. Put the CONSUMPTION readout where I can see it all the time; I don't see it at all on any of the odometer settings unless I switch to one display setting, and that's mildly annoying.
    6 (perhaps it does this?) Headlight auto-off like the Gen II Prius.
    For those of you waiting on your blue Prius PIP and wondering if you'll like the color, I have to say: I had a red Prius, which I loved, and didn't really know if I'd like the blue color--but I really love it more and more each time I walk up to my car.
  11. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
  12. ronlprius2
    ronlprius2 Junior Member
    56
    San Francisco
    At least they reinstated the wireless remote on 3 doors! What were they thinking when they dropped that from anything but the top line model?
  13. ronlprius2
    56
    San Francisco
    Wish list:
    Homelink in all models
    Turn signals in the mirrors (who thought of putting the front turn signals as close to the bottom of the car as possible? That was a major visibility error).
  14. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    There are four packages for Prius. For 2012, every one but the base TWO has a three door smart entry. FYI.
  15. drash
    drash Senior Member
    2,457
    1,235
    Upstate NY
    I haven't had this problem and I've gone up some rather steep hills. Did you try putting the PWR button on while in EV? Allows the EV mode to use more power.
    Yep does this, just delayed off like my wife's Venza. Don't like running the 12V down like that though.
    Ditto. It is distinctive. Pretty much spot it easily in the sea of silver and gray in our parking lot.
  16. o2cool
    o2cool o2cool
    48
    Palo Alto, CA
    Seat heater is a great idea. It could be even better if it was based on the temp of the car. So, on a cold night in the garage, you get more morning warm seat. On a warm night in the garage, why bother?
    I also agree with you on the battery. When battery performance/price ratio improves (over the upcoming years), then it might make sense for more battery. Right now, I think that Toyota engineered the battery size just about perfectly. This does not mean that it can be perfect for all drivers or even all situations for an individual driver.
  17. longterm
    longterm Member
    152
    Nashville, TN
    I haven't but will give that a try; there are lots of hills in Nashville so it's a common occurrence. I assumed that the POWER button would mean that I'd not be using EV as often...
