Would you put coating on the audio/climate remote control
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by fobber, Jul 21, 2014.
  1. fobber
    fobber Junior Member
    32
    So Cal
    As the topic line states, would you put some type of coating on the audio/climate remote control to prevent the rubber from wearing out? I can invision if I'm using it frequently, over time, the rubber part is going to wear out.
  2. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    Are you posting in the right forum? The Gen III Prius hatchback doesn't have any rubber coating on any of the controls. :confused:
    SCH-I535
  3. fobber
    32
    So Cal
    I was referring to the controlable part of the steering wheel. Just wondering if there was a way to prevent it from wearing out; aside from not using it.
  4. xliderider
    7,849
    3,103
    Honolulu, HI
    They sell Plastidip in clear.
    SCH-I535
  5. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I also wonder how durable those are, they're the first steering wheel controls I've had.
  6. danvee
    danvee Blizzard Brigadier
    326
    53
    38
    New Jersey
    Four years and 37k with no discernable wear on mine.
  7. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Good to know, Dan.
  8. bisco
    48,996
    i'm more concerned with the buttons underneath, i use the volume control uncontrollably.
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    I've wondered as evidently many people have- about the long term durability of that rubber.
    But it's been 4 model years, and I have yet to see a post where someone cited a failure of those pieces.
    Eventually...you've got to think it would wear. But initially it seems surprisingly durable.
    I'd be afraid to spray any chemical or additive or covering on it, thinking a reaction might actually hasten deterioration.
    I think the best approach is being as careful as possible in using the buttons, and keeping the rubber as clean as possible.
    While I avoid chemicals, I have treated the dash and those buttons using Aero Space 404...which is suppose to be an excellent rubber protector.
    About 2 times a year... and carefully.
    So far-Over 1 year-So good.
    Assuming the possibility of a future failure...does anyone know if Toyota sells those parts individually?
  10. fobber
    32
    So Cal
    Mine too. I figured probably after 6 years of usage, cracks may appear.
  11. qdllc
    qdllc Senior Member
    1,358
    396
    I'd expect someone would have cited a problem by now.
    I also expect they are somewhat easy to replace (probably are switch units that could be swapped out).
    Applying anything to preserve something is hard to manage. Armor All was a big deal, but I heard it did more to ruin a surface than preserve it (although it did make it look good). Odds are having DIRTY HANDS does more to ruin control surfaces than anything else.
    Let me tell you what will most likely fail in these switches. I believe they are using what I call a "bubble" switch. It's like a soft metal dome that gives under pressure to complete the circuit and then pops back into shape when released. I've hardly ever seen these fail, but repeated use does invoke the chance of eventual failure. I'd think you would see the contacts fail before the coating failed.
    #11 qdllc, Jul 24, 2014
    fobber likes this.
  12. retired4999
    2,652
    625
    Eau Claire, Wi.
    Get a hold of yourself! Hummmmmmmmmmmmmm! maybe I worded that badly!:)
  13. bisco
    48,996
    that too.:oops:
  14. retired4999
    2,652
    625
    Eau Claire, Wi.
    No problems here after 28 months. We will see I guess!
  15. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    no problems here after 5 years of use and 77k miles, I work in construction and have very dirty hands when I'm on my way home.
