Couple Questions
Discussion in 'Gen 3 Prius Main Forum' started by pitterchi, Nov 24, 2009.
  1. pitterchi
    pitterchi Junior Member
    Northern VA
    Hi everyone,
    I just had a couple questions if anyone has any input it would be much appreciated.
    1. The first question is about the "mileage remaining on the tank" trip display (when you scroll through the trip button on the steering wheel). How accurate is this? Is it the mileage remaining on the tank or mileage remaining until I'm about 2 gallons? I ran it down today to about 18 miles then filled up my tank 9.5 gallons. Seems like I can drive another 80 miles or so until I'm really out of gas.
    2. Have you noticed when you drive on power mode the ECO light doesn't light up in the HSI display at all? It only lights up on EV, ECO or normal mode. Does this ECO light really mean anything at all or is it aesthetic? I'm one of those drivers that get better fuel economy in PWR mode.
    Thanks! :rockon:
  2. G3priusV
    G3priusV Member
    131
    17
    UT
    I'm not sure about the first one and would like to know too! But on the second one I used to drive on ECO mode before but now I'm driving on PWR always. The difference is hard to believe but really, a better MPG! I'm not sure if it's because easier to accelerate and then coast a lot or is it just more fun to drive with PWR mode on. :)
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    DTE is very conservative. It appears anywhere from 1.5 to almost 2 gallons remains in the tank once 0 is reached. Toyota just wants to make sure you don't run this puppy out of gas (including tilting). Consider it your reserve.
    By its nature, PWR mode circumvents ECO mode.
  4. Tideland Prius
    16,560
    1. My guess is it's the distance to the low fuel light. (i.e. 2 gal reserve or thereabouts.)
    2. It's just to hint to you that you won't get the best mpg (typically) cause we normally would use PWR Mode to merge on the highway or just have fun on the country roads, mileage be damned. But yeah there are a few ppl here on PC that get better mpg and if PWR Mode fits your driving style, then you're gonna be better at it than the rest of us.
