Inverter Coolant Leak: T-SB-0352-09
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Patrick Wong, Jan 13, 2010.
  1. Patrick Wong
    18,210
    6,515
    I noticed a TSB for 2010 models which the group might be interested in. The inverter coolant drain plug might not be properly torqued, which would lead to a coolant leak.
    If you notice that the inverter reservoir coolant level is dropping, I suggest you look for a fluid leak at the drain plug and verify tightening torque, which should be 35 ft.-lb. Replenish coolant as needed with Toyota Super Long Life Coolant.
    Note that the 2010 repair manual shows the drain plug tightening torque should be 29 ft.-lb (which is the same as Classic and 2G). I assume that the TSB was issued because 29 ft.-lb was found to be insufficient given field experience.
    12 people like this.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Thanks! I will have to check that plug when I do the oil change in the future. Until then, I will just keep an eye on the level.
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Have they changed the design of the plug between gen 2 and gen 3?
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    This TSB is specific to the GenIII. If the GenII had problems, I guess not.
  5. Patrick Wong
    18,210
    6,515
    Looking at the repair manual drawings, the plug seems to be the normal circular plug with a 10 mm hex hole.
    However the transaxle case is certainly different. Maybe the aluminum wall thickness is less than 2G. I'd recommend caution when tightening these plugs, use a torque wrench for sure.
    BTW, the 3G transaxle ATF fluid drain and fill plugs also require a 10 mm hex key. The 2G transaxle case had some plugs using the circular design while other plugs had a hex head requiring a 24 mm socket.
  6. risingsun
    risingsun seeker of the way
    186
    30
    Prescott, AZ
    I am curious how you came across this TSB. Is there a library of them for the 2010 model somewhere that you found it posted? Would be nice to have an on-line location where they are placed (by Toyota, or whoever) when developed that we, as DIY'ers, can check periodically.
  7. Patrick Wong
    18,210
    6,515
    techinfo.toyota.com
  8. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Part of the tsb refers to transaxle coolant drain plug. Is the inverter coolant not a separate drain?
  9. Patrick Wong
    18,210
    6,515
    The inverter and transaxle are both included in the same coolant loop. The coolant fill is performed at the reservoir adjacent to the inverter, while the drain is located at the bottom of the transaxle.
    The engine coolant loop is separate and unrelated to the inverter/transaxle coolant loop.
