post pics of your prius w/ rims!!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mrplease, Sep 8, 2008.
  1. snapster
    snapster New Member
    Nice man. Have any pictures? Will you need any spacers at all? I don't even know what the necessary offsets are to get a flush look on the fender.
  2. Fred_H
    Fred_H Misoversimplifier
    559
    485
    28
    Germany
    Dotz Imola 6.5 X 16, 40 mm offset, Pirelli Sottozero 195/55 R16 87 H
    These are snow tires, which I leave on these rims. I use these from October to March. Summer rims/tires still original...
  3. Vladi_07
    Vladi_07 New Member
    Nor*Cal
    SO nice!! the second one :eek: never thought a Prius can look so good! lol
    looks perfect!!
    ugh, i cant properly quote you :mad:
  4. Neena2007
    Neena2007 New Member
    SJ, CA
    my share with the TC wheels...
    ...also 35% tint all around.
    ParadisePrius likes this.
  5. ufourya
    ufourya We the People
    1,258
    336
    42
    Most all my mods have been relatively inexpensive. These MB Drifter rims at Discount Tires ran under $80 each. They are 16x7. Tires, also under $80, are205/55R. This makes the overall rolling diameter slightly larger than OEM, resulting in a small difference in mileage and mpg recorded by the car. My gps shows it at about 1% (It shows 101 miles traveled for each 100 the car records.
    I've taken a mleage hit estimated at around 2-3 mpg. The difference, in handling and stability at speed - even with significant quartering headwinds, is worth it to me. Your driving conditions and preferences might differ.
  6. turnerdhr
    turnerdhr HellaFlush(TM) Prius
    SINGAPORE
  7. turnerdhr
    SINGAPORE
    hey snapster,
    no spacers yet.. was a real pain... but i managed to just get the right offset!..... phew!!... BUT.... I'm thinking of getting some 5mm spacers for the rear... to get her perfect... will be looking for some now.... actually i think probably just 3mm will do.... I have already rolled the rear fenders and i really don't see much space back there to play around with.... we'll soon see....
  8. NC_Prius
    NC_Prius Member
    186
    I have a set of 16" aluminum rims wrapped in Goodyear Assurance Fuel Max 205/50/16 tires. The wheel/tire combo is 3 lbs heavier than the stock 15" rims and tires (each, so 12 lbs total). The tires drive more quietly and smoothly -- while coasting in my neighborhood this evening I could barely hear the car moving at all with the window down. The original Integrities made more noise.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    Centerline Monsoon RPM 17x7", 15lbs
    In my native habitat..... I switched back to stock so I don't mess up the Centerlines
  10. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    These weren't my choice, they came with the car and I wasn't too crazy about them at first but they've grown on me. ADR Designs Battle Exe I think. Only trouble is they must have been popular at the local tire shop because I've seen them on several different cars around town.
    - D
  11. sunstarfire
    sunstarfire New Member
    34
    Munich, Germany
    Die sind huebsch :)
  12. Fred_H
    559
    485
    28
    Germany
    Ja, und reinigungsfreundlich auch!
    Hi Sunstarfire!
    Have you checked out www.priusfreunde.de and www.priuswiki.de ? If you search there for "Rueckfahrkamera" you might find some helpful dokumentation for your camera problem.
  13. sunstarfire
    34
    Munich, Germany
    Actually yeah, I have. If you look in the wiki you will find an article about some LEDs for the interior, and I also asked some stuff on the forum. Seems to be nice there, but noone so far has retrofitted the original camera. I am collecting all the stuff I need (hopefully) and then will try it as soon as it gets a lil warmer :)
  14. mary2al
    mary2al Junior Member
    57
    SF Bay Area
    I took the plastic wheel covers off my 09 touring 16" (can't believe anyone would leave em on over those cool wheels)
    However now I need the small center hub cap -- any ideas muchly appreciated!
    Danka
  15. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    updated pic of my car....
  16. NC_Prius
    NC_Prius Member
    186
    I'm happy to report that the Goodyear Assurance Fuel Max tires are doing as well if not *slightly* better than the Integrities on mpg, despite being slightly heavier (with the new rims) and increasing the rim size to 16". I realize other factors may be at work. While the Michelin Energy Saver is a better choice, if you don't want to spend the extra $ these are decent tires, IMO. I thought I would have taken a mileage hit, but that hasn't happened. I was careful to select a lightweight aftermarket rim.
  17. Takaaaa
    Takaaaa New Member
    32
    Hawaii
    I was wondering are you lowered?
    Also do you rub at full turn or when you go over bumps? Im thinking about getting 18x8 wheels thats why.
  18. MarkusMann
    MarkusMann Junior Member
    Today I put new Michelin Primacy MXV4 tires (P185/65R15) with König Zero-In (15") light sport alloys (see pic) on my 2007 Prius (switching out the original Goodyear Integrity at 30,200 miles).
    I went for the Primacy for the handling and fuel economy. A proven tire (I was eyeing the Michelin Energy Saver A/S for a bit, but liked the Primacy handling aspect for my commute).
    The rims were a choice I'd been considering but didn't make the decision until they showed me them on the car, which is when I knew I had to get them. I like the look of chrome wheels, but I didn't want the added weight. So I went with the sporty looking light alloys.
  19. NC_Prius
    NC_Prius Member
    186
    Neena,
    Are those 17"? How is your FE in relation to stock with those tires/rims?
  20. Fred_H
    559
    485
    28
    Germany
    Hi mary2al, I don't remember where, but I once read that the small center hub caps from a different Toyota model fit perfectly on the original Prius touring 16" wheels, and are available from Toyota as a spare part. Unfortunately, I also don't remember which model. If your Toyota shop has some in stock, they might let you try if they fit.
