Poor Man's Toyota Badge Mod
Discussion in 'Gen 3 Prius Accessories and Modifications' started by NoMoShocks, Jun 11, 2009.
  1. NoMoShocks
    1,292
    83
    Camas, WA
    OK, if you don't mind having the top of you Toyota "T" being a black hole, there is body paint color under the rear emblem. This is really just an experiment in looks for me, becuase I don't really want the void hole under the top part of the T, and I noted the badge clips are not quite tight without the plastic film in-between, so if you were going to leave it this way, you would want to add some felt bumpers under the emblem or something to make it fit snuggly again.
    Rear emblem removal:
    Take a Credit Card. Sears MaterCard and Amazon Visa have both worked equally well in my trials. Gently work the credit card under the emblem toward the bottom becuase the plastic clips holding it are near the top and it is easiser to insert toward the bottom.
    Then carefully slide the card around to the right side of the "T". Left side may work equally well for leftys, but I have not confirmed this. Once the card is positionsed here (even with hidden clip) firmly push the credit card toward the T to deflect the clip while simultainiously pushing the badge in the same direction and genly prying up on the credit card.
    As you feel the badge clips release, pull back the credit card back with a quick steady swipe or the Prius may not read it correctly. I haven't got my bill back to see how much of a charge your Prius will debit to your account, but it can't be too much as this is a Poor Mans Mod.
    Now you can remove your badges, your options are many. Sand and paint the protection / window tinting guys can apply a variety of different colored vinyl films. By the way, does anyone know where I can get some thin film light emitting diode or other glow in the dark sheet material?
    Credit card trick doesn't work well on front becuase it is recessed deeper into the bumper, and there is dull black plastic under the front emblem. But, once you know the position of the badge clips, if you want to remove front badge, just reach down through the hole for the hood latch with a skinny wrist and release the clips from inside.
  2. HeyVern
    HeyVern New Member
    47
    Hickory, NC
    Used your credit card technique to remove my rear badge today. Worked exactly as you described. Thanks!
  3. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    What a GREAT FIND!!!! Never thought of this, and with a card the chance of paint finish scratching is minimal. And if the rear emblem is especially easy to release this way - super.
  4. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I followed your directions. Worked great!
  5. Nuckz23
    Nuckz23 Member
    127
    Santa Clara, California
    Thanks for the tip. Came off with no issues. The front was pretty easy as well. I am glad to see that ugly blue plastic go!
  6. kmkremer
    kmkremer Member
    227
    30
    San Diego
    This seems way easier than going in through the hatch door, as was outlined in a previous post. One question: does the uncovered hole that's left at the top of the T go anywhere or is it self-contained? I'm concerned about water damage through the hole.
  7. Nuckz23
    Nuckz23 Member
    127
    That's a good question. To tell you the truth the blue plastic piece really isn't stuck on there that well so I'm sure water is going in there already. I wouldn't worry about it.
  8. talonts
    talonts VFAQman
    468
    76
    Wiring it may be a PITA, but EL sheet should work well, and you can get it in many colors now.
  9. Penny's Dad
    Penny's Dad New Member
    421
    46
    Orlando Fla
    You didn't really post images of your credit card...did you? Ha Ha Ha Ha Ha Ha Ha...You are sooooo lucky the moderator saved your butt.
  10. Tideland Prius
    16,621
    Huh? It's photobucket's problem, not us. We didn't do anything.
  11. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Here you can use this LED wind powered T emblem for the front. (Ha)
    Wind Powered Sensor RGB LED Vehicle Logo - Toyota
    dealextreme.com/details.dx/sku.27848
  12. Penny's Dad
    421
    46
    Orlando Fla
    Well then could you alert me when the problem is solved...I want to book a cruise ;)
  13. Tideland Prius
    16,621
    sorry, i don't get the joke... or punchline...
  14. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    I used a nylon pry tool like this ...
    Both the rear and front emblems popped out nice and easy -- no trouble at all!
  15. jimlyons
    jimlyons Junior Member
    East Stroudsburg
  16. jimlyons
    East Stroudsburg
    Great Tip - I recently got this badge 3D printed and wanted to remove the OEM Toyota badge from my 2010 Prius III. Worked perfectly. [​IMG] TOYODA.jpg
  17. ASRDogman
    ASRDogman Senior Member
    7,827
    3,986
    To bad they spelled it wrong
