HV Battery Warranty After Replacement
Discussion in 'Gen 2 Prius Main Forum' started by CA2006Pruis, May 29, 2010.
  1. CA2006Pruis
    CA2006Pruis New Member
    Turlock, CA
    :confused:My HV battery died. A replacement was installed and everything seems to be ok. Problem is that the service manager said I have a One Year warranty on the New Battery!
    Since the orginal battery didn't make it to 100K, it died at 80K, and it only lasted 4 years, does it mean I am out of luck should the New battery fail in 13 months?
    The Service manager also could not tell my why the battery failed. They did not conduct any test to see if the "computer" was working correctly.
  2. richard schumacher
    7,664
    1,045
    United States
    You are not out of luck, but you do need to dump this dealer.
  3. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    A CA Prius battery is guaranteed for 10 years and 150,000 miles. Your new battery gets the remainder of that warranty.
    JeffD
  4. PriusDrift
    PriusDrift Junior Member
    33
    sacramento
    Hi Jeff,
    I am having issues getting my Toyota dealership to honor their warranty on a new replacement hybrid battery that failed after 19k miles and 2.5 yrs. Do you have a source you could point me toward that holds Toyota's 8 yr/100k warranty for Priuses older than 2020 extends to new HV battery replacements installed by Toyota? I am hoping I am not totally screwed after the dealer telling me the new replacement only had a 1 yr warranty and thus is no longer valid.
  5. bisco
    51,584
    toyota has upped the warranty on replacement batteries to 3 years if installed by a dealer. call and ask for help, they might cover it
    PriusDrift likes this.
  6. PriusDrift
    33
    sacramento
    Thank you for the info! I just found the memo for this change on PC, so I have written proof. PC is a life savor.
