Mildew Smell
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by joeyd08, Jun 11, 2010.
  1. joeyd08
    joeyd08 New Member
    62
    Garnet Valley, Pa/
    Thanks EdtheFox for the details on your handy work under the car. I imagine I'd never find the tube lying outside the frame of the car on the ground. I should have asked and checked before I bought the kit but for some reason I thought the drip tube was close to side of the car. I think letting them do the service is probably the answer as well since it's easy for them to get the car up and done. Curious what you use on the CV boots as that sounds like a good idea. Sucks to hear of the struts but as stated that should be a warranty coverage. At any rate I appreciate the info on where that darn tube was as I was very curious as the water drips further in toward the center after it travels across some sort of protective plate bolted to the bottom of the car....I had no clue. This chat never fails to inform nightly :)
  2. cobradb
    cobradb Member
    105
    tn
    occasionally turn off the comp and run the blower to dry out the evap,, make sure the drain is open also.
  3. Fester
    Fester Active Member
    201
    198
    Ohio
    I can add one thing to that which should help quite a bit. I always turn the AC compressor OFF a couple of minutes before reaching my destination, and leave the recirc. ON with the fan at medium or a tad higher. This allows the evaporator to come up to a non-condensing temperature before you shut down.
    Make sure the air intake remains in "recirc" as the cabin air is already de-humidified and you don't want to pump the evaporator coil full of highly humid outside air till its warmed and dried off.
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I wish I had taken photos before I sold the Prius. I drilled a pilot hole about 2.5 inches in from the firewall. I had a fiber optic inspection scope from work that I could borrow, made sure I wouldn't drill into the e-coil.
    Then drilled the 1/2 hole. I chose 1/2 because electrical knockout plugs are that size, so very easy to close when done. Sprayed in the NuCalgon EvapFresh, problem solved
    Here are some shop manual drawings of the Prius HVAC
    Yep, most of the stuff is just powerful perfume that temporarily masks the mildew smell. You also have to be careful to use a product that is compatible/safe with the material the e-coil is constructed with
    As an example, it would be tempting to use laundry bleach to "clean" the coil. Sodium hypochlorite will absolutely kill any mold/mildew in the e-coil. It will also destroy the aluminum fins and copper tubing of the e-coil
    NuCalgon EvapFresh is not only designed to be effective and SAFE for e-coils, it is also EPA certified to work as intended
    Now that you mention it, I have a Bryant Evolution system: variable speed gas furnace with 2 speed outdoor A/C unit, all hooked up to the Bryant Evolution control system
    That means I can program it for dehumidification priority. So it will run almost constantly on the lowest speed
    And stink like thousands of pairs of jockey straps unless I regularly treat the e-coil with EvapFresh
  5. hill
    8,784
    Um, we don't have the issue, because we used a recommended and effective product (on the evap core too) to eliminate the issue. :rolleyes:
    Are the products the same? Never heard of Ozium. I'll look it up to see what the active ingredients are - compared to DM-1:
    Ozium: Triethylene glycol & Propylene Glycol: Applications are multiple - from perfume, to solvent, to antifreeze, to food additive, to anticeptic, to de-icing, to deoderant, to food flavoring and more;
    [ame=http://en.wikipedia.org/wiki/Propylene_glycol]Propylene glycol - Wikipedia, the free encyclopedia[/ame]
    [ame=http://en.wikipedia.org/wiki/Triethylene_glycol]Triethylene glycol - Wikipedia, the free encyclopedia[/ame]
    DM-1: Isothiazolinone: Strictly created as an Antimicrobal [ame=http://en.wikipedia.org/wiki/Isothiazolinone]Isothiazolinone - Wikipedia, the free encyclopedia[/ame]
    I welcome any expertise, but since you've only offered the 'crap' word, without citing any authority, I'm happy to leave it at that. Good luck with finding some alternate solution. I'll stick by the one suggested by an AC guy.
  6. joeyd08
    joeyd08 New Member
    62
    Garnet Valley, Pa/
    I would be willing to give this a try since I still have the product....2 cans....actually thought it seemed the best plan when reading your post. Based on the 1st diagram did you drill about 2.5" out from the firewall into the casing...left side of assembly towards driver side? I am trying to be certain as I want to be sure I am able to spray into coil ...and not drill into coil
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    [QUOTE=hill;1144058]Um, we don't have the issue, because we used a recommended and effective product (on the evap core too) to eliminate the issue. :rolleyes:
    [ame="http://en.wikipedia.org/wiki/Propylene_glycol"]Propylene glycol - Wikipedia, the free encyclopedia[/ame]
    [ame="http://en.wikipedia.org/wiki/Triethylene_glycol"]Triethylene glycol - Wikipedia, the free encyclopedia[/ame]
    DM-1: Isothiazolinone: Strictly created as an Antimicrobal [ame="http://en.wikipedia.org/wiki/Isothiazolinone"]Isothiazolinone - Wikipedia, the free encyclopedia[/ame]
    Now you state that you used it on the evap core. Thats fine. Your previous post did not say that. How do you apply it directly to
    the evap core?
    Spraying it on the filter or in the filter vent does nothing.
    Been cleaning e-coils for lets see 35 years now and only way I've ever seen work is a liquid anti-microidial usually applied with a bug sprayer. Until the dealer came out with the compressed air can with a foamy version of that and the special nozzle it was a struggle to get directly to the e-coil with any cleaner.
    Which is why Jayman drilled a hole in the housing.
    Not looking for an alternate solution. My whole post was about how the dealer recommended fix does work.
  8. jayman
    13,439
    641
    Winnipeg Manitoba
    That is correct, the e-coil is up against the firewall side, the heater core is at an angle towards the passenger cabin
    Obviously, there is risk involved in drilling into the housing. Hitting the heater core will result in an expensive repair bill, hitting the e-coil will result in a VERY expensive repair bill
    Considering that TSB's are out for both the Prius and the FJ, and possibly other Toyota models, for the mildew A/C problem, you would think Toyota would engineer in a small door that can be easily opened to allow application of proper disinfectant
    The TSB that calls for replacing the e-coil, seems very excessive and ultimately will fail as well. It has been my experience that any sort of coating applied to the coil, such as NuCalgon CalShield
    Nu-Calgon: Products: Coil Cleaners and Sprayers
    will not last forever. Then what? Replace the coil AGAIN?
    Oddly enough, heavy duty highway tractors, such as those from Peterbilt and Kenworth, one can easily remove the entire e-coil with OUT evacuating the system. They are designed for easy cleaning
    Right.
    Not only that, as I stated in a previous post, there are a LOT of products that will work as a biocide. Thing is, are they safe for the metals used in typical e-coils? I used laundry bleach as an example of a product that would absolutely kill the mildew, but also destroy the e-coil in the process
    Also keep in mind that a product that will work as a biocide, many are NOT safe to use in HVAC applications. These products, once aerosolized, can pose a significant health risk
    The reason why I mentioned NuCalgon EvapFresh is because it has had extensive testing to ensure it is SAFE to both humans and the materials used in the e-coil. It is also EPA certified for use in HVAC systems, for the intended purpose
  9. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    I use 409 and it works great. I spray into the cowl intake and put control to external air with fan on high.
  10. joeyd08
    joeyd08 New Member
    62
    Garnet Valley, Pa/
    Well Ed a update note. I took the day off today so after cleaning my garage I put my car up on heavy duty jack and crawled under. I found the tube after several minutes of searching as I didn't have a flashlight. I see what you mean about needing to be under it directly as it is black and blends in. At any rate I was able to do the treatment (after another trip to Toyota as they forgot to give me the applicator hose/tip). I did use the spray into the intake as well for kicks. I did notice a big difference but almost think as second treatment may be required. That's ok though if needed now that I know the routine. Thanks for all the assistance and the detailed description which ultimately led me to find the silly tube! This chat is extremely helpful for sure.
  11. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Your welcome glad I could help!
