Over-torqued lug nuts
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mmichaell, Aug 31, 2010.
  1. drees
    drees Senior Member
    1,782
    247
    Actually, it's highly recommended that you do NOT apply any sort of anti-seize or lubricant to the lugs - this will result in over-tensioning of the studs.
  2. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Over tensioning, but I know from your earlier post that you knew that:D
  3. SteveWantsaPrius
    SteveWantsaPrius New Member
    17
    Southern California
    I always re-torque wheel lugs with a Snap-on torque wrench after leaving a tire shop. Its more business for them later when the brake rotors warp using an impact wrench. My current Toyota pickup has not had the rotors turned on over 125K miles and the brake pedal still does not warble. My previous Toyota pickup was the same year & model but needed the rotors turned every 20K before I knew how critical the torque setting is. The tire shops tell me it makes no difference if they use the air impactor. Yeah, right!
  4. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Perhaps.
    But if you live in an area that seens frequent application of road deicing salt in winter, not using Loctite Never Seize or similar will mean you will NOT get the nut off
    Or, with things that badly corroded, you WILL snap one off torqueing down again
    Especially if you run steel wheels in winter, then you have to use the proper "acorn" style lugnuts. You will notice plenty of Never Seize on the threads
  5. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Somehow I feel you (and others) missed the point SyZyGy was making...the smily tells it all...
  6. alexilic
    alexilic Member
    120
    Wauconda, IL
    Discount tires is great in my area. They torque every lug to spec(I watch), they fill each tire to the PSI I ask with a digital air compressor(50/48), rotate and balance your tires every 5k, check your air pressure anytime you want without looking at you as if you just interrupted something important. I always shop for best price(tirerack, costco, suburban, etc.) and their prices are either same or lower.
    As for no anti-seize. As Jayman said, if you live where they use salt and especially on steel wheels, your not getting those lugs off easily. My '03 Chevy 3500 has never had an issue with me using the anti-seize. I put it on the bolts, and the rotors. I have no issues removing my wheels when the time comes. 115k miles should be enough to show signs of issues?
