Centre Armrest Slide and Tilt, hitting kids in back seat.
Discussion in 'Gen 3 Prius Main Forum' started by JohnRobinson, Oct 22, 2010.
  1. JohnRobinson
    JohnRobinson Junior Member
    99
    29
    Norway
    Centre Armrest Slide and Tilt, hitting kids in back seat. *SOLVED*
    Hi all.
    Been looking through loads of threads but cant seem to find anything about this.
    Due to the way the armrest slides back to reveal the cup holder and then tilts it is hitting my sons legs while he is sitting in the rear seats. Cant quite see the logic in the design of this as when its slid back there is like 10 cm space between the back of the armrest and the rear seat. The design on our old 2007 was much better. No slide, just tilt. I know that my 3 boys in the back will find some way to damage it while its slid back or tilted back plus I dont really want my sons legs to be cut off in a potential accident.
    So my question is, has anyone managed to successfully modify it to stop the slide and allow it just to tilt?
    I have looked at it quickly and when its tilted there is a small square underneath where you can push a small plastic piece that allows you to extent the armrest back to the full length effectively making it exactly like the gen 2 model. Problem is that when its put back down you have to go through the slide and tilt process again. Im sure it should be pretty simple but hoping someone else has modded it before.
    I am going to try and modify it tomorrow but dont really want to damage it in any way.
    Thanks in advance.
  2. Michaelvickdog123
    Michaelvickdog123 New Member
    332
    US
    Good GOD!
    Is this pasenger sitting in the middle of the back seats? Otherwise, if they are near either door, why would sliding it straight back hit them in the leg? :eek:
  3. JohnRobinson
    99
    29
    Norway
    THREE boys. Three rear seats. My middle son is seven. No real need for the good GOD statement in my opinion.... :(
    Threej likes this.
  4. bisco
    52,417
    well said, and it shows that prius is not a great family vehicle. poor designof the whole center console. i thought toyota would make better use of the empty space in front of the gen ii console, not totally screw up the whole thing. what a clusterf***. hope you have some luck with modification.:)
  5. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    GOOD GOD
    Learn to read!!!!!:D
  6. Sassan
    Sassan New Member
    33
    Troy, MI
    I agree. I dont know why anyone would want a sliding console... when would i ever want fewer cupholders? Im already uphappy with 4 small ones as it is.
  7. donee
    donee New Member
    2,956
    198
    Chicagoland
    You are not the only one. Its just a plain stupid design for a general purpose car....
  8. GasSaving
    GasSaving Saves $1,000/yr on gas
    52
    Boston
    I think the center console does a great job hiding my iPod, while still allowing full function of it. Isn't that the whole point of the design of the center console? When you have 3 in the back, I think you need to think ahead. But you're right: I don't think the Prius is designed for families with 3 kids. Maybe get a Sienna? Or the new Prius V minivan when it comes out?
  9. JohnRobinson
    99
    29
    Norway
    I got my car a few days ago and have no intention of changing it. :p
    All I am asking is if someone has modded it before? If not Ill attempt it myself.
    Well seems like I am not alone so I will take a look today and if I manage it will post some pictures.
  10. Penny's Dad
    Penny's Dad New Member
    421
    46
    Orlando Fla
    I know what you mean..My kid gets in one side and slides across to the other. If the console is slid back...there is drama. This is one thing the big T did not get right I.M.O.! Let's hope some genius on the Accesories forum figures out a cool mod. I'm sure with the engineer types on this forum it will be done.
  11. JohnRobinson
    99
    29
    Norway
    Well I managed it. Here is a quick video of it in action and I will give an explaination later. :rockon:
    Whats great is that you can tilt it like the gen II but it can also still slide for those that want it. Or of course when the kids arent in the car. :)
    [ame=http://www.youtube.com/watch?v=b20bQwh-tWw]YouTube - Prius Centre Armrest Modification[/ame]
    2 people like this.
  12. Michaelvickdog123
    332
    US
    And you know what my "good God" comment was in regards to? Hint: not the 3 kids in the back.
    But nice attempt at reading between the lines!!!!!! :rolleyes:
  13. JohnRobinson
    99
    29
    Norway
    I have to say that there are two ways to do this. I did it the complicated way by taking everything apart and removing the bits properly. I had to so that I could see how best to acheive it. However listed below is the quick and easy way!!!
    Anyway here is how I managed it:
    6 people like this.
  14. JohnRobinson
    99
    29
    Norway
    By removing the two springs and taping the little pins back it stops the whole armrest from "locking" to the centre console. By doing this it means you can,
    1) Tilt the whole armrest like in the Gen II and
    2) Still slide the unit like normal as well as tilt it after the slide. Basically use it like normal.
    Whats good is that even though the locking pins have been disabled you can still click it in place to stop it from being loose. Check the video out.
  15. JohnRobinson
    99
    29
    Norway
    NOW FOR THE EASY WAY:
    Get 2 pieces of tape and place it over either the two pins themselves or the locating whole to basically stop the armrest from locking onto the console!!! :D
    Nothing needs to be taken apart!
    sdtundra, bzyrice, peterjmc and 10 others like this.
  16. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Thanks for the fix.
  17. Jocko Jackson
    Jocko Jackson New Member
    27
    Ha ha when I first red this title I thought it was bout disciplining kids. Thougt this was some kind of new discipline tool this armrest thign to give them a good beating when they act up and disrespectful. :rockon:
  18. JohnRobinson
    99
    29
    Norway
    lolol!!!! :d
  19. donee
    donee New Member
    2,956
    198
    Chicagoland
    Thats Great! Now we need some way to have it slide downward, once its tilted vertical just a little bit (5 inches?). Then it could be left open if need-be.
  20. JohnRobinson
    99
    29
    Norway
    If I understand you correctly then when its fully open (gen II style) it can still be slid backwards or downwards like its designed to do.
