Another Strut Tower Brace Option
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mrbigh, Apr 5, 2009.
  1. pEEf
    pEEf Engineer - EV nut
    720
    579
    Berkeley, CA
    After looking carefully at your pictures, my brackets are definitely almost identical to yours, but there is no way my cowl pan will go back in like that.
    I wonder if there could be a difference in the 04 vs 08? Maybe they made the Cowl pan deeper?
    Anyone know?
    Do you suppose you could do me a favor and take a pic of what the bar looks like under the cowl? Might be hard to get, but if your cam has a Macro setting it might work. This way I can see if there is a difference.
  2. mrbigh
    3,686
    699
    Long Island, NY
    As an inside information for the install, I had the same problem you described; my solution was to bend downward the towers bracket, where I circled in the pictures.
    The flat bar of the tower's link, barely clears the cowl but it laid flat just atop.
    Once the cowl is installed, I can't see the Strut's bar.
    Also, there is no difference in the body panels in between MY 2004 -2009.
  3. patsparks
    10,664
    567
    Adelaide South Australia
    I'll be chasing this up, I love to throw my prius around in the twisty stuff. Although I think it handles really well I'd like to get a little more. Don't us petrol heads always want a little more? :)
    Simtronic likes this.
  4. s3nfo
    s3nfo Member
    164
    24
    San Diego, Ca
    Petrolheads, hadn't heard that one before. This side of the pond we're gearheads.
  5. richbrvd1987
    richbrvd1987 New Member
    26
    West Hollywood
    I may have misunderstood the post. The OP has a U-shaped brace and the other poster is using a conical brace. This could be the issue.
  6. patsparks
    10,664
    567
    In Australia we are petrol heads, always have been.
    Oh and I knew about "gear heads", we get American culture on tap in Australia.
  7. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I had the same problem, I resorted to a little panel beating of the cowl, followed by some mastic to ensure it was watertight. I am glad I persevered it has transformed the ride especially high side winds on motorway (freeway to some) and slow sharp bends
  8. silver_prius_2008
    silver_prius_2008 New Member
    I am just wondering about any conclusive benefits of this installation? As I drive mainly on suburban streets, is this still beneficial? I have just had my wheel alignment done recently and asked the tech guy to have toe in adjusted to 1mm instead zero (toyota spec). This have made my steering noticeably more defined and more stable on the road as well.
    Any comments and ideas?
  9. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    Have you taken a MPG hit? I would also be concerned about tyre wear I guess that was toe out as toe in makes most cars handling skittish at best. The short answer to your question is yes, major benefits I was recently reminded of this when I drove someone else's Prius and remembered how poorly they handle rough roads (we have lots here in UK) I also noted major improvement from changing my front tyre size but then I have 16" wheels like the US touring version
  10. silver_prius_2008
    No effects on mpg so far as the amount of toe in is till within the limits but not zero. As for tire wear, I will know for sure after another 5000km but I doubt. My current front tires were like newish when I bought the car and was told that rubber is getting hard two weeks ago (about 3 yrs old).
    As for the strut bar, is there any rubbing issues against the wire bundle(passenger side), bracket for the electric motor and the foam under the cowl plate? I am still tossing up on this as there is not much room under the plastic plate and clearance may be an issue.
    The middle chassis plate definitely improved the handling and stability. It also has damped the rattlling noise from the rear plastics (tail gate trim). Any means to make the front tight would be desirable if the benefits are real.
  11. Sezy
    Sezy Active Member
    443
    231
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Going to be trying this tonight. Wish me luck,I'm using a brace for a Corolla I got off ebay.
  12. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    good luck 'n take pictures. I been thinkin about this mod too.
  13. Sezy
    Sezy Active Member
    443
    231
    37
    2020 Prius Prime
    Fail... Poor fitment. There was no way I could make this fit without hitting the crowl. You would have to cut the crowl and some tabs off. The bolts matched up but could not make it fit no matter what way I turned the brackets or bar. The ebay auction was titled "MEGAN RACING FRONT UPPER STRUT TOWER BAR 03-06 TOYOTA COROLLA E120 2ZZ 1ZZ ALL" I plan on reselling it on ebay because it would not be worth returning for a restocking fee and shipping.
  14. Mike500
    Mike500 Senior Member
    2,593
    767
    This is one situation that I'd recommend the Tanabe;
  15. 69shovlhed
    2,170
    752
    Delaware
    looks like the same one the op used. did you try flipping it over and adding washers under the brackets like he did?
  16. Mike500
    2,593
    767
    No, the Tanabe is a perfect fit for the Gen II Prius. No modifications are needed.
    To me, the money that you'd save on one that needs to be modified is NOT a savings, given the aggravation and time spent getting it to fit, if it is even at all possible.
    Sezy likes this.
  17. mrbigh
    3,686
    699
    Long Island, NY
    Hey, that's me!!!
    As you can see in the pictures the Corolla brace had a good fitment with a little extra work. At that time I saved a bunch of money with the aftermarket, don't regret it.
    Justdidit likes this.
  18. Sezy
    Sezy Active Member
    443
    231
    37
    2020 Prius Prime
    Flipped it every way possible including the brackets and angling the bar. Washers would have made it go further up into the crowl. Tanabe has been ordered. Lots of people were out on amazon so ended up getting from ebay.
  19. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    I don't understand why everyone feels the need to add all this racing crap to the car. It drives fine as is
  20. Mike500
    2,593
    767
    Some people are after the "image crap."
    Other prefer no outward image and a little better handling. I haven't driven high performance in years. No need to. I did it chasing crooks years ago.
    If you are numb or dead to any feeling in the car's ride and satisfied, that's fine.
    Everyone has their preferences, including you!
