Almost 540 miles on the very first tank!
Discussion in 'Gen 3 Prius Fuel Economy' started by bennela, Nov 26, 2010.
  1. bennela
    bennela Junior Member
    Philadelphia, PA
    Hi everyone. Got my first Prius (2010 model III) on Veteran's Day and the fillup the dealer did when I bought it was running low, as I heard a beep and the one bar on the fuel display was flashing. I pulled up to the pumps at the gas station and it took 9.63 gallons to full! I am ecstatic and love this car. I have been trying to use all the techniques I have learned both here and at the cleanmpg dot com forums. Thank you all for the advice and I look forward to learning much, much more so I can get that mpg even higher.
  2. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Very good. and welcome
  3. 02semiata
    02semiata New Member
    New York
    wow thats awesome man. Good job. I hope my first tank is that good
  4. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Welcome to PriusChat and the world of Priusdom! :welcome:
    Great job on that first tank. :cheer2:
    Take it from everyone here, it gets even better!
  5. Roy's Prius
    Roy's Prius Roy's TOY
    Alaska
    Congrats on your new Prius.
    Test drove an insight and prius on black friday, went back and bought a "Blizzard Pearl White" Prius III on saturday. My first 100miles of driving has been to work and around the town of Fairabanks in cold weather. Today -25F coming home!
  6. ETC(SS)
    7,350
    Congrats and Welcome Aboard!!
    540 is pretty dang good... :D
    Good Luck with the new ride!
  7. Rafiks
    Rafiks Junior Member
    Sebring,fl
    Wow . Thats awesome .Did you wait till its almost empty?
    I'm also on my third fuel-up myself. my first one was 427 . I keep track of mine via fuelly.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Roy, you should start your own thread about the Prius performance in Fairbanks! I would really like to see how it does up there this winter (I am in Anchorage).
  9. hill
    8,916
    Way to go bennela ! Before you know it, you'll be doing over 600 miles per tank! My first 700 mile tank, I felt like I'd just won an olympic medal . . . . being the nut job that I am. :p
  10. bennela
    Philadelphia, PA
    Thanks everyone. Rafiks, I didn't wait until it was empty, but rather when the last bar on the fuel gauge started to flash I got gas soon after. It only took 9.6 gallons to fill and this was the tank the dealer put in, so maybe they didn't top it off. Anyway, I should be getting at least 600 miles per tank from now on and I'll keep trying to get more and more with the various techniques I've learned from here.
    One thing I do find difficult though is the gliding on the P&G as it seems this Prius doesn't want to glide well. We use Gen II's at work and it seems they glide easier. When I glide my Prius, It seems to slow down too much. I try and keep just a bit of the beggining of the left hand side of the "fat bar" lit on the HSI screen, as it was advised here, but the car seems to slow down too fast, even on level roads. This is worse at highways speeds (50+ mph). It seems I have to always keep the engine running (right side of the fat bar lit halfway ) to slowly drop speed. Tires are at 40 psi front and 38 psi back. do not know what's up.
