07 prius with no start condition.
Discussion in 'Gen 2 Prius Technical Discussion' started by Nick1214#6, Dec 9, 2010.
  1. Nick1214#6
    Nick1214#6 Junior Member
    Smithtown, NY
    I am Toyota certified and my prius will not start. I got into the car pushed the button and it just dimmly lit the maint required light. I think it may be the battery as it started right as the weather got cold. Please advice on whethet I should try changing the battery or have it towed in for free and pay Toyota.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    You can jump start the car by carefully following the instructions in the Owner's Manual. The jump connection is under the hood. After you get started, I suggest you replace the 12v battery. It's on its last legs...
  3. Nick1214#6
    Smithtown, NY
    That is what I was hoping it was. I didn't have time this morning so I put it off til later. It made me really nervous. I hope that's all it is
  4. masini
    masini New Member
    I really do not know but no only the battery could cause this. Ii could be others causes to.
  5. firepa63
    1,761
    208
    It's the 12v battery...
  6. Nick1214#6
    Smithtown, NY
    Is there a Diy thread on replacing the 12v battery? I have never done it
  7. pEEf
    pEEf Engineer - EV nut
    720
    579
    Berkeley, CA
    There are tons. I recommend an Optima. Search is your friend!
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    I love your Wally Watt. I used to collect Wally memoribila.
  9. Nick1214#6
    Smithtown, NY
    Thanks for the search tip. I always use it which is why I have so little posts but I am on my phone now
  10. Nick1214#6
    Smithtown, NY
    I am having someone at an independent shop change the 12V battery but I would like to find the DIY thread on the forum. I am having some trouble doing so. If anyone knows what to search and can provide a link that would be great. I am going in in the morning and will keep a close eye.
  11. pEEf
    720
    579
    Berkeley, CA
    This Page by Hobbit may be of use. It's the best documentation out there I know of, but you don't need to do everything he does, such as the auxiliary 12 volt battery steps to preserve your memory/settings/clock.
    MK1228 likes this.
