Wi-Fi SLOOOOOOOW!!!???
Discussion in 'Fred's House of Pancakes' started by daniel, Dec 24, 2010.
  1. daniel
    14,487
    1,519
    Spokane, WA
    According to your link, the AirPort Extreme is pretty good.
    Thanks. So I'm using the right one, which is in fact the only one the AirPort seems to support.
    I didn't know they did that. I'll ask them about it tomorrow or the next day. (I may be busy with a lot of other stuff tomorrow.)
    It would be worth it to get some real speed into the iPod.
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You would have been told correctly. Any geek can crack a WEP network within an hour. With automated tools and a secondary WLAN card (as I have) you can get it down to less than 5 minutes before you can login to their network. Most people use weak passwords or dictionary passwords so it is like stealing candy from a baby.
    That is actually a very good site and test routine.
    It's a bagillion times stronger. :)
    Where does Comcast do this? Comcast specifically states in all TOS I have seen that they are only responsible from the ISP building to your modem. After it leaves your modem's switch, it is your responsibility. Actually when you have a network setup, if you call Comcast out to help, the very first thing they do is disconnect your whole network, then test the modem solo. They wont put it back together.
    If you can open up a screen on the iphone that shows the SNR and Signal in (dBm) of networks it is seeing, or at least on a laptop (I guess you would have a mac book), then I would walk around. Use it and walk a foot or two or so at most between refreshes. For instance, my E3000 updates these stats at 1Hz. So I walked around going about a couple feet then checking SNR, walk some more, check SNR, and so on. This will let you know what sort of wifi pattern you are getting. If you can change the ACK settings, then set it to about 1.5 times the radius of the largest point between the router and where you want service. So if it is in some corner of your house, and it is X meters from the router to the sidewalk, then put in X * 1.5 as the ACK settings (integer rounding obviously). Note that this number is in meters.
    Comcast gives you a global IP address. This is the unique identifier that your modem and only your modem has. No other device in the whole world has this same number. This is how the world talks to you and knows where to route data.
    Your router takes this IP address and uses it to talk to the outside world. However it also assigns another IP address (local) to your computers. Usually 192.168.1.xxx because it is standard. It could be anything you want though. So when your iphone request data packet A from google.com, it tells your router that it at 192.168.1.Z wants packet A. The router then tells the modem it wants packet A. At the same time, your imac (at 192.168.1.Y) says it wants packet B from bbc.co.uk. So the router says to the modem you want packet B too. So the interwebs gives your global ip address (maybe 12.34.567.890) packets A and B and that's it. Your router then sends packet A to 192.168.1.Z and packet B to 192.168.1.Y automatically. Hence the router part. ;)
    Now these IP numbers are usually given by a DHCP server. So when something new connects to your router, it says "hey I am new, give me a unique local IP address". The router checks a few parameters (like if it is allowed to give out IPs, if it has given out its maximum number of allowed simultaneous IPs, and so on) and then sends back 192.168.1.X as the IP for the new device. Now since these are from a Dynamic (the D in DHCP) server, there is no guarentee that it will always be 192.168.1.X. If you turn every device on the network off, then turn them all on again your iphone may now be X. However if you set them up statically, then it will always be what you set them to be. Then instead of asking the router for an address, the device just says "my address is BLAH, so give me my stuff". If there are two devices setup with their addresses as BLAH, then the router doesnt know where to send it, and you get an IP address conflict and neither device works.
    DNS is not really something you need to care about. It is a dynamic name server, and maps IP addresses (usually global) to human readable strings. So the best website in the world is Google
    You may know it as "google.com" though. When you type in google.com, there is a lookup done on a name server that translates it to "74.125.224.51" and gets the info there which just happens to be google.
    So unless you are running a server, disregard the DNS. And unless you want statically assigned IPs, stick with DHCP.
    Stick with WPA2
    Change your channels to something non-automatic. Like I said before 6 is crowded because most people just plug it in and never change it. So you have a bunch of interference.
    I would NOT do that. Buy a separate rotuer and a separate modem. Just buy one that is good. Buffalo and Linksys/Cisco make really good routers. Buffalo is better out of the box. Linksys/Cisco have better 3rd party support and the firmware is better after being flashed. It is pretty automatic and easy to do nowadays if you follow the instructions.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The 2.4Ghz is pretty good but the 5Ghz is not. Are you connecting to the 5Ghz network on your imac, or the 2.4Ghz network? Also note the review is over a year old now, it ranks much lower now though.[/QUOTE]
  4. daniel
    14,487
    1,519
    Spokane, WA
    I do not do that. If anyone is going to crack my system, it will not be by guessing my passwords. But I don't know if a longer password makes it harder to crack a system where the password cannot be guessed.
    No, I don't have a MacBook. I have the iMac and the iTouch. I also have a laptop and a netbook, both running Linux, and the Nokia N800, none of which I use since getting the iTouch. Each in its turn was my travel computer, and each was an improvement in size and weight over the one before.
    I have no idea how to read the signal strength of a network, other than the little icon in the corner which gets bigger or smaller.
    But I will say that based on a subjective assessment of performance, it does not seem to matter where in my house I am.
    I will. In fact, I have no choice. That's all the AirPort has.
    Only two networks are visible from my house. Both probably belong to my neighbor. (One has her name on it, and the other might be the default on the same router.)
    How do I know what channels I should use?
    I had a Linksys router that died. Not sure I trust them.
    How can I tell?
  5. daniel
    14,487
    1,519
    Spokane, WA
    I did manage to find my total usage for the month on my account page on Comcast's web site. I've been consistently using 6 or 7 GB of my 250 GB allowance. The last few days, since downloading the NetFlix app I've been watching more than I expect to do generally, and it looks like I've used about 2 extra GB in the three days. So if I started spending all my spare time watching NetFlix, which ain't gonna happen, I'd never get to 50 GB.
    But thanks for the heads up.
  6. tnthub
    tnthub Member
    519
    Brunswick, Maine
    All hardware, sooner or later, "dies". The Linksys, DLink, Netgear consumer stuff will all have issues from time to time but over the past couple of decades the least amount of problems I have seen are with Linksys. However I have a router for security and keep my wireless access separate, and use a switch for wired internal access. This configuration is safer, faster, more reliable, and easiest to diagnose in case of a problem. It also has the capability of being temporarily reconfigured if a component fails.
    WPA2 is fine for most household use. You will also want to turn off your SSID broadcast. As far as channel selection, try anything other than the default selection and see if things improve. I also suspect you can turn off IP6. Hard setting your IP addresses eliminates the router having to do DHCP and can make your network more stable. I have a server doing DHCP for the laptops but desktop machines all have static IPs.
  7. daniel
    14,487
    1,519
    Spokane, WA
    Okay. I changed the channels and I turned off SSID broadcast. I would have turned that off anyway, but I didn't find it before. It goes by a different name in the set-up program but by careful reading I found it.
    Under IP6, my options are:
    "Link-local only"
    "Host"
    "Tunnel"
    "Router"
    "Off" is not an option. I have no idea what any of the selections mean, so I left it on the default of "Link-local only."
    So far, I don't notice any differences, except that the first time I turned wi-fi on from the iPod I had to manually enter the network name, since I had turned off SSID broadcast, but after that it remembers; and the SECOND time (???!!!) I had to enter the password.
  8. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I originally set up our wireless network when I was working with people that had "LAN parties" on a regular basis.
    Naturally, as soon as my friend was out the door, I changed the router's name, and changed to the tightest security and a more complex key system :thumb:
    I am fortunate that I have friends that have 1)Mac systems, PC systems, and/or 2)their own business setting up networks. Can I forward your issue to one of them?
  9. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    Oh, and I should mention, that watching Netflix on my desktop PC (direct connection to router), occasionally mine will stop and "adjust playback"... in which case, I know it is an issue with Comcast.
  10. hill
    8,894
    We've been all smiles after moving up to the giga hertz stuff
    woo hoo !!
    :eyebrows:
    I LOVE the 50+" LED TV's they're selling now, that come wi-fi enabled. I may never get anything done, ever again, if I hook that into our network. Cox cable downstreams to us at a minimum of 20mb/second. That said, I get the strangest looks when I tell folks how much I love cox.
    :pound:
  11. daniel
    14,487
    1,519
    Spokane, WA
    Certainly.
    Today, after having disconnected and re-connected everything (maybe a poor connection before?) I am getting:
    Blazing fast Wi-Fi to the iMac;
    Pretty fast, but less, Ethernet to the iMac when it is plugged into the AirPort;
    Widely varying Wi-Fi to the iPod, ranging from 8.75 mbps on one run, down to 1 mbps, and everything in between, with 2 mbps being the most common.
    (All tests are speedtest.net on the iMac, and the speedtest.net app on the iPod.)
    My big question at this point, is:
    Why, when my cable modem consistently delivers 30 to 45 mbps, does the iPod Touch (3rd gen) ever go below 8 mbps, and so often hang around 2 mbps? It does not seem to matter where in my house I hold the iPod.
  12. bisco
    52,274
    just outside of boston, comcast came out and set up my cable modem, hd box, wireless router, phone system and laptop computers. are you looking for more than that?
  13. daniel
    14,487
    1,519
    Spokane, WA
    Right now, all I want is to get my iPod up to a consistent 5 mbps. But now that the iMac is getting consistently fast speeds from the AirPort's Wi-Fi, I no longer suspect a problem with either the AirPort or the cable. The problem seems like the iPod. But it's beyond the free service advice period. I'm hoping for useful advice from the discussion board at Apple.
  14. bisco
    52,274
    ya, i doubt comcast would get involved with that. good luck.
  15. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    It is difficult to say, but I doubt iPod was designed to handle tens of megabits per second of downloads in mind ...
    For IPv6 select tunnel or local link mode only.
    Then select Automatic for IPv6 network settings on your OS X machines, iOS 4.2 and higher devices (iPad, iPhone, iPod Touch, ...) handle IPv6 automagically, for Windows use Google :)
  16. Ogo
    220
    44
    As images say more than words.
    IPv6 settings for Airport Extreme:
    IPv6 Mode: Tunnel
    Block incoming IPv6 Connections: Checked
    Configure IPv6: Automatically
    On your Mac, go to System Preferences, Network, Advanced, TCP/IP:
    Configure IPv6: Automatically (default is Off)
    (If everything breaks apart, then use Link-local only for IPv6Mode on Airport Extreme and Configure IPv6 to Off on your Mac)
    Not all operators/providers support IPv6 yet, but those settings above are usually good enough for things to work when they will start supporting the new internet protocol.
  17. tnthub
    tnthub Member
    519
    Brunswick, Maine
    Not to start a debate, but for regular household use IPv4 might work better... I have found many odd issues over the years that removing IPv6 seems to "fix"...
  18. daniel
    14,487
    1,519
    Spokane, WA
    One person told me that Wi-Fi on the iTouch was an afterthought, and has never worked very well. A guy at the Apple store told me just now that his own gen 3 iPod Touch is about as slow as mine. Netflix was actually able to look at a history of my instant viewing and my internet connection speed, and showed that sometimes it's as high as 6 mbps, but that when it stops it's because the speed dropped below 3 and the device had to re-buffer.
    So I now think my problem is that the iTouch is just not capable of the speeds needed for NetFlix streaming. But in the end it's not really a big deal, since I cannot send the stream to a TV set because NetFlix does not allow that from the Gen 3 iTouch.
    I guess it's back to watching DVDs. Maybe I'll upgrade my DVD system. That will be another thread.
  19. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    You could have interference on your default channel.
    On your laptop, do a search for available wifi signals and see if it'll tell you what channel they're on. Set your router to use one not already in use by your neighbors.
    Lots of stuff uses 6 GHz. Do you have any 6 GHZ cordless phones or baby monitors? Try turning them off.
    Even old 802.11b should be able to handle 10 mbps unless you're 50 feet and 10 walls distant.
    If you get good speed tests right out of the modem, then it's a wifi problem and calling Comcast won't help...they're doing their job.
    If the laptop on wifi gets good speed in the same location the iPod doesn't, then it's an iPod problem.
  20. tnthub
    tnthub Member
    519
    Brunswick, Maine
    If Netflix determined a drop in connection speed, that would be outside of your internal network. Call Comcast and have them check if your cable modem is in full or half duplex mode. In my area, the default setting (by Comcast) is half duplex and what occurs is that when there is a lot of traffic on the Comcast wire speeds drop significantly. I had the tech set my Comcast cable modem to full duplex mode and my speeds now stay very consistent:
