Better cargo area lighting.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by adric22, Jan 16, 2011.
  1. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    I got fed up with the wimpy little light bulb in the cargo area. This is especially important to me since I have an Enginer kit back there and if I ever needed to open it up in a dark parking lot or something, I'd never be able to see anything. I can barely see groceries back there. So I bought these two LED strip lights at AutoZone. What I did was pop the little light fixture out and soldered the wires directly to the bulb. I tried to solder to the metal in the fixture, but it proved resistant to soldering. I brought the wire out to two pigtails, one for the left side of the cargo area, one for the right. The lights are flexible and have a very sticky back so I just stuck them to the trim panel and drilled a small hole for the wire. I had experimented for a while to find the optimal position for these lights, and this area seemed to work best. Right now I only have one installed, soon I'll have the second one. I can tell you this, the result is fantastic. The lighting back there is tremendously better and it only cost $19.
    2 people like this.
  2. PhazonPhobe
    PhazonPhobe His name is Sora
    221
    26
    28
    Fontana, CA
    Ohhh. I like that. Seems pretty simple to do as well. I've always hate the lighting back there as well. I don't have an engineer's kit, but I basically have a whole tool box under the carpet, and I'm usually found using the flash light app on my phone to see wth is in there.
    I might even like to add a strip or two to the inside of the little compartment under the carpet. Seems like if you were to put one on each side (just stick it right to the plastic bucket/basket thing), it would light that area fairly well.
  3. pEEf
    pEEf Engineer - EV nut
    720
    579
    Berkeley, CA
    I also have a PHEV system back there and wanted more light. I ended up replacing the crappy incandescent bulb with a 3 watt LED to achieve the same result. I'll try to post pictures when I get a chance.
  4. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
  5. adric22
    642
    146
    Fort Worth, TX
    Yes, that is the exact product I used. I don't think it is 24", unless you count both strips. I just finished wiring up the other side and it looks great, I couldn't be happier with the concept.
  6. kenmce
    kenmce High Voltage Member
    1,551
    524
    NY
  7. macmaster05
    macmaster05 Senor Member
    4,050
    730
    I'm using a 6 SMD LED festoon in place of the oem bulb and it is significantly brighter. The only problem is I had to pull back the clips pretty far to make the bulb fit.
  8. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Any thoughts on, say, a 12 SMD LED festoon?
    Such as, eBay item # 170668435584 for example
  9. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    I tried a 12 SMD and it didn't fit in the fixture with the cover.
  10. trentofdestiny
    1,104
    227
    Harrisburg, PA
    If you look for the incandescent part number equivalent, you of course come up with the 31mm festoon, BUT if you search eBay for a 28mm, you get a 28mm.
    Example: eBay item 140587233079
  11. newemi
    newemi Junior Member
    43
    Corona, CA
    Festoon Dome Lights from autolumination FTW.
    They have the replacements for festoons that are so freaking bright its ridiculous. I replaced the bulbs in my lancer with them and even though I have 20% tint all around. At night when I open the door you wouldn't have a clue. It's like the sun came up inside my car.
    The best ones are three quarters the way down that page, the 25-48 led array. The ones with the leds mounted on a small board/chip, and wired to the plastic festoon fake bulb. Or another easier option for a simple buy: Super Bright LED Car Interior Lights | Toyota Prius SMD LED Car Lights
    But the leds are not as good overall.
  12. jason petter
    jason petter Junior Member
    To: adric22
    can you show more info how to install it ? where do you buy the "wire out to two pigtails" thanks
  13. SunDevilDrake
    SunDevilDrake Junior Member
    58
    Gilbert, Arizona
    I recently put in a 6 SMD LED in. OP could do the same so the original light and after market light match colors.
    Any new pics in the dark with both sides done?
    Radioshack (n)
    #13 SunDevilDrake, Jul 30, 2015
