12v Auxillary Battery Removal Question
Discussion in 'Gen 2 Prius Technical Discussion' started by tigiras, Jan 20, 2011.
  1. tigiras
    tigiras New Member
    Utah
    I'm trying to remove that 12V Aux Battery but there is a little tube that attaches from the side of the battery into the body (see pic). Anybody know what it is and how to detach it?
  2. Britprius
    Britprius Senior Member
    5,194
    1,916
    Herefordshire England
    Its just a vent to let gasses from the battery escape outside the car just pull to remove.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Just make sure you replace the plastic tube, it's does vent those smelly gasses, as well as hydrogen, which is generated as the battey is charged!
  4. pEEf
    pEEf Engineer - EV nut
    720
    577
    Berkeley, CA
    Normally the vent does nothing. It's there in case of a fault that causes an overcharge. Normal charging does not vent anything, if it did, you'd be losing a lot of water!
    A fault could be DC/DC overvolt, or a shorted cell which would mean the remaining ones see too much voltage. In that case it would most definitely vent!
