Fuel filler pipe door
Discussion in 'Gen 3 Prius Main Forum' started by Roland1555, Feb 8, 2011.
  1. Roland1555
    Roland1555 Senior Member
    282
    69
    Vancouver BC
    Maybe I've lost it, but I could swear there was a little spring loaded door or cover in the fuel filler pipe of my Prius.
    About 2 weeks ago, I experienced a low power, take off from standing start that almost proceeded to a bucking event when I pushed a little bit more firmly on the gas peddle. I had just refuelled the night before and in my mind thought about bad gasoline.
    It never happened again since then, but I had to refill last night at a self serve station and I noticed that this little door that I could swear existed was no longer there, just a restriction funnel to make certain you could only fuel the car using the proper sized nozzle.
    Now I wonder if the door was impeading the fuel pick up in the tank.:confused:
    I'd be very happy to hear from you folks if there is in fact a little spring door in your cars fuel filler neck visible when you have unscrewed your fuel cap.
    Thanks, Roland.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Not on mine. I unscrew the filler cap and see the hole to the filler pipe (or the restricter funnel as you say).
  3. Roland1555
    282
    69
    Vancouver BC
    Thanks for the quick reply.
    As I said, I questioned my imagination, it could after all have been feature on a previously owned car, and I wasn't certain.
    Roland
  4. bisco
    51,840
    now that you say that, i thought mine had one but i'm no longer sure. gonna have to take a look!:rolleyes:
  5. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I rented a new Ford Focus the other day and when you open the fuel door, there is no cap. Only the spring loaded cover that you push in to the filler throat with the gas pump nozzle. That is one of the first cars that I have seen that did not have a gas cap.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    My Prius doesn't have a check valve either, just a pipe going down toward the tank.
  7. bisco
    51,840
    are you sure it wasn't missing?
  8. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    The owners manual doesn't say anything about a spring loaded filler cover. I don't have one on my car. As long as the fuel cap is securely seated until "clicked", I'm not sure why it needs an additional safeguard.
  9. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I was like you and looked at it closely to make sure but there was no where to attach a gas cap of any kind. I also rented a Ford Fusion this summer and it was the same way. No gas cap.
    Can any new Ford owners confirm what I saw with the rental Fords?
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Yes my previous car, a Ford Mondeo, had the Ford "Easyfuel" system. No cap and a filler neck that only allows the correct fuel (diesel or petrol) to be put in, by the size of the nozzle on the pump. I found that water could get into the neck of the tube, when it rained, so I put a coffee jar lid over it.
  11. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Yes the Prius never had a spring cover/valve.
    yes Ford uses a kinda dumb capless thingy, i have noticed water in them and watched it go down when i inserted the gas pump.
  12. ETC(SS)
    7,134
  13. Roland1555
    282
    69
    Vancouver BC
  14. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I think because the cap is improved, you don't need that metal flap that exists in other cars.
    Notice how it says to tighten until you only hear 1 click and it sounds different. In other cars I was taught to tighten three clicks normally? I could be wrong though.
  15. adamace1
    1,403
    193
    Charlotte, NC
    Yea our car will only allow for one click. I know older gm's would keep clicking after it was tight.
