FOB battery replacement - how & when
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by john1701a, Mar 19, 2008.
  1. Eoin
    Eoin Active Member
    593
    116
    Long Island
    Thanks, Patrick. I'm assuming there will be no reprogramming issues.
  2. Crazytwoknobs
    Crazytwoknobs Junior Member
    Chicago
    Tips from having changed two just moments ago:
    1. The clip needs to be wiggled a little, so what I ended up doing on the second one was pushing it ALL the way open, wiggling everything I could with it open, letting it loose, and then the second time you move the latch, it's much easier.
    2. CR2032 batteries are the same as in your desktop computer's motherboard. It's the battery that keeps the clock going when the computer is unplugged, and keeps some other memory type things going. You CAN steal one from your computer, it'll just need one to start up next time (or if your'e REALLY REALLY REEEAAAALY cheap, a piece of metal/foil jammed in place of it). If you choose not to replace the battery, the clock and possibly some other functions might need to be re-set. Or you can order them online or hit up Harbor Freight, they can be found for ~$0.50 if you buy a bunch.
    3. Pushing on the opposite edge may help. Don't use a screwdriver, it'll slip and cut your finger.... blood everywhere...
    4. Make sure you're aware of the location of your Prius. You'll probably hit the panic button if your battery isn't dead. I had an "Oh, s*** that's me!" moment while doing the first battery replacement.
  3. jjforbes
    jjforbes New Member
    My fob is dead. I downloaded the Prius User guide. They are excellent photos, however you do not tell how to remove the protective door. I attempted to force a knife edge into the seam, but could not get it open. I will be grateful for any help. Thank you.
  4. Patrick Wong
    18,210
    6,513
    1. Remove the mechanical key by holding the little latch in the open position, then pull the key out of the fob.
    2. While holding the latch in the open position with a finger of one hand, slide the cover off with the thumb of your other hand.
  5. bisco
    52,375
    it can be stick if you have never opened it. my o4 took some 'persuasion'. no, i'm not talking hammer or pipe wrench.:eek:
  6. Tekdeus
    Tekdeus Shifted to Green
    151
    Vancouver
    ** Also, you must slide the cover off with your thumb on the Toyota emblem, NOT on the outer ridge. Do this, and it comes off really easily.
  7. jamesbalch
    jamesbalch Junior Member
    71
    Northeast
    This is a wonderful forum. I have been getting a short beep everytime I shut the prius down for the last few weeks. Today, it wouldn't start without putting the fob in the dash! I came to the conclusion the battery in the fob was out of juice.
    I came here today and easily found the procedure to remove and replace the fob batery. I was under the impression that once the battery came out, the fob had to be re-programmed by toyota. Glad to see I was mistaken!
    Thanks!
  8. Notbob
    Notbob New Member
    United States
    Thank you, Richard. You saved me time and headache.
  9. Nda3rdCar
    Nda3rdCar Junior Member
    92
    Here is a little how to YouTube:
    nh7o, Rokeby, sirons3 and 4 others like this.
  10. Nda3rdCar
    92
    This was the first time I replaced the battery. So, I used my camera to record it, hence the fumbling around at times... just as anyone would. It took less than four minutes. No programming issues, worked perfectly.
  11. richard schumacher
    7,665
    1,047
    United States
    Bravo sir! Beautifully done: language free and perfectly clear.
  12. Ozzyprv
    Ozzyprv New Member
    39
    Red Deer, AB - Canada
    Excellent post. It helped me a lot! Thanks.
  13. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    Interesting. The two fobs we have for our 2010 Prius II seem to be a different design than what Nda3rdCar posted in the video. On ours, I can open my 2010 fob using just the slide out mechanical key.
    1. Press the little side button to release the mech key.
    2. Look at the bottom edge of the fob near where you just pulled the mech key out from. Just to the bit over from where the mech key slide out is a little slot, exactly the size of the tip of the mech key.
    3. Stick the mech key tip into this slot and twist the key. The fob case should pop apart along the seams.
  14. fga1939
    fga1939 Junior Member
    Yorba Linda, CA
    Greetings,
    Since my FOB was very tight, I had to pry it open using a thin, wide blade, flat screw driver at the line between the cover and the body below the Toyota logo while pushing in the latch as far as it would go. Once open, I cleaned the surfaces with a Q tip, especially that of the latch cog sticking out. Then I put a very, very light smear of vasoline on the mating surfaces and latch cog and closed the FOB. After that, #2 in Patrick Wong's description was all it took to reopen the FOB. Thanks to all who contributed!
  15. sirons3
    sirons3 Junior Member
    Moreno Valley,CA
    Thanks for a great video. All the talk in the world did not teach as much as your 4 minute presentation. I had my case open a minute later after fumbling 20 minutes with no success.
  16. HybridAussie
    HybridAussie New Member
    2003 Prius
    Hi there, this is my first post. Really glad I found this site. Can anyone please advise where I can source a replacement inverter for my Gen 2 Prius & installation instructions as my ride is at a stand still without it?
    Chris
    Read more: INTERMITTENT ENGINE TROUBLE P0138 | PriusChat
  17. Jared
    Jared Member
    209
    Long Island
    Just did it. You don't really need a jeweler's screwdriver. I did it with the tip of a kitchen knife.
  18. Asim Jahangir
    Asim Jahangir Junior Member
    34
    Fellow Enthusiasts,
    I have prius 2007 of the Japanese make (140k miles). Yesterday, my keyless fob stopped working. I couldn't use it lock/unlock my car; however, it is starting the car just fine. I replaced the batteries on the fob but no avail. The small red light on the fob is shining like normal. There is no abnormal behavior in the car otherwise. Any tips on what should I check?
    thanks!
    Asim
  19. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    How old is the 12V battery? Symptoms of a failing 12V battery seem to vary a lot from car to car. On our Prius, fob trouble was the first symptom.
  20. Asim Jahangir
    34
    I disconnected the 12v battery terminals, checked for any rust or lead/acid accumulation (there was none), and re-connected. The FOB started working again. Not sure if I have solved the problem...
