How to turn on A/c without pressing the break?
Discussion in 'Gen 3 Prius Technical Discussion' started by osa, Mar 19, 2011.
  1. osa
    osa New Member
    AZ
    I tried to find an answer on the forum, but there is none. I guess everybody but me figured this one out.
    Before putting the kid in the car seat I like to turn on the a/c (in my previous car I would open the passenger side front door and turn the key). According to the manual, pushing the Start button twice will activate all the electrical. But no cold air is coming out in my Prius, just fan. Not till I depress the break.
    Really inconvenient as I live in a deserted AZ and going to the driver's side, pressing the break while holding the toddler by the hand and then going back to the passenger side seems to be the only way to avoid unnecessary discomfort for my kiddo.
    Is there any way I can start A/C without depressing the break?? Please help!
  2. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    No way.
    Prius has to be in READY mode to activate the A/C.
    Ken@Japan
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Ken, it's good to hear from you considering the recent events in Japan. Are you and your family OK? Did you suffer much damage from the earthquake or the tsunami in Yokohama?
    The situation in Japan is receiving a lot of coverage on the news here but most of the talk concerns the very hard hit regions along the Northeast coast.
  4. FLteacher
    FLteacher Junior Member
    75
    My FOB has a button to turn on the air before I enter, but I also have the solar roof. I wonder if this option (the air, not the solar roof) could be added on.
  5. tumbleweed
    4,067
    692
    Eastern Oregon
    Since you have the solar roof option you should already have remote air conditioning, according to the options list it is part of the solar roof package. I can't verify that because my car is not equipped with a solar roof option.
    According to the owner's manual (pages 285-287) the button on the fob should activate the air conditoning for 3 minutes if the other requirements are met.
  6. fotomoto
    fotomoto Senior Member
    5,637
    3,812
    So. Texas
    OSA, don't get too excited about the remote a/c option (even if you could somehow get it added on). The activation range is short PLUS it turns off the instant you open a door. The solar roof venting is more effective.
    I believe some have been able to add an aftermarket remote start which have a much greater range. If you leave the air con on, then it should activate.
  7. FLteacher
    75
    Thank you. Yes, you're right. I have it. I was just letting the OP know that it could probably be added on to his.
  8. qbee42
    3,079
    It's brake, not break -- part of my ongoing effort to correct this very common mistake.
    So what happened to all of the people?
    :D
  9. Mendel Leisk
    41,427
    Off somewhere eating dessert?
  10. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Correct me if I'm wrong but you cannot run the a/c on ANY vehicle if the ICE isn't running. Accessory mode in Prius is basically same as any other car. Compressor won't work in acc mode.
    I'd look into the remote starter option if you want to turn car on without hitting the brake.
  11. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    They are in the dessert eating desert. :p
  12. tumbleweed
    4,067
    692
    Eastern Oregon
    Give me a brake. :rolleyes:
  13. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    The AC compressor on the 2nd gen Prius and beyond is electrically driven. The ICE does NOT need to be running for the AC to run. But, still, the only options are the remote AC w/the solar roof option or being in READY mode. ACC doesn't cut it.
  14. dogfriend
    7,512
    1,190
    Carmichael, CA
    No. It is a safety feature. Pressing Power twice with your foot off the brake pedal puts the car into IG-On mode, which does not activate the A/C compressor (powered by the HV battery/inverter, not by the 12V battery system). You need to be in the Ready mode to connect the HV battery and power the A/C compressor.
  15. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Thanks cwerdna..I forgot the a/c works when in stealth mode (hence no ice on).
    Unlike Honda hybrid - correct?
  16. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    How is it a safety feature ?
  17. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    It is unsafe for the ICE to turn on when humans are not aware it is ON and those who are aware are not there to see risks. The remote A/C only runs for 3 minutes so not to run down the HV battery, as it cannot turn on the ICE ,for safety. Remote on is not a Toyota feature, but aftermarket, as Toyota does not want the liability.
  18. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    The OP already pressed the START button not once but twice. Isn't that a good enough indication that the car should start running ?
    Normal ICE vehicles will keep the engine running once the driver starts it, no difference here. What's the additional liability beyond what's already present for , say, Toyota Corolla drivers ?
    This START on/off button business is getting too complicated, almost Microsoft Windows like.
  19. tumbleweed
    4,067
    692
    Eastern Oregon
    The Power button must be pushed when the brake pedal is depressed to put the car into the Ready mode. Only when the car is in Ready can you drive it and only in Ready will the ICE run if need. If you push the Power button once without the brake pedal depressed it goes into the ACC mode, if you push Power twice without the brake depressed (which the OP was talking about) it goes into the ON mode which means it only has power from the 12V battery not the hybrid battery, so it really isn't on in ON. Very simple, actually more like Linux than Windows.
  20. dogfriend
    7,512
    1,190
    Carmichael, CA
    The brake pedal must be depressed to go into Ready mode, analogous to how the brake pedal must be depressed to shift from P to any gear in a conventional automatic transmission.
