Battery disconnect?
Discussion in 'Gen 2 Prius Main Forum' started by marlowe7, Apr 8, 2011.
  1. marlowe7
    marlowe7 Junior Member
    I realize this question has been asked and answered, but I'm still not getting it!
    I'm going out of town for 6+ weeks and want to disconnect the 12V battery (or, at least, do what's necessary to allow the car to start when I get back).
    Can anyone explain—in the SIMPLEST possible terms—how I can achieve this?
    I'm not car savvy, and don't know where the DOME fuse is.
    Thanks very much in advance for any help on this!!!
    I have a 2005 Prius.
  2. Patrick Wong
    18,200
    6,497
    You can find a fuse by referring to your owner's manual and locating the fuse box under the instrument panel as well as the main relay/fuse box next to the inverter.
    You can also disconnect the negative battery cable where it connects to the body, or disconnect the positive cable at the dedicated jumpstart terminal within the main relay/fuse box.
    Either cable disconnection assumes that you have a 10 mm metric socket and socket wrench available to you. The 12V battery is located in the right rear corner of the hatch and the main relay/fuse box is next to the inverter on the driver's side of the engine compartment.
    If you disconnect the battery cable in the hatch and then close the hatch, you'll have to crawl into the rear of the car, remove the folding hatch floor and locate the access point within the black plastic tray over the spare tire, and find the mechanical hatch release when you are ready to open the hatch again to reconnect the battery cable.
    dslomer64 likes this.
  3. Mendel Leisk
    40,923
    You could hook up a trickle charger, one that's capable of being left on indefinitely, ie: it'll monitor battery charge level and reduce charging to just a trickle. I use this one, it's very compact/portable:
    CTEK Multi US 3300 | CTEK Battery Chargers
    They're a little pricey (though they go on discount sale sometimes, Princess Auto in Canada, currently), and there are cheaper, similar products.
  4. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Open hatch.
    Remove the hatch floor and stow it somewhere.
    Remove the storage bin and stow it somewhere. Note you can put both of these items back before closing the hatch, you will just have to move them to get back in.
    Remove the small triangular floor piece on the right side as you face the hatch - the one just behind the tail-lamp.
    You can now see the 12V battery. The post closest to the tail-lamp is the -ve terminal, and it's best to remove this rather than the +ve terminal (it's safer). You can remove the connection to the body, or the connection to the battery. As Patrick suggests, probably better to remove the connection to the body. Less chance of damaging the battery. Be sure to insulate it in case it moves and connects to the body when you're gone. A rag wrapped around it will do.
    Now, if you close the hatch, you can't open it without the 12V supply (electric latch). You will also have to reprogram the radio stations and the auto down/up window. The window is easy. Once you have restored power when you get back, roll the window half way down, then back up and hold the up button for a second or two (I think it will beep when it's programmed).
    To restore the car to operational mode, you can use a "booster device" on the front boost terminal and then open the hatch, or you can crawl in and manually release the hatch (centre of hatch just under the hatch floor is a shiny lever) or just put the -ve terminal back on loosely and open the hatch from outside. Then you can finish by tightening the bolt, replacing the storage bin and floor pieces and the above "reprogramming".
    Not difficult or dangerous, especially now that you know what the implications are. Do try to avoid rapidly and repeatedly connecting and disconnecting the battery. That's not good for the electronics. Just one disconnect and later, one reconnect.
  5. marlowe7
    Thanks all for the detailed help!!
    I know it sounds simple to you guys, but I warned you... :)
    Couple questions:
    1. I understand I'll have to reprogram radio. What about NAV. Will I lose all of my memory points, etc.?
    2. David, in your instructions, will I also need tools?
    Thanks again!!!
    Also, I feel like I read somewhere about a danger the airbags deploying when disconnecting the 12V. Something about waiting a certain number of seconds before doing something. Did I imagine that or is there something I need to know?
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I didn't lose my nav memory points when I replaced my 12 volt battery. I intentionally didn't have any other battery or maintainer in between while the 12 volt was disconnected.
    See Patrick's post about the tools. I will trust his statement about the 10 mm socket since I don't remember what sizes I needed.
    2005with259k likes this.
  7. David Beale
    5,963
    1,987
    Edmonton Alberta
    Yes, you will just need a 10mm socket or wrench.
  8. marlowe7
    If I turn my SKS off, is it for sure the car will be dead in six weeks?
    My other option is to just leave it and know that AAA is going to have to jump it when I get back.
    Wondering if that's not such a bad option, given my poor mechanic skills.
  9. uart
    uart Senior Member
    4,220
    1,209
    Australia
    No. If the battery is in good condition then it's entirely possible that with the SKS off that the battery could survive ok. The other precautions are mainly taken just in case your battery is not so healthy.
    Jumping is an option but the biggest downside is that since the battery isn't rated for "deep cycle" operation it may deteriorate significantly after being run down too flat.
  10. Patrick Wong
    18,200
    6,497
    I would say there is a high likelihood that the battery will be dead, so your other option is to leave it and plan to spend $200+ for a new 12V battery upon your return. Assuming this is the original equipment battery, it would be OK to replace it after six years of service, anyway.
  11. David Beale
    5,963
    1,987
    Edmonton Alberta
    Do note that the SKS WILL turn off on its' own after a few days. Everyone seems to forget that.
    RTFM!
    Allowing the 12V battery to fully discharge is a "bad thing" (tm). It will damage the battery, shortening its' life.
  12. derh2o
    derh2o Junior Member
    34
    you could also remove the "dome" fuse in the fuse box. it is the top red 15 amp fuse. be aware, you will loose your radio and nav settings.
  13. marlowe7
    Can't believe that six weeks idle would potentially leave the battery unusable!
    On the other hand, I did purchase the 7 year warranty when I bought the car in '05. If the battery is unchargeable after 6 weeks, I'd think they'd have to give me a new one, gratis.
  14. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    You might find the PDFs at http://priuschat.com/forums/gen-ii-...prius-storage-time-limitation.html#post607660 interesting. (Thanks to Google!) It says "In order to store for 10 days or more..." "Disconnect wire harness from exclusive jump starting terminal (found in Junction Block under hood). (Prevent decreasing SOC during storage due to parasitic current drain.)"
    You should check your terms to ensure that it is actually covered for that 7 year warranty. Usually batteries are not covered for that length.
    Heck, on my 02 Nissan Maxima, the basic warranty was 3 years/36K miles but 12 volt battery was only covered for 1 year. For the point between 1 year and 3 years (IIRC), it was prorated. My 12 volt went bad around the 2 year mark but I didn't know if it was an electrical problem or bad battery. I ended up having to pay to get it diagnosed (turned out to the battery). The prorated battery cost and diagnosis was about the same as buying new one. :/
    If you're not going to disconnect the battery or pull the proper fuses and the car will be parked out in the sun, perhaps try to snag a VW solar charger? I posted about it at http://priuschat.com/forums/gen-ii-...isconnect-reconnect-cycles-2.html#post1298659. I finally was able to get one for free. Looking at the part and its size, it looks worth more than $5 to me. That combined w/turning SKS off might keep the battery in ok enough shape. Get one w/the OBD2 connector not the cigarette lighter version (which would be useless since the outlets are disconnected/power off when the car is off).
    BTW, if you're still on the original 12 volt, it's probably on its last legs anyway.
  15. marlowe7
    Okay, in spite of my whining, I did it. I disconnected the battery's negative wire from the body.
    However, I was no finding the interior latch which would allow me to open the hatch from the inside.
    Where is it, again?? I didn't seen anything shiny. Is it through that small opening in the back wall of the plastic cargo container? If so, what trips the latch?
  16. Patrick Wong
    18,200
    6,497
    Good for you, congratulations.
    Yes, you would open the little rectangular access panel at the rear of the black plastic liner which sits over the spare tire. Then look for a small shiny lever located near the latch mechanism. To open the hatch, you would need to move that lever (which will unlock the latch) and then apply upwards force on the hatch to open.
  17. richard schumacher
    7,664
    1,045
    United States
    Betcha a nickel that extended warranty doesn't cover the 12V battery, along with many other things.
  18. 2005with259k
    2005with259k Junior Member
    22
    Michigan
    FYI anyone reading this it is 10mm socket and it is hard to reach a few of them. Please make sure you have a long enough extension adapter and a deep 10mm if removing the battery completely. I ended up just bending the bracket holding the 12v down being careful not to put too much pressure on the black brake box thing next to the battery because I didn’t have a long enough wrench extender. I know I am really late to this, but thought I could help with my experience I had today. The screws on that black brake box were impossibly tight. I could not remove them all.
