Question on disconnecting 12v battery
Discussion in 'Gen 3 Prius Technical Discussion' started by Scott near L.A., Aug 20, 2012.
  1. Scott near L.A.
    Scott near L.A. New Member
    I stopped into the Toyota service buy to get advice on disconnecting the battery prior to storage of our 2012 Gen III. I was told I could safely disconnect just the positive terminal by the service person (not a technician, but the guy who schedules the service). Is this true? Hopefully it is, because the positive terminal is easy to get to and I have the correct wrench. The negative terminal is jammed up against the back and is a different nut (which is extremely difficult to get a tool around. Thanks in advance for the info.
  2. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    You may disconnect just the positive terminal. Put it in a small plastic bag so it doesn't accidentally reconnect when you let go of it.
    If you do disconnect the positive terminal, be aware, any mistake wherein you touch part of the car body with your tools will result in vigorous sparking and possible damage to the battery or the electronics. This is why it is recommended the -first- battery lead to be disconnected should always be the negative terminal. Any mistake there results in nothing happening. Once it is disconnected you can short the positive terminal to the car body without harming anything.
  3. Scott near L.A.
  4. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    I can't remember what I did exactly, but I had the negative terminal turned around so the nut is easily accessible.
  5. paxam
    paxam Junior Member
    17
    Fort Lauderdale
    when you disconnect it you will lose all presets on the radio and map info. I done it a few times already.
    remember to remove rings watches etc in case you touch ground..
  6. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    My presets and map settings never reset everytime i disconnect the battery. Just the display settings.
  7. Mendel Leisk
    42,343
    I've always heard you disconnect the negative lead first, then the positive. While I don't undertand the logic, my understanding is that what your service writer advised is actually dangerous. I do know the battery's negative lead connects to the car body, that the car body acts as part of the circuit, that's about it.
    BTW: how long is the storage period?
    What I did when the our car was sitting for just a couple of weeks was leave the 12 volt connected and hooked up a lowish amperage "intelligent" charger.
  8. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Disconnecting the negative lead at the point where it connects to the body not the battery is easy and safer and as stated above put the end in a plastic bag or put some tape round it to stop it touching any bodywork.
  9. David Beale
    5,963
    1,990
    Edmonton Alberta
    I would normally agree but it states in the manual not to do this, as the lead is long enough to reach the positive terminal, which would be a bad thing, I guess. ;)
  10. Britprius
    5,194
    1,922
    Not if it's in a plastic bag.
  11. naks7
    naks7 Junior Member
    Hawaii
    Do you know if it will reset the reverse beeping in a 2012? I had the dealer disable the beeping to just one beep when in reverse. Will I have to go back to the dealer to get it changed again? Thanks
  12. David Beale
    5,963
    1,990
    Edmonton Alberta
    Yes, it will reset everything to default.
  13. walter Lee
    1,126
    376
    Maryland
    Does the electronic rear hatch lock still work if the 12vdc aux battery is disconnected? :cautious:
    If not how does one open the rear hatch door to get access to the aux battery so as to reconnect it? o_O
    Is there some manual latch or old-fashion key lock I can use? :coffee:
  14. David Beale
    5,963
    1,990
    Edmonton Alberta
    No, the latch won't work. It must be released from -inside- the car.
    Remove hatch floor. You will see a shiny lever (small) right under the hatch latch.
    Actuate that manually to open the hatch door.
    walter Lee likes this.
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    The neg is removed first because if the wrench your using to remove the negative terminal should touch the body by mistake there will be NO sparks as the ground lead already touches the body. But if you remove the pos first with a wrench and your wrench touches the body guess what happens.
    BUT.....I do not own a III i own a II and on the II disconnecting the neg lead to isolate the battery is not necessary. There's a little cover on the pos terminal that pops right off and under that cover there are click in connectors for the pos leads. One large connector and one small. These connectors are easily clicked and removed. Battery unplugged!! No wrenching necessary. No tools needed. I bet the Gen III is just like that too.
    rogerdpack likes this.
