High Pitch Squeak/Whistle while accelerating and braking
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sufyant, Jun 16, 2011.
  1. sufyant
    sufyant Junior Member
    39
    2024 Prius Prime
    XSE Premium
    My 2007 Prius Touring creates high pitch Squeak/Whistle sound while accelerating and braking, But if I put the car on neutral then the sound completely goes away. I have all the holes covered on the both side mirrors and this still occurs. The sound is constant for as long as I accelerate and Brake and the intensity varies with how hard I accelerate or brake, It also does that during regen braking when I leave the accelerator. Anyone have any idea what could be wrong? Thanks.
  2. qbee42
    3,081
    I suspect your problem is good hearing. Your Prius uses an inverter to drive the electric motors, and the high frequency drive pulses can be heard by anyone with good hearing. It sounds like a high pitched whine, and is most pronounced while accelerating and braking.
  3. sufyant
    39
    2024 Prius Prime
    XSE Premium
    It might be true but I had a 2005 prius before this and it never made this sound, would the inverter be different for both in terms of sounds they create?
  4. Patrick Wong
    18,210
    6,517
  5. sufyant
    39
    2024 Prius Prime
    XSE Premium
    Sorry about that I wanted to delete the first thread but couldn't find a way. Investigating this further when I put the car in parking mode and give acceleration and when I release acceleration it makes the same squeak/whistle. Is it still the inverter or something else? Does the inverter still work in parking mode?
  6. Patrick Wong
    18,210
    6,517
    The inverter is functioning whenever the Prius is READY. Perhaps you can have someone rev up the engine while the car is parked, so that you can stand by the engine compartment and listen around to see whether the sound is coming from the inverter or elsewhere.
  7. sufyant
    39
    2024 Prius Prime
    XSE Premium
    Thanks everyone. It was the inverter making those sounds so Toyota replaced it under warranty and the sound is now gone or at least I don't hear it anymore :). So I think for some reason it was a lot louder than it should have been and now its been suppressed.
    2 people like this.
  8. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Good to know! Thanks for the update. :)
  9. pipaluk
    pipaluk New Member
    Norfolk
    Our Prius - which we love dearly - sometimes emits a high pitched whistle, a sound very much like the one when you are sharpening an ax on a grindstone. There seems to be no rhyme or reason to it: it can happen in town (ie at low speeds) or on the motorway, when accelerating, or when slowing but NEVER when standing still. Our Toyota dealer has checked it out (without taking it out on the road) but says there's nothing wrong. Hope they're right as we're about to drive some 3,000 miles on holiday and and ear-piercing whistle for all - or any part of that - would be craze-making.
  10. pipaluk
    pipaluk New Member
    Norfolk
    Our Prius - which we love dearly - sometimes emits a high pitched whistle, a sound very much like the one when you are sharpening an ax on a grindstone or astone caught in the brakes. There seems to be no rhyme or reason to it: it can happen in town (ie at low speeds) or on the motorway, when accelerating, or when slowing but NEVER when standing still. Our Toyota dealer has checked it out (without taking it out on the road) but says there's nothing wrong. Hope they're right as we're about to drive some 3,000 miles on holiday and and ear-piercing whistle for all - or any part of that - would be craze-making.
  11. northwichita
    481
    102
    29
    Wichita KS
    Take it back to the dealer and have them drive it on the road. If the sound happens more often when warmed up, drive the car some before the visit. As the inverter is a likely cause, have the technician load the system with running the A/C and headlights. Be persistent , perhaps ride along during the test drive.
    I wouldn't drive the car making a noise like that on a long trip, its not just annoying, its risky in my opinion..
  12. Joseph Wilde-Ramsing
    Hi sufyant,
    I think I am having the same problem, but unfortunately my Prius is not under warranty any more. Did you get an idea of how serious the problem is for the overall performance of the car? Is it dangerous to drive? Thanks.
    Joseph
  13. sufyant
    39
    2024 Prius Prime
    XSE Premium
    I dont think there are any performance issues or any danger for me the only issue was it was very annoying because I could hear it loudly and clearly so I assume it had to do something with sound insulation but after they replaced my inverter the sound was gone.
  14. Joseph Wilde-Ramsing
    ok, thanks. any idea how much it would have cost you to replace the inverter if yours hadn't been under warranty?
  15. sufyant
    39
    2024 Prius Prime
    XSE Premium
    I believe they said somewhere around $4000
  16. Philliplewis590
    Philliplewis590 New Member
    Oakland
    I'm hearing something similar in my 2010 prius. What about an inverter flush? Would that work or does the whole thing have to be replaced?
  17. dolj
    dolj Senior Member
    8,645
    4,396
    Wellington, New Zealand
    Might be an idea to ask your question in a Gen 3 forum. What appears to be the same, may be not applicable across generations.
