Baby did a bad, bad thing when washing his car.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Skoorbmax, Mar 4, 2011.
  1. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    OK, here is a scratch I did not do! Wife said it was there from when something hit the car. Here is before and after and I clay barred it after so there is absolutely no haze/material left in the scratch to the right. This stuff really seems like the real deal. Thanks for the advice! You really cannot see this now unless you're looking for it and bending around from crazy angles with the light just so and even then maybe not.
  2. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Okay...
    Please...listen to me. I've been detailing cars for 15 years...I'm very experienced and know what I am doing. Scratch-X is an abrasive polish...it does precisely what you are describing, the goal is to round off the edges of the scratches so that they don't reflect light in the same way, and hence become invisible. If you have hazing or dulling where you've used the Scratch-X, then you have not worked the product down enough or allowed the abrasives to diminish properly.
    First of all, always buff parallel to the scratch, not perpendicular. You also don't want to use too much, you need to polish with the product until it diminishes completely beneath your towel, otherwise you will get that hazing you described.
    I would recommend a cotton terry cloth towel for working the scratch-X in, and a good quality microfiber towel for buffing any residue off.
    Bear in mind that the areas you use the polish on will need to be waxed again. I personally would (and do) work the polish into the areas of concern and then follow up by putting a coat of wax on the whole vehicle. Never wipe in a circular motion that creates swirls, always in straight lines.
    You can probably achieve what you want with the Scratch-X, but if you don't use it properly then you can make the situation a lot worse...you can't really do anything that will permanently damage the paint without a machine...but you can create hazing and areas of more headache for yourself.
  3. Skoorbmax
    2,641
    265
    Western NY
    Thanks, Steve.
    Why is it that I should work parallel and not perpendicular?
    Also, if I work it and buff it until it's 100% removed, is the end result any better than just constantly applying more of it and then, when I'm finished, I have a bunch of excess stuff and I just wash it/clay bar it away...?
    I'm still surprised that $9 and some time can get results like this.
  4. SW03ES
    2,480
    176
    Gaithersburg, MD
    Because working parallel will even the edge out smoothly as opposed to chopping it up which can leave a wave or distortion behind.
    The end result will be much better if you work it until its broken down. These products use diminishing abrasives. Think about sandpaper, you use finer and finer cuts of sandpaper as you finish a piece of wood to get that nice smooth finish. If you stop after the heavy grit paper it will be rough. These polishes break down as you work them in so that the abrasives are finer and finer, refining the finish until they are gone. When you just add more and wash/clay the excess away you never get to those finer abrasives and the result is not as smooth as it could be.
    One thing to keep in mind is that a lot of these consumer products including Scratch X do have some glazes and fillers. So over time, those will wash away and the scratch may seem to "come back". Toyota paint is pretty soft making these spot polishes pretty effective, but on cars with harder paint you really would need a machine.
  5. Skoorbmax
    2,641
    265
    Western NY
    Thanks :) I think i read a thread elsewhere--some of us were wondering about the paint quality on our cars. Certainly not to blame here, though, that was all me.
    I know from personal experience what Mr Clean magic eraser does to car paint. Not on this vehicle, thankfully :)
  6. SW03ES
    2,480
    176
    Gaithersburg, MD
    Its not a poor quality paint, its just soft. The bad thing about soft paint is it scratches easily...the good thing is its easy to correct.
  7. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    I had a similar experience with Zaino Z-PC Fusion. It's a great paint cleanser, but sucks as a finishing polish and will leave behind a haze no matter how long you've worked the product down (at least by hand). It has no filler so the hazing gets pretty bad. Zaino says to apply Z2 or Z5 over it to make the hazing/dulling go away, but this doesn't do jack squat (and unfortunately Zaino doesn't have a suitable product that falls between Z-PC Fusion and Z-AIO). I went out and bought a better finishing polish and it took the hazing right out.
    Another product (albeit weaker) that you might want to try first instead of Scratch-X or Z-PC Fusion is NuFinish Scratch Doctor, which I've found doesn't induce hazing. If that fails then you can move to Scratch-X or Z-PC Fusion and finish with a better polish.
  8. Skoorbmax
    2,641
    265
    Western NY
    I did look at Quizz and it's well rated but the little strips of sand paper scared the @*#( out of me. Seemed like if done wrong I could mess it up, and since I scratched it washing the car I know where my skill set on detailing lies.
  9. SW03ES
    2,480
    176
    Gaithersburg, MD
    Yeah sanding is a pro-only process IMHO...
  10. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    If you want to clean it up a little more after the Scratch X, you can try some Mequiars Ultimate Compound. It's pretty light duty and you shouldn't damage anything with it. That should remove any haziness from the scratchX use. Then follow with a good sealant or polish, as SW03 mentioned.
    The only problem is, you'll have that one really nice area and the rest of the car will be 'hazier'. :D
    REV
  11. SW03ES
    2,480
    176
    Gaithersburg, MD
    If he works the ScratchX in until the abrasives break down he shouldn't have any hazing...
  12. Skoorbmax
    2,641
    265
    Western NY
    Update. I've been toying with Scratch X 2.0 more on this car and another one I have with dark paint.
    Overall I think $9 for this stuff is an amazing purchase. I found that many of the scratches on my Prius are deep enough that the scratch x cannot solve them. As such I've figured out a technique of sponging in touch up paint along the entire length of the scratch and then using scratch x to buff the new paint away from the sides of the scratch such that only the scratch has the paint. Seems to have worked extremely well. Scratch is certainly still visible but any white background is gone and it reduces the view-able distance of the scratch greatly.
    On lighter, more subtle scratches, one application of this stuff works wonders. If the scratch is light enough it can literally be completely removed. Even if it's a touch deeper it can be substantially reduced.
  13. Crazyhorse6901
    Crazyhorse6901 New Member
    114
    Hampton,VA
  14. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    I accidentally put some swirls into my hood while trying to clean-up the area around my paint touch-up.
    An LC orange pad with Meguiars M105 with a Flex 3401XRG and several passes cleaned it up. A few more passes with a LC white pad and Meguiars M205 made it look perfect again.
    As others have said, the paint on this car is on the softer side. I have the exact same color as you. And luckily, it is very easy to correct with the proper tools, pads and polish.
  15. therover1991
    therover1991 Junior Member
    New York, NY
    Have you tried the Microfiber Paint Correction Kit?
  16. The Critic
    3,193
    2,330
    CA
    I would if I could find someone to buy the Flex and LC pads from me.
    MB860 ?
