Turn signals are now parking lights / DRL's - parking lights are turn signals (MB/Audi style)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by SDM44, Jun 20, 2011.
  1. SDM44
    SDM44 Señor Member
    199
    Los Angeles
    After doing the front side marker lights mod awhile back, I was thinking about something different to do that would make my car stand out from the many other Prius' I see on a daily basis in the LA area. I had an idea of what I wanted to do, but I was waiting for the right bulbs to become available before I messed around with it.
    The LED lights on the new Mercedes and Audi cars have kind of grown on me, and they are really noticeable in traffic so you see the cars pretty easily. I didn't want to do the same LED strip thing with some cheezy light strip that you can buy from Ebay, so instead I made my bumper turn signals into the parking lights using some very bright projector LEDs (which can be used as DRL's if I turn on my parking lights), and the parking lights in the headlight housing are now my turn signal blinkers. I opted for this because awhile back I tried putting 64 SMD LED bulbs into the foglight housing and I didn't like the output or the way the housing made the color look. Plus these projector LEDs were much brighter than the standard 7440 SMD LED bulbs that you can buy, as they were actually more dim looking.
    The wiring took maybe 30 minutes to do, but then it took me another 20 minutes figuring out how to change the turn signal relay underneath the dash (19 minutes figuring out how to get my hand up underneath the dash.... once I got it up there after removing one bolt, it took less than a minute to swap out the relay, and in the end it was actually pretty easy to do).
    Below are some pics and videos.
    I found a place locally that made a projector style LED. After the pics and videos I saw of it, I figured this should work well. And they are extremely bright and are very visible under the direct sunlight during the day (I'll get daytime pictures of that later this week). Even though they project forward, the light still reflects in the housing so the output is good on the Prius.
    For now, I'm just using a chrome 194 amber bulb in the headlight housing. I have some 5-way and 9-way amber LED 194 bulbs coming in later this week so I'll swap those out. The bulbs are easily visible at night and when it's overcast, but it's hard to see under the direct sunlight. This is the only drawback so far, but I'm hoping the brighter LED bulbs I have on order will fix this. If not, then I have one other thing I'll try out, but it'll take some thinking on how to make it work.
    After wiring everything up, here's what it looks like with my parking lights on.
    Here's how the LED parking lights look with the headlights on. The color of the factory LED headlights actually match pretty much perfectly with the LED's in the bumper turn signal housing. When I tried similar LED bulbs in the foglight housing awhile back, they were more blue looking and did not go well with the headlights.
    Here are a couple of pics with the HID foglights on (I never turn these on unless the weather or conditions really call for it), just to give you an idea of how it looks with that much lighting up front.... still legal in CA, as you're allowed to have 6 lights on up front at once (3 on each side).
    Here are a couple of videos showing the LED parking lights by themselves, and with the headlights on. I'll take some videos during the day when I have some time later this week.
    Final thoughts... I like the look since it now stands out from other Prius cars on the road, and also the LED's work well as a DRL while driving during the day or at dusk. The turn signals facing the front do need to be brighter, and I'm working on some things for that. You also need the CF18-08 flasher relay or your blinkers will be fast, even if you're using halogen bulbs. But once you put the relay in, you can then switch everything out to LED bulbs.
    I can easily switch everything back to how it was before, but I figure I'll drive around this way for awhile to see how it works out for me.
  2. robby3
    robby3 Member
    181
    24
    Switzerland
    I Like the idea and in night the lower ones really look bright. But I do have some concerns with the visibility during daylight as well. In Europe, the law is that the DRL must be switched off or dimmed when the headlights are on. So the nightshots do not tell much about how they look in sunlight. Therefore do some daylight camera and video shots say 50 meters away so see how well visible it is now with the parking lights.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Could you give us more info on the projector LEDs?
    Careful with the LED bulbs you use for the parking lights. I used one that started discoloring / melt the headlight housing above the bulb (I assume from the heat).
  4. SDM44
    SDM44 Señor Member
    199
    Los Angeles
    My goal is to wire up a couple of relays that I have, and have it so the parking lights turn off when it see's a signal from the headlights being turned on. I didn't have time last night to do this, but I'll probably mess around with it later this week. I just need to figure out a good 12V switched signal coming from the headlight harness to tap into.
    I'll take some pictures during the day when I have some time this week. But when I looked at it this morning under the sun and stood back a good 100 ft, they still looked very bright at all angles (except directly to the side of the car).
    I picked up these Super Bright HID LED bulbs from this seller. There's really nothing HID about them, but they are super bright and illuminate better than a 30 SMD LED bulb in the turn signal housing.
  5. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Looks awesome!
  6. waiwaiet
    waiwaiet New Member
    47
    Rogers, AR
    Hey SMD neat mod! I am getting really to do this mod, I want to see have you try putting a 9 way led into the top DRL (above headlight, now turn signal) or not. Does that fit a 9 way? or only 5 way?
    Also, one question.....I already have switched the turn signal relay (because I am using LED bulb for turn signals now. So the only thing I need to do it's to switch the two power cable between the turn signals and the DRL, right?
    Thank you so much!
  7. Tideland Prius
    16,670
    Nice. Is it possible that someone could use an amber one instead and just have it stay on as DRLs and blink for the indicators?
    Also, would those same bulbs work as reverse lights?
  8. waiwaiet
    waiwaiet New Member
    47
    Rogers, AR
    SDM44, I want to see if you Installed the 5 way and 9 way led in your housing or not, how does it fit?
  9. SDM44
    SDM44 Señor Member
    199
    Los Angeles
    I picked up 5-way, 9-way, and 25-way amber 194 LEDs to try out in the headlight housing.
    I didn't even bother with the 5-way because they were not bright enough. 9-way LEDs fit just fine and clear the headlight glass just fine. They're right, but not bright under direct sunlight... they work fine at night.
    The 25-way LEDs were much brighter but the top LED touches the headlight glass. I actually just used those because you can see them in direct sunlight, even with the top LED touching the glass. I didn't harm anything and I even tested them by letting the blinkers flash for 12 minutes straight, and the glass was not hot or discolored at all (I wouldn't plan on using my blinkers for that long anyways).
  10. SDM44
    SDM44 Señor Member
    199
    Los Angeles
    Yes, you can easily use amber LEDs or just regular orange 7440 halogen bulbs that come stock on our cars. I just chose to use a LED that matched my headlights. But using the orange 7440 halogen bulbs would've been much brighter and the light would've filled the entire housing.... a really good DRL.
    And yes, the backup bulbs are the same 7440 bulbs as the turn signals (front & back). I actually tried out the projector LEDs and they are extremely bright as the backup lights. With the rear camera at night, I can really see a good distance behind me.
  11. Tideland Prius
    16,670
    Would the wiring be much different? I would think just keep the stock setting (i.e. as indicators) and somehow just wired them up to come on when the car is on to act as DRLs.
  12. waiwaiet
    waiwaiet New Member
    47
    Rogers, AR
    SDM44, i m assuming you put the 25led in the slot above headlight(not side parking), right? can you post the link on the 25-way LED you bought? Any picture or video on how bright it is?
  13. waiwaiet
    waiwaiet New Member
    47
    Rogers, AR
    Btw what bulb you use for side parking?
  14. SDM44
    SDM44 Señor Member
    199
    Los Angeles
    I put the 25-way LED in the top of the headlight housing (which is normally a parking light, but is now a turn signal). It looks like this:
    [​IMG][​IMG]
    The 9-way LEDs I also have look like these:
    [​IMG][​IMG]
    You can see the top LED on the 25-way is small, so it doesn't produce much heat that would affect the headlight glass. But the sides to illuminate a lot more and the light reflects better in the housing.
    I didn't change the bulbs in the side parking sockets (I assume you're talking about the bulbs behind the amber reflector in the headlight housing). I left the clear 194 halogen bulbs in there and just disabled them when the headlights are on, and they blink with the turn signals HERE.
    Dr Reid likes this.
  15. SDM44
    SDM44 Señor Member
    199
    Los Angeles
    I know of 2 ways to accomplish this......
    1) Wire up 2 SPST relays to make this work. We did this years ago with Honda bumper lights that used single filament bulbs & 2-wire sockets. The turn signal bumper light would stay on with your parking/head lights, but would flash to the 'off' position when it received a signal from the turn signals... and flashed normally without going fast (back then, no LED bulbs were available).
    2) Find a dual filament 3-wire socket that will fit into the turn signal housing (may need to modify the tabs) and then use a dual filament 1157 bulb since those are very common & cheap. The low filament will stay lit when your parking/head lights are on. When you activate the turn signal, it will light up the 2nd filament and will be much brighter and flash normally.
    Both ways would require some wiring to do. The 2nd option would require some more work locating a socket that would work and modify the tabs if needed, but has much less wiring is involved.
  16. Tideland Prius
    16,670
    Sounds like it's out of league lol. Thanks!
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    WebElectric Products - Sequential Turn Signals, Sequential Taillights, Sequential Tail Lights, Dynamite Stick Sequential, Pulsing Brake Light Pulser Flasher, One Touch Convertible Top, Dynamite Stick, One Touch Turn Signals, Daytime Running Lights, L
    sells modules that will run your front turn signal bulbs as DRLs. They have a unit for GenII Prii and someplace on their site they mention the possibility of using one of their units on a GEN III. You would need to be able to find the right wires to hook it up, probably not too big a job for someone with a schematic and a probe who know a little about automotive electrics. I installed one on my 1996 Corvette that wasn't intended for that car and it wasn't very difficult with wiring schematic and voltmeter in hand.
    Don't use your parking lights as DRLs the bulbs are too dim to be effective. The turn signal filaments (often in the same bulb) do make good DRLs. Late model Corvettes (Since 1997?) have used the turn signal bulbs as DRLs. The orange lights really stand out in a sea of no lights or white DRLs.
  18. Tideland Prius
    16,670
    I have DRLs (they're required in Canada). They're reduced intensity high beams. It would be nice if I could have the DRLs as LEDs, that's all.
  19. waiwaiet
    waiwaiet New Member
    47
    Rogers, AR
    SDM44, HELP PLEASE!!!! I did the mod today, while we are doing that we test each side before you put the whole thing back together.....then I tried the hazard light, and it seems to skip a few beat....I already changed the flasher relay.....and something it even not blink at all!!! do you kno what happened?? i pulled the fuse and put it in again and it works again......help please.....it seems like it works for normal right or left signal for now....i m just scare it will die all a sudden....do you know what cause that?
    I shot a video and posted on youtube, here it is:
  20. waiwaiet
    waiwaiet New Member
    47
    Rogers, AR
    Update, now no turn signal is working....no tick tick tick at all......last night the left and right signals were still fine....any suggestion where the problem is? Fuse? Wiring?
