Does a 2001 Prius need to be warmed up b4 freeway driving?
Discussion in 'Newbie Forum' started by ragnarkar, Oct 17, 2011.
  1. ragnarkar
    ragnarkar Junior Member
    Pasadena, CA
    2001 Prius
    Since I live literally next to the freeway, would it be a problem if I accelerated to 65 on a cold engine right from the start? Keep in mind this is an older Prius and my apartment exit is adjacent to the nearest freeway onramp.
  2. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Will it do it? Yes.
    Is it bad for longevity of the engine and the battery compared to a gentle warmup? Yes.
    I would say give it at least the ~50 seconds to leave stage 1 before going up the ramp. If you do that as habit, but occasionally go straight up the ramp if you are in a hurry, it's not going to make much difference.
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If it's at all practical, drive to the next on-ramp before entering the freeway. A few extra minutes warmup while driving gently will help your engine life.
  4. john1701a
    john1701a Prius Guru
    12,801
    5,284
    57
    Living in southern CA, your definition of "cold" is a complete non-issue.
    I live in MN, where it gets drastically colder... and never had any trouble, despite also living next to a highway. Even when seeing this:
  5. Flaninacupboard
    1,297
    213
    Midlands - UK
    I just had to look up what -13F was in C, -25! that is cold!!
  6. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i know i own a genII... and this is for a genI...
    i tow with my genII... to the point that if it's warm out or if i'm going N instead of S with a small incline it will partly drain the battery since the car uses mainly electricity to run during stage 1. as Flaninacupboard said... a warmup isn't all the bad. any time i do a warmup on my genII... my gas mileage is more predictable and i always have a more stable battery when i do a warmup. yes.. it may pollute more sitting there for warmup... but a person smoking a cigarette (possibly me) probably does more damage to the earth than a simple warmup (gross comparison... but really.. it doesn't seem all that bad to do a warmup)
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    They were having a heat wave.
  8. jhknight
    jhknight Junior Member
    74
    south central Minnesota
    2002 Prius
    I have a 2002 Prius and I also wonder what you consider "cold" in CA being in MN. I have driven the 2002 in -25F weather and there is a blue light that corresponds to a cold hybrid battery and I believe that while that blue light is on you're supposed to take it somewhat easy? I also saw the neffarious "turtle" light one cold morning - but only once- which ironically appeared after a full hour warm-up on one of those sub-arctic mornings which is supposed to indicate a battery that is overheated ?? and you are supposed to drive under 30 mph until the turtle goes away.
