Best wax or polish for 2011 Blizzard Pearl? ...and washing tips
Discussion in 'Gen 3 Prius Main Forum' started by BayAreaPrius11, Dec 21, 2011.
  1. BayAreaPrius11
    BayAreaPrius11 New Member
    17
    SF Bay Area
    Ive had the car for three weeks and I need to wash the car for the first time. Dealer said there is a product called "Auto Butler" on the car right now.
    Should I use Dial to wash the first time?
    Should I use a clay bar right away?
    What are the best brands of car washing solution to use?
    Should I wax or polish this color? > Which wax or polish should I use? Are there any I need to stay away from?
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    There's a care & maintenance sub-forum loaded with stuff like this. Try a search there.
  3. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    * If you're in a pinch, maybe have Toyota detail it again for you until you get your supplies together. Just a thought. The dealers have good detailers.
    http://priuschat.com/forums/prius-v...ng-waxing-tips-pics-your-prius-long-read.html
  4. BayAreaPrius11
    17
    SF Bay Area
    I was referring to a dishwashing soap for the first wash as I heard that its good for removing anything the dealer puts on the car. I think it was on the zaino website that mentioned this.
    Are there some waxes that will mess up the rubber/plastic parts of the exterior(turn them white) and others that wont?
    Thanks!
  5. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    If you have never used P21S wax, I highly recommend it. The nice thing about it is that you don't let it dry.....you wipe off while it is still moist....it's a little pricey (try amazon)but well worth it.
