2007 Prius 10 year or 150,000 mile hybrid battery warranty (whichever comes first)
Discussion in 'Gen 2 Prius Main Forum' started by Prius07Pkg4, Dec 15, 2006.
  1. Prius07Pkg4
    Prius07Pkg4 New Member
    Is that true? 2007 Prius 10 year or 150,000 mile hybrid battery warranty (whichever comes first)!
    When I bought the 2007 Prius, Dealer told me 8 years battery warranty, I don't remember how many mileage.
    Now I see the advertise below:
    http://www.buyatoyota.com/specials/special...?specialId=6817
  2. bugmenot
    bugmenot New Member
    93
    I asked the dealer and was told the same: 8 year, 100k mile hybrid battery warranty.
    My emails went unanswered after purchase (to be expected).
    Where did you buy? Will these extra years and miles apply to us?
  3. ceric
    ceric New Member
    1,114
    Fremont, CA
    The HV battery is warranted for 10yr/150K miles in CA and states that adopt similar emission standard.
    Read the following copied out from Toyota eBrochure for CA.
    Basic: 36 months/36,000 miles (all components other than normal wear and maintenance items).
    Hybrid-Related Component Coverage: Hybrid-related components, including the HV battery, battery control module, hybrid control module and
    inverter with converter, are covered for 8 years/100,000 miles. The HV battery may have longer coverage under emissions warranty. Refer to
    applicable Owner's Warranty Information booklet for details.
    California Emission Control Coverage: In California and any other state that adopts California emission warranty provisions, defect and performance
    warranty is 15 years/150,000 miles. The Hybrid Vehicle Battery is warranted for 10 years/150,000 miles.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Ceric is correct. To the OP, you'll see that the warranty booklet that came w/your car confirms this.
  5. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    619
    26
    <div class='quotetop'>QUOTE(Prius07Pkg4 @ Dec 14 2006, 10:03 PM) [snapback]362644[/snapback]</div>
    Your dealer (salesman) was an idiot.
  6. Prius07Pkg4
    <div class='quotetop'>QUOTE(mcbrunnhilde @ Dec 15 2006, 11:31 AM) [snapback]362880[/snapback]</div>
    Thanks for speak out lound!! :D :D :D
  7. Payin for it
    Payin for it Junior Member
    Santa Monica
    2001 Prius
    2001 Battery Warranty for Original Owner Only?
    anybody here have any info if 01 still has warranty on hybrid battery even if you aren't orig owner? I'm 3rd owner to a '01 and am told by MDR, CA dealer that I don't have a hybrid battery warranty. Seeing various threads here makes me wonder if that's true. I just brought it in for $800 worth of sensor cleaning, air filter and master sensor replacement and new computer key, and now told I need a new $3700 battery too! An additional $400+ will come later when I'm told I'll need to replace a cable attaching my horn to the steering column which was once a recall. I'm not having a good month$!
  8. thedutchtouch
    thedutchtouch prius is my SUV
    181
    Baltimore MD
    Re: 2001 Battery Warranty for Original Owner Only?
    if you do indeed need a new traction battery, i've seen a few on ebay in the 400-800 dollar range, usually used, but still a cheap, gently used battery is better than a 3700k new one. check ebaymotors. ie, search ebaymotors for "prius battery, i got 10 results, some rediculously expensive. (i'm not sure if your car and the 06 have the same battery) but here's one for 650 eBay Motors: Toyota Prius Hybrid Battery Complete Main Battery (item 170297778223 end time Feb-25-09 20:08:54 PST)
    alternatively if there's a way to test individual cells, you can buy those for 50 dollars on ebaymotors.
  9. GatorJoe
    GatorJoe New Member
    56
    i have found most toyota salesmen don't know crap about priuses. the last time i went to the dealer (a couple months ago) no one knew about the 2010 being a different body style or anything about it. i guess maybe since they sell themselves so much most salesmen dont bother learning how to sell them.
  10. Patrick Wong
    18,210
    6,512
    Classic Prius (2001 - 2003 model years) have an 8 year/100K mile warranty on the traction battery.
    A salvage battery is a reasonable alternative; however the 2G battery (w/ 28 modules) is not the same as the Classic battery (w/ 38 modules.) So you'll need to look for a battery from a 2001-2003 vehicle, and you'll find that the pricing is generally much higher than for 2G - while the Classic salvage batteries are much older and have more miles logged.
    Another possibility (for the advanced DIYer who can deal with high voltage) is to buy two 2G batteries (for ~$800-$1,000 total) which will yield 56 modules. Remove 38 modules from the two batteries and install in the Classic battery case. However you'll have to figure out how to equalize the state of charge across those modules or you'll end up with a traction battery fault code.
  11. fredthepostman
    422
    boothwyn pa
    Ditto!!!!! I was at a dealer a week ago. He new almost nothing about a car that's going to be out in about 10 to 12 weeks.:(
  12. iceobar
    iceobar Junior Member
  13. Patrick Wong
    18,210
    6,512
    The warranty would drop down to 8 years / 100K miles. The longer warranty is only in effect if the car was originally sold, licensed, and operated in a CARB state.
  14. joshjta
    joshjta New Member
    San Diego
    What if the car is purchased in a state not under the California standards and than resold in California? Is the warranty transferable for 2004-current Prii? Does anybody have a link to the California law so that I can confirm this beyond a doubt?
