Serpentine belt replaced 3 times in 49k miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by aanimate, Jan 31, 2012.
  1. aanimate
    aanimate New Member
    25
    I am very concerned regarding how often my serpentine belt needs to be replaced. First time it was replaced at 104k, second time dealer replaced it at 126k, third time at 153k. Today I went for oil change (173k) and the dealer told me that it has little cracks and recommend replacing it.
    Is it normal? Could it be something else is effecting it? Or dealer trying to pull something?
    Thank you for the advice.
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    The dealer is likely milking you. Learn to check it yourself. :)
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    ^ Probably this.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Yep, I'm still on my original at 120k...ask to see the old one before they change it and if it is worn then you need to tell them to fix the cause of premature wear.
  5. qbee42
    3,080
    I've never heard of anyone needing even one new belt in that number of miles. Most likely the small cracks are in the dealer's wallet, so he needs to keep refilling it with cash.
  6. kornkob
    kornkob New Member
    128
    Wisconsin
    I'd start to question if they ever changed the belt the last 2 times. If you've had the work done at the same place each time, it's time to ask for the service manager to review your file and then sit down with you to explain why they've needed to do this service repeatedly. Ask for that explanation in writing or take copious notes. Then take it to another dealership or mechanic and ask them for a second opinion of the service manager's explanation.
    And if you stay with this place for service, ask that all parts that are replaced be given to you, as well as any packaging for parts that they put in the vehicle. That way you can be sure that the parts are actually replaced and are in poor enough shape to be replaced.
  7. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Either the dealer's ripping you off with unnecessary work or there's an underlying problem and they're ripping you off by not bringing it directly to your attention. The underlying problem could, of course, be incorrect installation.
  8. kornkob
    kornkob New Member
    128
    Wisconsin
    Yep-- another reason to bring in the service manager. It could be one of his techs is not doing good work and this is something the service manager wants to fix if he's worth a crap.
  9. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    That would do it for sure, also a burr on the metal wheel could cause a problem. If changed again, inspect the old one. You should be entitled to a free belt and labor by now.
  10. aanimate
    aanimate New Member
    25
    Thank you all so much for the input. I will be talking to them this weekend.
  11. RobertK
    RobertK Member
    128
    Norfolk, VA
    After reading this thread, I remember seeing this page about identifying belt problems:
    Troubleshooting Belt Failure - Spring/Summer Car Care | Gates Corporation
    One thing that I found interesting was that they recommended belt replacement if three or more cracks were found in a three-inch section of the belt. It would appear that a few cracks across the belt do not necessarily mean that the belt needs to be replaced.
    Take a look at the pictures and see if your belt has any of these problems. You will then have an idea of what needs to be done to fix it.
    Hope this helps.
  12. andyprius
    2,212
    188
    I changed my belt simply because the car had over 100,000 miles on it so I thought it would be good insurance. It really did not need changing. Although there were a multiplicity of cracks on the underside, the thickness of all the cracks probably was 5-10 % of the total belt thickness. The topside was like new. It's a tough belt. :cheer2: I now have a spare!
