Tranaxle Oil Help
Discussion in 'Toyota Prius Service Bulletins - TSBs' started by Pinstripesdumbo, Oct 25, 2011.
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    I really like the Bentley repair manual. It is several steps above a Haynes/Chilton. It is the collegiate abridged version of the service manual.
    Transmission fluid ATF WS fills your hybrid transaxle. Changing the fluid is identical to changing that of a manual gearbox: Remove the fill plug, position catch pan, remove drain plug, give the fluid 5 minutes to drain out, install drain plug, pump 3.5 quarts of fluid into the fill hole, install fill plug. This is a 1/2 labor job for a dealer. No flushing machine, no code reader.
  2. richard schumacher
    7,686
    1,068
    United States
    Drain and fill, $90. Forget the $250 flush. If they play dumb, go to another dealer, or even an independent (but in that case buy the correct ATF yourself from a Toyota dealer and hand it to the independent).
  3. worrywort
    worrywort New Member
    buffalo
    Please excuse my asking (just petrified that I will mess something up really badly)--I can pour the fluid--I don't really have to pump it do I?.
    Have ordered the Bentley online.
    Thanks again.
  4. Wilsid
    Wilsid Junior Member
    91
    I bought 2' of 1/2" clear hose at lowes for 32 cents a ft. and used one of my
    wifes little funnels and filled it. It doesn't quite take 4 qts. No pump. It was
    $7.99 a qt.at the dealer.
    Mendel Leisk and worrywort like this.
  5. seilerts
    3,326
    1,520
    Santa Fe, NM
    I like to pump it in because it doesn't make a mess. I also have a lift. You have to be a little more careful with the funnel+tube method, but it is easier if you have the car on jackstands.
  6. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Easiest way is with a prybar to break them free that the hardest part
    Jack up one side 1489979674618.png remove top one and have your low profile oil pan remove botton drain lower car . After it drains jack back up and install botton plug i use 1/2 pex pipe snake down from the top to the hole push pipe in 2" or so heat pex pipe ine so it will stretch push funnel in the add all 4 then remove pipe wouldn't leak yet lower leave pan at the same spot lower car 2 minutes then jack up install plug your done with way faster then a oil change
    NOLA_Akita likes this.
  7. Mendel Leisk
    42,355
    Why not just raise and level the whole car, the once? (n)
    Raytheeagle likes this.
