Can't get inside of windshield clean...any ideas?
Discussion in 'Gen 2 Prius Technical Discussion' started by ripaten, Sep 17, 2008.
  1. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    Invisible glass is far better than Windex if there's something stubborn on there, but otherwise PN here has hit the nail on head: DISTILLED WATER is THE "magic" glass cleaner. Wipe down with distilled water, then buff out with clean microfibre towel. Glass will fade to near invisibility.
    Also don't forget that newer cars interiors are still gassing out and a bunch of the "stuff" the plastics are giving off will condense upon and coat the interior glass with gray hazy stuff. The newer the car, the faster this happens.
  2. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Ripaten,
    The 2008 Prius is also still "outgassing" on the vinyl dashboard. The can contribute to the horrible condition on the windshield.
    I use 303 Protectorant on the dash, it seems to cut down on the "haze" that appears on the windshield @ night.
    Worth giving it a shot. Also I use Invisible Glass cleaner - really cleans well.
    Hopes this helps,
    Dbcassidy
  3. donalmilligan089
    239
    22
    virginia usa
    I found that overspray fro A vinyl restorer really is hard to clen off
  4. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    I'm sur glad someone else is having this problem!! I thought it was just me! Thanks for all the suggestions. I'll have to see how they work.
    Frank....;)
  5. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    invisable glass and a micro fiber towel. I also think clay bar is needed on the outside once in a while.
  6. s1flaherty
    s1flaherty Junior Member
    45
    Southern Nevada
    2023 Prius
    XLE AWD-e
    I just ordered a"Windhsield Wonder." It arrived yesterday and works great. Streaks gone. Thanks!
  7. Priusshock
    Priusshock New Member
    Lomita, CA
    The worst thing that could happen is a leak from your radiator to the heater box. Clean Streak uses accetone. But the other one suggested should work fine. THen check often to see how fast the problem comes back.
  8. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    invisibleglass.com has samples
    You’ll get 5 packs of Invisible Glass Wipes (2 wipes per pack), PLUS $15 in savings coupons.
    but they want $4.50 to cover shipping
    they also got a reach and clean tool for 14.95 plus 4.95 shipping. if you click on the win link on invisibleglass.com
    you can get a $5 coupon code
  9. richard schumacher
    7,675
    1,057
    United States
    Ammonia spray and clean old cotton rags.
  10. rigormortis
    1,340
    26
    san jose, ca
    window cleaner and ordinary gas station blue paper towels seemed to do a better job absorbing liquid then high priced 'food service' paper towels!
    food service paper towels go for like $40-70 for a case of 150, haha
  11. oldseagull
    oldseagull April Member
    49
    Chester, Virginia
    Invisible Glass is the best window cleaner I have ever used, and for reaching the far-flung corners of the Prius windshield, you should try Glassmaster Pro System, a paddle like affair available at AutoSportCatalog.com - Products For Everyone Who Drives! 800-953-0814. The cost is $19.95 but for all the extras included and the quick work it makes of cleaning both front ,rear, and side glass, it is worth it! Here's a picture from the catalog - BTW, it comes with two snap-on/snap-off paddles and several cleaning covers.
  12. Walker1
    Walker1 Empire
    911
    FL
    I bought Invisible Glass @ Sam's club. Windex didn't dowellfor meeither, but after cleaning the inside glass with "Invisible" 3X the 1st time it looks very clear. Walmart & Pep Boys sell it also.
  13. southridge
    southridge New Member
    Walton, KY
    I had a lot of trouble trying to clean the inside of the windshield on my '04 until I tried spraying windshield washer fluid that has a few percent alcohol in it. That seems to get the streaky film off pretty well for me.
  14. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Don't use a terry towel even if it's micro fiber.
    Get a glass cleaning cloth from an auto parts store.
  15. ADK46R
    ADK46R New Member
    Queensbury, NY
    I've used this for years.....get a quart of warm water in a clean bucket, add a couple tablespoons of cornstarch from the kitchen cupboard, swish it around until it's mixed up good. Take a dishrag & soak it good...wring it out & wash the windshield with it. You may use newsprint or paper towels to dry it. You will have a sparkling clean windshield in no time.
  16. Grwiseman
    Grwiseman New Member
    Houston
    Wow did that work well. I turned right around and cleaned my house windows. Thanks for the tip!
