Odometer limited to 299,999 miles
Discussion in 'Gen 2 Prius Technical Discussion' started by 80Kayear, Aug 24, 2009.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I added you to the list over at 299,999+ mile club.
  2. Chazbby
    Chazbby New Member
    Napa,Ca.
    Hi. Yes I did I called toyota and they told me that's
    as for as it will go. They will turn it back to 0,it is called "Cluster", but it cost $485.38. Toyota told me they will half it with me. I don't find that exceptable. I think they should pay all because that is a problem that should be theirs.You would think they would be proud that their cars would go past 299,999 miles. Charles
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Search for member Peef in this forum. He fixes the affected CM board for about $125.
  4. kamoores
    kamoores New Member
    Severn, MD
    My wife's prius (2005) just hit the 299,999 limit on Feb. 14th. With camera ready, she waited as her car approached the momentus occassion. 299995, 996, 997, 998, 999, then nuthin! The computer still seems to be calculating the gas mileage correctly. So it must be recording miles traveled, but just not updating the display. Has anybody ever found out why the car was designed this way? Its beyond absurd.
  5. kentoxboy
    kentoxboy New Member
    MD
    Very interesting, wonder why Toyota would do that...
  6. dstrauss
    dstrauss 2018 Honda Clarity PHEV Touring
    Midland, TX
    Maybe it's like the Mayan calendar - that's the pre-ordained end of life...:eek:
  7. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Could have been a simple hardware limitation in the actual display. I guess they mustn't have expected many Prius to make it past 300,000 miles on the early models
    It was one of the upgrades that they made in the later models though, given the user "2fast4u" reported taking his Prius out to well over 400,000 miles. I guess they probably made that update when they updated the display and the interior in the 2007 model (or was it 2006 when they updated the display, I keep forgetting) .
  8. somuchtoseeanddo
    somuchtoseeanddo New Member
    Los Angeles County
    I too discovered this yesterday, and was equipped with a camera to record the 300,000 mile event. What a strange surprise. It does seem rediculous that one would have to pay to get the odometer to again roll. It did steer me to this forum, so I at least appreciate that it is not something limited to my 2005 vehicle; although, it is still frustrating.
  9. emtdaddy4life
    emtdaddy4life Junior Member
    Bakersfield
    I too have the same problem as about 3 weeks ago on 2005 Prius I went over 300,000 miles and it stuck at 299,999 miles, I have had to replace the hybrid battery and mass air flow sensor, inverter pump, tires and auxillary battery, I average 1500 miles a week
    JDonovan likes this.
  10. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    That odometer limitation is only on the 04, 05 models. I remember lots of threads about it, also I think it is the reason for the 299000 mile club.
  11. eldiee
    eldiee Member
    118
    17
    Iowa on Mississippi River Bluffs
    This problem must have been corrected in later genII models as 2fast4u had pictures of his 2009 with 460000 plus when he traded it for a new Prius v a couple months ago.
  12. emtdaddy4life
    Bakersfield
    Did you ever find a fix? It seems to be an inherit problem what did the dealer tell you to do?
  13. jersuzvan
    jersuzvan New Member
    Valley Center, CA
    I have a 2005 Prius that had the odometer stop at 299,999 miles and corporate Toyota told me they wouldn't cover the design flaw because the car is out of warranty and has too high of mileage! DUHHH.
    krutoyi likes this.
  14. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    See pEEf for a solution.
    JeffD
  15. Former Member 68813
    3,524
    983
    US
    2003-2008 Corollas have the same issue. 299,999 miles or kms (Canada) is the limit. I think it's planned obsolescence. It also proves Prius is just a hybrid corolla ;-)
  16. krutoyi
    krutoyi New Member
    Hello all,
    My 2005 prius odometer stuck at 299,999. The red triangle on the dash is on as well. I was first guessing it on because the HV battery needs to be changed. But I am still averaging 46mpg and battery seems to charge fine. The other users with 299,999 is the red triangle on?
    thanks
  17. jmcdaniel99
    jmcdaniel99 Junior Member
    Illinois
    Yesterday I hit 299,999 miles on my 05 prius. With camera ready to take the 300K pictures... but it never happened... Odometer is stuck....
  18. emtdaddy4life
    Bakersfield
  19. SageBrush
    11,627
    2,533
    Southwest Colorado
    Ahem
  20. dolj
    dolj Senior Member
    8,555
    4,346
    Wellington, New Zealand
    Ahem x2.
