ScanGuage II installed in my Prius C!
Discussion in 'Prius c Accessories and Modifications' started by managerman, Apr 4, 2012.
  1. managerman
    managerman Prius v Nerd
    228
    110
    Columbus, OH
    After reading tons of threads about the advantages to having a Scan Gauge...I purchased one yesterday and installed it today...Setup some X-Gauges based on this link...
    https://spreadsheets.google.com/ccc?...ZTUR1eVE&hl=en
    Install worked out good from a visibility standpoint and the cable is hidden very well on it's way down to the OBD II connector...not happy about the side mount of the connector, but in order to use the back jack, I would have had to mount it to the steering column and it was not as easily visible...
    Here are some pictures of the installation.
    -M
  2. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    Looks great!
    lol... like that's all we need... more info to distract us when driving, eh? ;)
  3. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    You're using 3 of the same gauges I do. (I've got trip mpg instead of SOC).
  4. EVOX
    EVOX New Member
    24
    So Cal
    Would the ScanGuage II be usefull on high performance cars? I heard it tracks 0 - 60 times and quarter mile times.
  5. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    im using mine for rpm, water temp and voltage. what is soc?:confused:
    Prismart likes this.
  6. managerman
    228
    110
    Columbus, OH
    It has a whole performance section in the manual....0-60, quarter mile, horsepower...so maybe yes..
    -M
    State of Charge of the traction battery.
    -M
    Prismart and MandiRocker like this.
  7. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    oh oh im going to ask a very naive question. is that like the big bad nice person battery. instead of the 12volt. where did you find it if that is correct. i think i would really like that. my scan guage II is several years old going back to either my 2004 or 2007 prius. thanks for your patient explanation:D
  8. managerman
    228
    110
    Columbus, OH
    No problem....Yes...the main EV drive battery....I think you might have to have the firmware upgraded to the latest version for some of the X-gauges to work properly...latest firmware is 4.06..
    There is a link in my first post to the X-Gauge info...including SOC
    -M
  9. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    wow. that looks very confusing!!!!.:confused: can i upgrade my software by somehow connecting my guage to my computer or am asking a too dumbass question. im sure there have been many upgrades since i last used mine. thanks again.:)
  10. nerfer
    2,507
    237
    28
    Do a search. Or go to the scangauge website and look at their link on upgrades: Upgrade : Linear Logic - Home of the ScanGauge
    They say version 4.02 is the latest, but there are PriusChat posts talking about 4.05+ and 4.06. You might want to e-mail them directly, and/or spend the time searching here for information that's already been given.
  11. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    There are no "Stupid" questions, just ones a person was too stupid too ask. So continue to ask away!
    I believe you have to send your Gauge in to have the upgrade performed. Here is a thread on upgrading...
    http://priuschat.com/forums/gen-ii-prius-main-forum/38313-scanguage-ii-upgrade.html
    Personally I would rather the end user have the ability to plug into a USB port and flash the unit yourself!
    X-Gauges are gauges specific to the Hybrid system. There is a program called Torque you can use on a Android phone or tablet to display Gauges, here are a couple of links for you!
    This is a link for Gen II
    http://priuschat.com/forums/gen-ii-...ndroid-app-formulas.html?highlight=gauge+list
    This is the Gen III list...
    http://priuschat.com/forums/obdii-a...pids-torque-app.html?highlight=GenIII+Android
    Another good thread is here...
    http://priuschat.com/forums/gen-ii-prius-modifications/51100-my-scangauge-user-manual.html
    Hopefully with all this to read, you can come up with some useful ideas. As a side note, you can run more than one Gauge at a time. The two RJ-45 connectors on the unit are loop thru. Just daisy chain away! They will connect with a standard Cat-5 cable!
  12. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    wow. thanks to all. i have to admit that i mostly use the tempeature and rpm guage the most. its kind of a kick to hear it wind out to a whopping 4000rpm or so.
  13. KK6PD
    4,003
    946
    118
    Just remember 4000 rpm eats Gas.
    But have fun now, you will figure out Hyper Mileing after you spend some time here!
    Watch the correlation between RPM, MPG, SOC, Stealth, Warp Stealth.
    Read Grasshopper, learn, ask questions!
    You too can Master the HSD!
  14. Nic Lechner
    Nic Lechner Junior Member
    65
    Sacramento Ca
    What would be the best scangauge for a C?
  15. managerman
    228
    110
    Columbus, OH
    Scangauge II. Allows the use of X-gauges
    -M
  16. deckbuild
    deckbuild Junior Member
    42
    Singapore
    Hi Would like to check does the firmware in the SC II matters for use in Prius C?
  17. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Hi deckbuild,
    Yes, it does. Ver. 3.xx can't handle multi-frame msg., only Ver. 4.xx onwards can. See my other thread.
    Vincent
  18. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    I used to have the SGII I'm using on the C on my Z28. It can be useful to have real numbers instead of needles, and it does the mpg figuring (which isn't an option on my ancient 1998 vehicle.) Plus, yes, it does monitor a number of performance parameters. I did a 0-60 in the C one morning. Saw a whopping 11.5 seconds warmed up and on level ground.
    I put my SG on the C on the steering wheel pod with the connector coming out the back. There's a thread about that with plenty of pictures.
    I monitor water temp, RPMs, instant mpgs, and trip mpgs. I have others, but those are the ones that usually stay up most of the time.
  19. Alexandru Popa
    Alexandru Popa New Member
    Hi
    Does anybody here know who i can get SOC and BTA running in the same time? i managed to get SOC working but BTA is blank
    Thanks
    Alex
  20. X HCH2
    X HCH2 Member
    119
    Upstate SC
    I've got both on mine right now. I have a nearly new SG, maybe yours is not the latest software version. Do you know what you have?
    X
    Mr Incredible likes this.
