Film on inside of windshield
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jdcollins5, Apr 27, 2012.
  1. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    When I first got my car I had an issue trying to keep the film off of the inside of the windshield. Even with Windex it would leave streaks. I found out that old newspaper worked best.
    I then read where others were just using a damp cloth to clean their dash and not any interior protectant. Ever since I quit using any type of interior dash protectant I have not had any further issues with this film.
    A couple of weekends ago I noticed that the dash part closest to the windshield looked like it was beginning to discolor ever so slightly. I grabbed a bottle of the ArmorAll interior spray, wet a rag and applied a thin film to this part of the dash and then the rest of the dash.
    After the first day of sitting in the hot sun in an asphalt parking lot at work I again have a film on the windshield.
    Does anyone know of a good dash protector that will not give off an oily film but will help with the dash fading ?
  2. vvDO
    vvDO New Member
    Santa Barbara
    I have the film and I have never used cleaner on the dash just a damp cloth however was going to start using armor all, guess I won't now.
  3. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    That film was common with older plastics and is a result of the plasticiser evaporating and condensing on the windows. Armour all has a lot of volatiles in it which is why it stays "wet". These also condense on windscreen glass. Prius glass is UV blocking. I'd be surprised if the dash was discolouring due to UV.
  4. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I've read that the best way to protect it is just a damp cloth and no armorall. I just wipe it down, and after 3 years don't see any discoloring happening. I"ve heard someone I know likes Blech White (I think that's how it's spelled).
  5. ataylorracing
    ataylorracing ataylorracing
    171
    29
    Fishers, IN
    Using plain old newspaper should work.
  6. d2mini
    d2mini Active Member
    519
    106
    Houston
    I usually use a mild, ph balanced interior cleaner.
    I just picked up my first bottle of this stuff. Only used it once so far but seemed nice, and I was able to use it on the whole interior. The softex seats, the dash, the door panels, the steering wheel, etc. But not the display screens.
    http://www.detailersdomain.com/Optimum-Protectant-Plus_p_177.html
  7. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    I find something called '303 Aerospace Protectant' does a great job on plastics, without releasing a film that coats the windows.
  8. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    I use it also, works great and doesn't leave a film.
    303 Products, Inc.: 303 Aerospace Protectant
    I get it at Ace Hardware.
  9. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    There's no reason to use anything on the dash. The windshield is already tinted 80% and has 100% UV cut rate.
  10. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Just say no to Windex and Armorall. Over the past 10+ years, I've been using these products with great success:
    - Plastics: 303 Aerospace
    - Glass: Stoner Invisible Glass - absolutely the best consumer window cleaner for streak-free finish. I've always used the aerosol can, but it's also available in a pump. It comes in a black & yellow container.
  11. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    That film on the window is plasticizer. Armor All is a water emulsion of plasticizer. It's great for replenishing dried plasticized materials, but then it does evaporate, and condense on the cool window.
    Plasticizer makes hard plastics soft. The classic is vinyl, which is plasticized PVC. PVC is a very tough plastic, but it's also hard as a rock. Think of PVC pipe. That's pure PVC. The plasticizer comes as a thick liquid. You melt the PVC and mix in the liquid. Then when it cools, you have a soft, flexible, but still tough plastic (you call it vinyl). Over time the plasticizer evaporates and the soft plastic becomes harder and it also shrinks (as part of it's volume disappears into the air).
    Other plastics also can have plasticizer. I had a nice window shade for the car, but the silver coating over the fabric must have been plasticized, since it always left that blue haze when I used it.
  12. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    I agree. The Stoner Invisible Glass is the best window cleaner I've used. A lot of detailing shops use wet newspaper. However, newsprint leaves ink on your hands and Stoner cleaner contains strong chemicals. Either way, try to wear protective gloves. I buy powder-free latex gloves in Walmart's pharmacy area.
    The 303 Aerospace Protectant sounds promising, although it's a new one to me. Their website says it's recommended by manufacturers and fights UV rays. The reviews I found on the product were positive. Some people said it can be difficult to find locally, so it might require an online purchase.
  13. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I've been using 303 for a long time with great results. Although I haven't used it--or anything else--on my Prius interior. Dusting with a California dash duster is all that's ever needed.
  14. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    I've been using 303 for years, but on my hot tub vinyl top. It's a great product also for those black rubber seals around the doors and hatch of the Prius. Keep in mind that it might leave a high luster if you use it on the dash plate which could generate reflections.
    303 can be found at your local pool and spa supply store.
  15. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    Thanks, I never would have thought to try a pool supply store.
  16. WE0H
    WE0H Senior Member
    3,247
    528
    Got my vote for 303. I have been using it for years on my paddling dry top latex gaskets. They stay like new with 303 worked into them. Add a paddling shop for a source of 303. I would not hesitate to use it on any rubber or plastic material that you really care about.
    Something else I have used in the past on plastics is aerosol furniture polish. Lemon Pledge or any other brand name spray on polish. It keeps plastic from drying out. It does leave a very slippery surface and shiny so be aware using it on the top side of the dash.
    Mike
  17. car compulsive
    741
    274
    Michigan
    While 303 works for door seals, it doesn't last very long and doesn't cure noisy, creaky seals very well. (Common problem on my old Lexus LS430) The best product I've found for door seals is Shin Etsu grease available at the Honda parts counter. You will likely need to have them order a tube (about $20) as they often only have one in stock which is used by all of the mechanics when needed.
  18. richsc
    richsc New Member
    59
    Washington DC
    I will have to try that 303. However, I found a microfiber cloth on a stick wipes all the film off and keeps me from straining to get into the far reaches of the windshielf.
  19. WE0H
    WE0H Senior Member
    3,247
    528
    Would that be one of those green cloths on the plastic stick? Sprayed with a mist of water? I use one of those, works great.
    Mike
  20. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    We have a dust brush we use on the dash as needed.
    Also we started using the Invisible Glass cited above (got at Walmart) on the windows to help minimize the inside film.
