What do you guys think about this roof spoiler?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by macmaster05, May 2, 2012.
  1. macmaster05
    macmaster05 Senor Member
    4,050
    730
  2. powerjo
    powerjo Member
    112
    42
    Hong Kong
    lovely and clean !
  3. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    If doing body mods IMHO would go with full body kit. I am not really sure what image shows. Sorry IMHO not a go for me.
  4. macmaster05
    4,050
    730
    The image is of a roof spoiler. It's very subtle. See the tiny 'lift' on the top of the glass?
  5. macmaster05
    4,050
    730
    So I talked to someone who bought this spoiler for the Gen III and he sent me a picture of it on his car (see first pic below).
    Notice he installed it on the panel above the rear window. On the picture in the eBay listing, however, it's on the top of the glass (see second pic).
    He did point out that he had to leave 1/4" of space between the spoiler and the roof, so that when he opened the trunk, the spoiler would clear. But now I'm wondering, where is the right place to put it? What looks better?
  6. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I'd want to see wind tunnel tests before changing the car's aerodynamics. Although, most street cars aren't driven fast enough for this mod to make any difference.
  7. macmaster05
    4,050
    730
    Haha I never even considered this. I don't know if this counts as "changing the car's aerodynamics" so much that I don't even know if you are you implying it would improve or hurt aerodynamics? Do you have any input on where I would place this though? (on the top of glass or on the top of the section above the glass)
    Edit: The guy says he put it on the roof otherwise it would be too low - "what's the point" he says. And he said it would hit the wiper. I'm starting to agree with him but my concern would be that it doesn't fit the roof, since the picture shows it installed on the glass. Thoughts?
  8. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Intuition tells me it would have a negative effect on the smooth airflow over the hatch. That said, unless you're also installing a flat 12 under the hatch, it's just cosmetic. ;)
    Probably on the glass would be less problematic. If putting it on the roof affects being able to open the hatch, that's a significant problem and a dumb idea. If it's on the glass but in the way of the wiper, you can always install a shorter blade.
  9. macmaster05
    4,050
    730
    I just confirmed that it'll hit the wiper. I went outside and measured the clearance (it recently rained and I used the wiper so I could see the line and measure it). It's about 39mm from the top of the glass to where the wiper swings, so if the piece is truly 44mm like the eBay listing says, then it won't clear.
    I'm leaning toward installing it on the top. The other way is too low like the guy says and I don't want to replace the wiper. I'd have to be really careful about installing it, so I have enough clearance to open the hatch.
  10. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    Plus I think you would lose the function of the rear window spray if you install it on glass. It'll just spray all over your new spoiler...
  11. macmaster05
    4,050
    730
    Yet another great reason. Thanks C. :)
    Ok, we've established that it definitely does not belong on the glass. The question is, does it clear the roof when the hatch is open? On a Gen III apparently 1/4" away from the edge is enough to clear. Does anyone know if the Gen II trunk stops at the same angle? I was just outside taking a look and doing some measurements and I can tell you that when the hatch is completely open, it goes deep under the roof. It's like a canyon in there, I couldn't stick my small fingers between the gap.
  12. djstl_atl
    djstl_atl Junior Member
    ATL Gawja!
  13. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    macmaster05 any updates or pictures? I think it's awesome, and I've been looking for something like that for awhile. Let us know how it looks and where it was installed :)
  14. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    What i would like to see is this in a "lip spoiler" like the BMWs.. instead of roof spoiler.
    or even a lil more sporty...
  15. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    personally, i'd install it in a dumpster. (see avatar). however, i do like some of your blacked-out mods. and i'd like to see what red vinyled tail lights would look like. i hope its easier to install than window tint...
