Initializing the tire pressure warning system
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ukr2, May 19, 2012.
  1. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Did I miss a meeting ???
    My Base model PIP does NOT have a Set button for the tire pressure warning system. WHAT !!! It is NOT below and to the right or left of the Steering Wheel.
    I haven't noticed anyone mention it here for the PIP.
    The FEATURES page for the PIP lists the Tire Pressure Monitor System (TPMS) as Standard for the Base and Advanced models.
  2. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    It's there. Stick your head under the steering wheel and you'll see the button.
  3. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Nope, not there.
    You also have a Base model. If you have one, take a photo of yours, also showing the steering wheel.
  4. PRPrius
    PRPrius Active Member
    327
    198
    The button is to the right of the OBD port. Look underneath the dashboard on the driver side. It is right after the knee airbag. Right above the brake pedal.
  5. Conrad
    Conrad Junior Member
    Santa Clarita, CA
    When you say 'reset'. What do it reset and where do you read the results? Gotta admit I havn't read the manual. Can't get past the Caution notes, they scare the hell outa me. Only had the vehicle for 2 months and got 1900 miles on it. Love it.
  6. Rebound
    3,996
    2,645
    Portland, OR
    There are pressure sensors in each tire. When you reset the system, it sets the current tire pressure as the "baseline," so if pressure falls below that amount, it warns you.
    Whenever you add air, you should reset it. You want to be warmed of pressure loss, not that the pressure dropped below X psi.
  7. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Rebound,
    There is a blank cover for a device on the right and 2 blank covers on the left, on either side of the gas door button.
    But no Tire Reset button.
    Did you find your button?
    If you did, take a photo.
  8. Rebound
    3,996
    2,645
    Portland, OR
    Sure, it's the button that says SET. It's farther underneath than you think.
    4 people like this.
  9. qbee42
    3,080
    TPMS is required by law. Even base models have to have it.
  10. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    OMG. Thanks Rebound.
    WHY the hell did they put it UNDER there.
    I had to put my head BELOW the seat to see it.
    CRAZY.
    I want to speak to the engineer that approved that location.
    Is the Tire Pressure Set button in this location for the Advanced model too?
    WOW.
  11. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    But why take up valuable dash real estate for something that you will use very seldom? It wasn't such a bad placement IMHO...
  12. Rebound
    3,996
    2,645
    Portland, OR
    What I think is that most owners don't read the manuals, and the TPMS Reset isn't a button that should be pressed at just any old time. Therefore, it's placed in a location accessible for mechanics and for those owners who will take the effort to use it correctly.
  13. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    The gen 3 manual doesn't show it in that area, I think they just used the gen 2 diagram.
