Help - Tree Sap
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mozart, May 22, 2012.
  1. Mozart
    Mozart New Member
    Columbia MD
    I have tree sap on the roof and doors of my 1 month old Prius. Can someone please tell me what is the best way to clean/remove the tree sap?
  2. PeteinPG
    PeteinPG Junior Member
    Pacific Grove, CA
    Hi M; I have been dealing with pine tree sap for years.
    The sooner you get to it the easier it will be to remove. The older the sap the drier it becomes, but it's still can be dealt with effectively.
    Clean the area around the sap first. Use "Goof Off" (bought at Home Depot, Ace, or any H/W store) soaked on a paper towel and place that on the sap. If the sap is still fluid and sticky, the Goof Off will remove it very easily. If dried, just keep applying the Goof Off and rub it gently and it will come off as it loosens up. No need to rub it too vigorously.
    Once removed, clean the area again or better yet just wash the car and I like to wax that specific area.
    Good luck!
  3. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    151
    59
    Chelmsford, MA
    In addition to Goof Off, Bug and Tar remover, available at all the car stores, works well. If it's fresh (like same day), the high pressure wand at a car wash will take most of it off, reducing some labor.
  4. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Spray the stuff onto a cloth rag then rub- rather than spraying directly onto the car's painted surface.
  5. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Just use WD40 if it is fresh.
    I used to work at a car wash and for sap, bugs, and gas stains, we would use kerosene or diesel to clean it.
  6. fulltank
    fulltank New Member
    230
    Arkansas
    Wanted to add if it's just 'light' sap from spring time budding trees you can use normal car wash soap, like Dawn. I park near some smaller trees at my office and get a light dusting of sap on my car but it comes off easily with mild soap and a car wash cloth or mit. No reason to apply all those harsh cleaners if they're not needed.
  7. Mendel Leisk
    41,894
    I had pretty good results using a cloth dampened with kerosene plus a dab of liquid car wax.
  8. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    ...another thread we concluded turpentine might work well (like dissolves like) but check safety for car finish first.
  9. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Well, Dawn is definitely not a "normal car wash soap" as it'll strip wax, but yes, it's safe and give it a try first if they're light.
  10. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved to the proper forum.
  11. royvogel
    royvogel TanzMan
    Smyrna, GA
    I would first try warm, maybe very warm water and car wash soap, it that doesn't do it and you can tell with your fingers, if it's gone, I would then go with a clay bar. I would not use Goof Off or any other petroleum derivative as I would be concerned with long term damage to the clear coat. There is no doubt the petroleum products will do the trick, but the long term effects could be noticable, especially if the car will be in the sun.
