FREE Earth Day Charge Point Card
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by knckdwntxt, Apr 17, 2012.
  1. maverickf
    maverickf New Member
    113
    Southern California
    Got mine yesterday, can't wait to try it out.
  2. seek
    seek Junior Member
    32
    Tewksbury, MA
    Ordered on 17th and got it today.
  3. Mark Y
    Mark Y Junior Member
    Connecticut, USA
    Got mine yesterday - yay!
    -- Palm Pre3 using Forums
  4. mrbigh
    3,686
    699
    Long Island, NY
    Received mine yesterday, about 10 days processing and snail-mail time.
    Nice looking card.
  5. janie
    janie 2016 Prius 3 Touring
    175
    42
    Three Touring
    Just in case some of you missed getting the free Earth Day Charge Point Card.
    About a month ago, when I was at one of the free charging stations, without a card and without an online account set up:
    the person helping me on the phone, activated the charging station for me, and said he could send me a card if I wanted, and I said yes - and received a free card without paying for it- (took about 2 to 3 weeks before I received it).
    I don't know if that is their normal procedure, but just saying it still might be possible to get a charge point card for free (but not an earth day one). :)
  6. mikenewmediary
    100
    24
    Bridgewater, Ma.
    Received mine yesterday (6 days), stopped for a charge, and drove my entire commute on EV. If I only could charge @ work. :mad: IMG_0455.jpg
  7. flim
    flim Active Member
    247
    171
    Huntington Beach, California
    2023 Prius Prime
    XSE Premium
    According to customer service, if you order online there is a FEE but if you order with a humanoid it's FREE!
    I actually called last week to have the $4.95 refunded.
  8. csolsen
    csolsen New Member
    CA
    Re: Charge Point Card
    Is the point to get the card to activate Free Chargepoint stations or to charge at $1/hr?
    At $1/hr, you should be able to charge 12 miles in 1.5hr at 240V on the charging station, which comes out to $0.125 per mile.
    In hybrid mode, with gas at $4/gallon and 50mpg, it is $0.08 per mile.
    Gas is cheaper at $1/hr rate. $3/hr is criminal.
    Please check my math.
  9. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    The former.
  10. Rebound
    Rebound Senior Member
    3,995
    2,642
    Portland, OR
    The point of the card is to allow you to use both free and fee-based ChargePoint stations.
  11. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    Mike, where was that ChargePoint? I tried using the one at the 99 in Easton, when we ate there, but it was "ICE"d, asked the manager if he could do anything, nope... They haven't figured out how to mark the 2 spots yet. Anyway I stopped by later that night and tried it quickly, as I've had my ChargePoint card for nearly 2 years and never used it ... It worked fine. FYI, 11 of the 99's have these, National Grid did the leg work to apply for the DOE grants, and get them installed.
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I got 2 Chargepoint cards. One for charging my pip, the other to connect my laptop to the 120volt remaining outlet. Since the Pip shuts power off to accessories after a few minutes. Haven't tried to use it yet. Stay tuned. Plus, in the wintertime I can use a quartz heater to stay warm inside my pip.
  13. frankbiele
    frankbiele Junior Member
    24
    Los Angeles
    I emailed to have the $4.95 refunded and got the following rejection response, maybe I need to call them?
    "Our EarthDay promotion ended on Earth Day, April 22nd. Prior to registering your card serial number in your driver account, you will have 10 grace sessions on 'free stations'.?
  14. mrbigh
    3,686
    699
    Long Island, NY
    I guess that this deal is better than the $4.95 any way...
  15. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Someone mentioned that another connection can be made on the chargepoint station by opening a door, is that the small door in the front? And what initiates the door opening ? Another card? Also, instructions say to tap card to start charge procedure, exactly where? My hit and miss system generally gets there, but I would like to be more precise. TY.
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Yes, another card if you're using one of em to charge your pip and the other one for laptop, or in winter time, a quartz heater:D
  17. CharlesH
    2,796
    1,163
    Roseville, CA
    Right in the middle of the unit under the words "Chargepoint". There are logos for various cards, and the "hot spot" it right in the middle. http://www.chargepoint.net/images/img-cp-card.jpg
