Anyone using Pennzoil Platinum 0w-20 ( S.N. ) ? If so , hows' ...
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by cinder, Jun 10, 2012.
  1. cinder
    cinder Member
    150
    northeast
    it doing for your engine ?
  2. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    I have a dealer service package until 60k so I am going to stay with Toyota 0W20. However, I am pretty sure any synthetic 0w20 is going to work fine in the 1NZ-FXE.
  3. Iconn127
    Iconn127 Master Diagnostic Technician
    44
    Cameron Park, CA
    not a fan of pennzoil products. already bad enough rep they use parafin wax in their conventional. stick with toyota oil or mobil 1 imo
  4. Mendel Leisk
    41,865
    I've used it with A Civic Hybrid, works, no problems. But with Toyota selling their 0w20 for under $6 per liter, comparing to over $10 per US quart for Pennzoil, locally, I'll stick with Toyota brand.
  5. strongbad
    strongbad Member
    170
    47
    Driggs, ID
    The basestocks used in conventional Pennzoil are refined from paraffinic crude (as are most other brands). Paraffinic crude is the highest quality crude for making lubricating oil because of the naturally high viscosity index.
    The paraffins are removed (for the most part) in the refining process and in the hydrocracking process ( for "synthetic" oil) the long-chain hydrocarbons are further broken down to shorter-chain hydrocarbons.
  6. Oldwolf
    826
    110
    NC
    2016 Prius v wagon
    PP is a great oil to use. I am a Mobil 1 fan so at 5k I will probably use their 0W20 for my C. But after that I am will be using Toyota 0W20 up to 60,000 miles since my service package covers oil changes up to that mileage.
  7. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    OP, I guess you got some pretty good answers in this thread and in your other thread:
    Pennzoil Platinum 0w-20 : Anyone here using / used it ? | PriusChat
    I'm going to return the Mobil 1 I bought at WalMart and keep the Penzoil Platinum 0w-20 because it was $5 less, almost pays for the oil filter. It's going to stay in the car for less than the full 10K anyway, changing the oil out at 3K to 3.5K for it's first oil change, then it will be done by the dealer at 10K.
  8. cinder
    cinder Member
    150
    northeast
    GEDC2143.JPG Went with the Platinum 0w-20 at $25 for the 5 quart jug . Seems fine in the 1.5 ltr. of the Honda Fit . Here's the Technical Data Sheet . Looks good on paper . No ?
    mremaximus likes this.
  9. strongbad
    strongbad Member
    170
    47
    Driggs, ID
    It's interesting that the NOACK volatility is lower for the 0W-20 than for the 5w-20 and 5w-30.
  10. mremaximus
    mremaximus "I can't wait to start hammering people" Bubbles
    98
    From parts unknown...
    I used it in my Honda fit as well, first change and on. People have great used oil analysis using penzoil synthetics.
