Planing CanView and BMS+ conversion with lithium
Discussion in 'Prius PHEV Plug-In Modifications' started by Mr-plugin, Oct 27, 2011.
  1. Flying White Dutchman
    4,376
    313
    I bite the dust ;-)
    I did a oog mode drive .~16km
    Iiiiii lovee it ;-)
    Great, i am hooked
    -Htc Tapatalk
  2. planetaire
    planetaire Plug in 20 kWh 85 km/h or > 208km range
    190
    139
    France
    I use also this mode as you can see on my today's mfd.
    and like it so much.
    99.9 L/100km equal zero gasoline ! unlike 0.00 Liter/100 km that is not exactly zero gasoline.
    dave77 likes this.
  3. Flying White Dutchman
    4,376
    313
    I stil have some driving IG mode ( in gas mode )
    But i also see the same thing with the small cars on mdf uploadfromtaptalk1339225664156.jpg
    BTW i love Tapatalk... Can do anything now from phone and on the road like post this pic direct from phone no more transfer to pc and then post
    -Htc Tapatalk
  4. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    I think it is great to drive around on battery power only. The best part is that my electricity is free. I have solar panels on my house roof and my electricity supplier pays me for feeding excess electricity from my solar panels into the grid. It's great to be green.
  5. mrbigh
    3,686
    699
    Long Island, NY
    Yes , it's great .In my case to drive in ALMOST electric since 2006 with the exception of long trips.
    dave77 likes this.
  6. Flying White Dutchman
    4,376
    313
    This is what happend ever 2 days standing still
    When you disconnect pin 1 of the cellogs
    -Htc Tapatalk
    dave77 likes this.
  7. lopezjm2001
    1,146
    407
    Sydney Australia
    When I went overseas on holidays I unplugged all my CellLogs so they would not draw any power at all. Obviously the pin 1 disconnect does not stop drawing current between cells. Just all cells to pin 1.
    dave77 likes this.
  8. Flying White Dutchman
    4,376
    313
    here are the voltages after a deplete drive ( first cell below 2,75 volts ) i top balance.
  9. lopezjm2001
    1,146
    407
    Sydney Australia
    Your graph look normal to me. Last time I did OOG mode I managed to draw my pack from 20ah down to 2.8ah.You can probably take it down further if you can keep the discharge rate to 1C or less. My pack was depleted when my weakest cell reached 2.5v. However a discharge rate of 5C or even 3C at the end will cause your weakest cell to reach 2.5v a lot sooner and hence use less AH. All my cells were around 3.1v except when my weakest cell reached 2.5v. Showing cell volts when they are open circuit is a bit deceptive when the battery pack has depleted. My Prius was still running in OOG mode in park when I looked at my CellLogs and the battery pack was depleted but I was still drawing about 1.3 amps of standby current from Lifepo4 battery pack. Because I was only drawing 1.3 amps from my lifepo4 battery pack my weakest cells was a lot higher than 2.5 v.
  10. Flying White Dutchman
    4,376
    313
    I was stil in ready oogmode parked
    Ac running to draw some amps when i write these cellogs down
    What is a lot higher? 2.7?
    -Htc Tapatalk
  11. lopezjm2001
    1,146
    407
    Sydney Australia
    I will post photos on Monday.
  12. Flying White Dutchman
    4,376
    313
    Ok great
    The high pitch sound of the ev200 is gone now
    Maybe it was Because they where new
    Also did a halleffect amps reading and topped at 80 amps for just seconds.
    This next week i will do a true rms meeter reading with max gold function
    -Htc Tapatalk
  13. planetaire
    190
    139
    France
    all. Yesterday was a very nice day.
    Just begining testing my V2.0a+ plug-in prius. This version has twice the capacity of the previous : 9kWh.
    For a total of 140 A123 cells connected 2 by 2. Yes this is not a dream, there is really 140 20Ah cells.
    First road test was 43 km. Voltage at begining was 235v, at the end 228v. Speed goes up to 85 km/h during few moments. Used 95 Wh/km.
    With the previous version (4,5 kWh) the voltage would have been near 213V after 40km and cells really depleted.
    dave77 and jdh2550 like this.
  14. Flying White Dutchman
    4,376
    313
    Nice this way you still have your spare tire and not s lot of used space.... Really nice.
    Do you have lots of flat roads?
    Do you have a data sheet of your drive?
    Here not so nice day lots of rain
    When i did another oog mode.
    I charge up to 3.7 and not lower then 2.75 but i did a 37.7 km drive from full to empty.
    This in oog mode.
    I also did lots of regen so not even 37.7 km on pack alone.
    The worst cells will deside your range i geuss me worst cells are preventing me from driving like you 40 + km....
    What was your lowest cells voltages when doing that before with your 70 cells.....
    -Htc Tapatalk ( sorry for auto spell correct )
  15. planetaire
    190
    139
    France
    When I used the "old" ;) 4,5kWh plug-in, in order to drive 40km I first connect lithium on nimh during half an hour, not more.
    (That was not necessary when temperature was over 20°C.)
    Voltage goes near 233-235v. Then put the charger one more time and after drive.
    My roads are not flat but speed can be slow : 40 km/h average.
    I just have a hill to climb 1 km before end ot trip and that was always a chalenge because I could not use more then say 40A there.
    With lower temp I could only drive 38 km in OOG mode.
    My lowest cell was at 2,8v.
    This is the relationship between amperes and volts during 18km at the end of the 43 km trip with the 9kWh cells.
    dave77 likes this.
  16. ericbecky
    ericbecky Hybrid Battery Hero
    4,436
    3,304
    Madison, Wisconsin
    I am very interested in the connections between the cells, how you put the packs together, as well as the balancing boards.
    Where can I read more and see more pictures?
  17. lopezjm2001
    1,146
    407
    Sydney Australia
  18. planetaire
    190
    139
    France
    In my album called "can"
    These connections are made for cells without tabs. If I have to do it one more time, I would really prefer cells with tabs.
    Here the connections for the 9kWh:
    The bms is the same : peter prkins.
  19. lopezjm2001
    1,146
    407
    Sydney Australia
    I did mine without tabs. It felt like I was one of those Chinese factory workers. It was a real PITA. Never again.
  20. Flying White Dutchman
    4,376
    313
    i did with tabs!! pfffff lucky me i did get them with tabs!!
    so guys only buy with tabs!! maybe a little more to pay but well spend money
