2009 aux connector but no aux button on radio
Discussion in 'Gen 2 Prius Audio and Electronics' started by codycamp, May 22, 2012.
  1. codycamp
    codycamp New Member
    southern california
    How do I connect my ipod for listening in a 2009 prius. I have an aux cable and aux connector but the stock radio with no cd/aux button. Does the aux cable do me no good at all or am I still able to hook my ipod up through this?
    Thank you for your help!
  2. cnschult
    cnschult Active Member
    772
    96
    Michigan
    press the Audio hard button to the left of the MFD and see if more options don't show up, you might hook it up and press the Mode button on the steering wheel and it may eventually toggle to Aux.
  3. ijgarcia
    ijgarcia New Member
    I just got my daughter an 06 Prius (I also recently got a '12 for myself), and encountered the same issue. There's an aux input as well as a 12 volt power supply inside the arm rest compartment, but pressing the mode button only toggles between the 3 options on the head unit panel, cd/am/fm. Seems odd that the car would have the aux input but no way to use it. Makes me wonder if the car originally had a head unit that went bad and was replaced with one without aux capability.
