Power Outlet Problem
Discussion in 'Gen 2 Prius Main Forum' started by mel1948, Aug 22, 2012.
  1. mel1948
    mel1948 New Member
    A couple of months ago, I had a front power outlet failure so I replaced the corresponding 15 AMP fuse in the instrument panel under the dash which seemed to resolve the issue. However, it recently failed again and when I replaced the fuse, it did not solve the problem.
    Any ideas?
  2. Patrick Wong
    18,210
    6,511
    There are two 15A fuses that relate to the two 12V power outlets, so I suggest you check both.
  3. mel1948
    mel1948 New Member
    Hi Patrick,
    I replaced both fuses....no success. But thanks anyway for the suggestion.
    Mel
  4. Patrick Wong
    18,210
    6,511
    Does the 12V power outlet operate, located in the center console between the two front seats?
    Are all other electrical accessories working?
    If yes to both questions, then I would suspect the Power Outlet relay. This is hiding behind the instrument panel on the left side. It will probably be necessary to remove the black plastic panel above the steering column (which houses the POWER button) for access. Consult techinfo.toyota.com and look at the electrical wiring diagram for a view of the parts installed in the instrument panel area.
  5. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Another thing to check is the 25A ACC fuse, as that feeds both sockets.
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    By failed again, what are you plugging in? Is what you're plugging in causing the fuses to blow?
    The only times I ever blew a fuse in my Prius was when I plugged in this one particular power splitter, so I lost power to my power outlet. I replaced the fuse and tried again w/that splitter. It blew a few again. I no longer user it. My other power splitters don't have that problem.
  7. mel1948
    mel1948 New Member
    Patrick,
    Great gouge. I'll check on this.
    nh7o,
    Good idea. It may be a simple fix.
    cwerdna,
    I plugged in a power adapter for an iPhone; it didn't work. Nothing more exotic than that.
    Thanks all for the assist.
  8. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    It might be defective or badly designed, causing the blown fuse. This is more likely if it's not from a reputable brand.
  9. overexposure
    overexposure Junior Member
    amsterdam
    A bit late but the fuse inside the power outlet is blown, its a small black wire inside the outlet
  10. bisco
    52,236
    never too late for someone searching for a solution
