GreenCharge now compatible with Prius Plug-in
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PlugShare, Aug 24, 2012.
  1. PlugShare
    PlugShare New Member
    Hello Prius Plug-in owners!
    My name is Armen and I am one of the creators of GreenCharge, a charge monitoring iPhone app for electric vehicles. We also make another app called PlugShare which some of you may be familiar with.
    I just wanted to notify everyone that we have recently enabled Prius Plug-in support for GreenCharge. If you'd like to check it out, here is the link to the App Store or you can simply search "GreenCharge" on your iOS device.
    The app is 100% free to download and use. Please let me know if you run into any issues!
  2. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    How would this differ from Entune?
  3. PlugShare
    This differs from Entune by focusing solely on charging and adding features to help alleviate range anxiety. For example, the app sends push notifications to your phone when your car begins charging, is unplugged, stops charging, etc. It also shows you our current state-of-charge on the badge of the icon (the little red circle where the number of unread emails shows on the Mail icon) so you don't even have to open the app to know your car's battery level!
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    How about android users?
    bilofsky likes this.
  5. PlugShare
    We are working on an Android version but unfortunately the existing app is only available on iOS devices.
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Ok, thanks, will look forward to the Android Version.
  7. Chris Knudsen
    Chris Knudsen Junior Member
    Moraga, Ca
    i tried this, when i try to log on it fails. "Error, unable to connect to vehicle" i have checked and double checked the credentials and they are fine, entune works fine
  8. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    I like that the app doesn't drain the battery using 50% of the CPU like the Toyota Entune app does (see Entune App drains battery | PriusChat) and that it provides a Reminder notification, which is more elegant than the Entune email notification.
    But I find the updating of the charge status a bit quirky. The Entune app gets a quick charge status (the car seems to push charge status when beginning charge, unplugged, finished charging, and turning the car off to a server which then caches the status) in a few seconds by default and only queries the car itself if you hit the refresh button which takes 1-2 minutes. GreenCharge always seems to query the car, so it takes a long time to update. It would be nice if it could grab the quick/cached charge status by default and only query the car if the refresh button is hit.
    Furthermore, if you open the Reminder notification, it opens up the GreenCharge app which then queries the car, generating another Reminder notification. I think that Reminder notifications should only occur if the car is queried since it takes so long and not when the cached charge status is retrieved, b/c this happens quickly and I'll probably wait for the update to be shown in the app. Or at the very least, don't query the car if GreenCharge gets opened via the notification to avoid the notification-query-notification loop.
  9. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    I like your plug Icon better than the green bolt icon. Another Android user here.
  10. sdplugin
    sdplugin First Time Prius owner
    22
    San Diego
    another android user here !
  11. hill
    8,894
    PiP's don't have range anxiety . . . . they have gas anxiety . . . . the anxiety of running out of charge & having to burn gas.
    As for no android app - maybe someone can explain the logic in that . . . . if you're going to leave out the most popular (based on sales) mobile OS and build for apple first, then hell, you might as well come out with a MS mobile app first ... it's just as illogical.
    Ken Blake likes this.
  12. chuckp
    chuckp Junior Member
    26
    Seattle, WA
    Well, it doesn't seem to want to connect to my car. The Entune app connects fine with my email and password, as does the entune website. But with the identical information GreenCharge rejects my login attempt. "Unable to connect to vehicle".
    Chuck
  13. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I presume it only works with Plug-in Prius Advanced, and not Basic
  14. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    Come out with an Android app and you have one more user.
  15. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Can it start the Prius charging (overriding the timer) like the Entune app? I use that a lot.
    Can it provide any other controls - like stopping charging?
    I would love a replacement for the Entune app - I hate it.
    - Another Android user
  16. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    Correct
  17. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  18. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    I think it's crap that you have to have an advance pkg car to be able to have remote app access, way to drop the ball on that one Toyota.
  19. Jimbo69ny
    712
    107
    Ithaca, NY
    I dont think so. We paid thousands of dollars more than you did. No offense but you dont get what you dont pay for.
    Rebound, DianneWhitmire and KK6PD like this.
  20. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    [#humor] You wanted cheap, you got cheap.
    no spare tire in the Base, either … bwa ha ha [#humor]
    It is lame that the techno flagship of the Toyota fleet leaves out the most basic of tech advances in their Base model.
