Be careful when having your windows tinted. HUD could fry!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jimbo69ny, Aug 22, 2012.
  1. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    I just had my PIP's windows tinted on Monday, all windows including the windshield.
    I had read a post on here somewhere stating that their heads up display wasnt working after their windshield was tinted so I wanted to make sure I warned them.
    Low and behold, my HUD was affected as well. It was flickering and the screen was rolling like a laptop screen would if you watched it through a video camera. It would also pixilate and shut off completely. Im not a a/v guy so I cant describe it any better. Basically, it was not working. My 7" nav screen was also foggy from all the water they used.
    I consider myself lucky because as of today it must've dried out and it seems to be working. I will know more when I leave my office to get lunch today.
  2. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Must depend on the installer. I had my windshield done three weeks ago and had no problems at all with my HUD.
    I count myself lucky.
  3. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Just curious, but when you say "windshield" how much of it is being tinted? In California, the law restricts tinting to the top few inches.
  4. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    The entire windshield. You can use 80% clear
  5. Jimbo69ny
    712
    107
    Ithaca, NY
    Yes the whole thing. I went with Carbon XP 55%. It looks great! I just wish my HUD worked.
    I thought it was all fine but I just went to lunch and its still flickering. I called Toyota and they dont even offer the part yet. But they do have a price its $450 not including labor to install.
    No begins the fight with the tint shop.
  6. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    I would turn the HUD off for a week or so, park in the sun if you can, put a blowdryer to it.
    Its not dead, its just wet.
  7. Jimbo69ny
    712
    107
    Ithaca, NY
    Its hard to see in the video but here is it flickering.
  8. Jimbo69ny
    712
    107
    Ithaca, NY
    Thats what I am hoping. However the tint shop just emailed me and assured me that they will make it right no matter what it takes. More to come...
  9. Jimbo69ny
    712
    107
    Ithaca, NY
    Here is my tint job. Looks good at least...
    Witness likes this.
  10. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Looks really good!
    As for the HUD, is there not a coating on the interior of the windscreen that allows the HUD to be projected? Hopefully this wasn't damaged by the tint. The rolling/flickering should not be a symptom. It would just be harder or impossible to see.
    Roll and flicker sound like it is out of sync which shouldn't happen, ever. If they used enough water to make the MFD foggy... That is a big red flag. Hopefully it will just dry out and be fine. But the more you use it and it shorts the worse off it will be.
  11. Jimbo69ny
    712
    107
    Ithaca, NY
    Im kind of surprised it hasnt shorted out yet honestly. Pretty good tech I guess. It seemed better today after I drove it on lunch. Hopefully it will continue to dry and be ok.
    No there isnt a special coating on the window to display the HUD. I was worried about this but I did a lot of searching before having the work done and it didnt seem like it was going to be an issue. So rest assured, if you want to tint your front window, it will display fine as long as they dont soak your HUD unit.
  12. MikeyF
    MikeyF New Member
    What level darkness (or however it is measured) did you go with the windows and back window? Looks good.
  13. n5160u
    n5160u Junior Member
    22
    17
    Please note that the display switches on the dashboard do not turn the HUD On or Off. They only select what will be displayed.
    The HUD is Powered ON the whole time the vehicle is powered up.
    Even if the HUD display does not appear to be turned on, you can still see it showing the Welcome Screen every time you power up the car. The HUD welcome screen shows at the same time the MFD shows its version of the welcome screen. Those displays are powered on even if they have nothing selected to show.
    Park your car in the sun and hope it can dry itself out from the sun's heating the interior. When the car is powered up you are running current through both the HUD and MFD displays and running current through a wet circuit is inviting major damage from corrosion and shorted electronic components.
  14. Jimbo69ny
    712
    107
    Ithaca, NY
    I went with 35% on the sides and rear but I did not tint the lower rear window because its already at 29% from the factory.
    The windshield is 55%.
  15. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Thread cleaned up. If you guys want to bicker more, you know who you are, start a conversation with each other.
    bielinsk and Jimbo69ny like this.
  16. rogerv
    1,639
    317
    Mea culpa. My sincere apologies to all concerned.
  17. stackcheese
    stackcheese Junior Member
    Pasadena, CA
    woah! that hud is awesome is this for advanced version only?
  18. Jimbo69ny
    712
    107
    Ithaca, NY
    Yeah. Its only available on the advanced. Its pretty sweet, even if it does flicker now.
  19. Jimbo69ny
    712
    107
    Ithaca, NY
    I just wanted to update this thread.
    Im not sure why but all of a sudden it stopped working completely and shut off. I left it off for about a week and then turned it on. Since that point its been working flawlessly. Its been working for about 3 weeks now without a problem.
    Very strange but Im glad its working again.
    The tint shop was very good about it. They were going to pay for everything. The total was going to be around $1000 for the part and labor. Im glad they didnt need to tear apart my dash.
  20. rogerv
    1,639
    317
    Glad to hear it worked out for you, especially without having any further work on the car.:)
