Gas Mileage this tank 37mpg
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Greg Kaiser, Aug 25, 2012.
  1. Greg Kaiser
    Greg Kaiser Junior Member
    33
    Santan Valley Arizona
    Not sure if I got a bad tank of gas but I am at 37 mpg on this tank. Used about 2/3 tanks so far
    Recently changed Oil, Engine Air Filter, PCV Valve, Trans axle Fluid and Inverter Coolant
    I also put in a few ounces of Lucas Injector Cleaner....(n)
    Normally I get 42-44 I'm a bit of a lead foot at lights
    UPDATE: Now back down to 44.7mpg I assume it is due to the heat. I got 50+ at night here in the desert and averaged 60mph on highways with some slight hills
    52,371
    certainly the injector fluid seems suspect, maybe it will take some time to clear it all out. someone else mentioned bad gas at bp. is the oil at or below the full mark?
  3. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    How much oil is showing on the dip stick, how many miles on the car.
    Have you cleaned the MAF sensor and what are your tyre pressures, have you changed tyres.
    John.
    PriusCamper likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,034
    5,297
    Pacific Northwest, USA
    I've found my Prius to be way too sensitive to a bad tank of gas... MPG plummets on the two rare occasions that's happened. I suspect overuse of Ethanol beyond 10% in both cases, but can't say for certain.
    Consider this a great opportunity to take better care of your car!
    Some more ideas: I once got really bad gas mileage when I was new to the car because I added a 1/2 quart of oil (to be safe) even though the car didn't need it.
    Like our computers at home sometimes a good old fashion reboot of the computer makes a difference. As in unplug the 12volt battery for 10 minutes... Have you changed your air fllter yet? Also ow-20 synthetic oil helps a little bit? Over-inflate your tires... See if gas mileage improves without using air conditioner / get AC service if needed. Make sure tires rotate easily when car is jacked up. Replace 12 battery if less than 12.3 volt available when car is off or in acc/inspection mode.
    Most of all learn the joy of getting your gas mileage up above 50mpg... Study up on pulse and glide in the city, pulse and stealth mode on the freeway, and just generally enjoy driving safer and slower, especially if no one impatient is following you!
    Lots of other things to consider but this is a start!
  5. Greg Kaiser
    33
    Thanks for all the suggestions to everyone. I am so happy now I am getting mileage I have never seen with this car. I bought it used Oct 2010 with 42k miles and never got over 50mpg I filled the car with fresh gas from shell took a 70 + mile trip and now am getting over 50mpg See Pic
  6. Greg Kaiser
    33
  7. bisco
    52,371
    well done!
  8. Britprius
    5,194
    1,922
    Good to see a simple and fruit full outcome.
    John.
  9. PriusCamper
    13,034
    5,297
    Looks like there's gonna be one less lead-footed driver on the road! Good job PriusChat members!!!
