Cargo Space spec with seats up and down?
Discussion in 'Prius v Main Forum' started by Collector, Aug 23, 2012.
  1. Collector
    Collector Junior Member
    24
    Illinois
    Toyota has a cargo space spec of 34.3 cu. ft. for the Prius v. I'm assuming that is with the rear seats up. Are there any storage numbers for seats folded down?
  2. tim1964
    tim1964 Junior Member
    2012 Prius+ MPV
    These are the dimensions for the Prius + (the UK 7 seat version in mm), it's just a case of converting to inches if you prefer.
    The 1st number is for the T4 version and the 2nd number is for the T Spirit version but as they are the same regarding size, they come out the same.
    DIMENSIONS AND WEIGHTS T4 T Spirit
    Exterior dimensions
    Exterior length (mm) 4615 4615
    Exterior width (mm) 1775 1775
    Exterior height (mm) 1575 1600
    Front tread (mm) 1540 1530
    Rear tread (mm) 1545 1535
    Front overhang (mm) 930 930
    Rear overhang (mm) 905 905
    Wheelbase (mm) 2780 2780
    Turning circle – tyre (m) 5.5 5.8
    Interior dimensions
    Interior length (mm) 2690 2690
    Interior width (mm) 1520 1520
    Interior height (mm) 1220 1220
    Weights
    Gross vehicle weight (kg) 2115 2115
    Kerb weight (kg) 1495 –1565 1495 –1565
    Luggage compartment
    Luggage overall length, rear seat up (mm) 375 375
    Luggage overall width (mm) 1230 1230
    Luggage overall height (mm) 730 730
    Luggage overall length, rear seat down (mm) 985 985
    VDA luggage capacity, up to tonneau cover, rear seat up (litres) 200 200
    Luggage capacity, up to roof, rear seat up (litres) 232 232
    There may be a small difference as the UK/Europe model has 2 extra seats but as the batteries are under the front armrest that may cancel out.
    Hope that helps
    Read more: http://priuschat.com/threads/dog-crates-in-a-v.114260/#ixzz24hLtyz00
  3. Quentin
    Quentin Member
    335
    West Virginia
    Here is my v on the way to drop off recycling. I love the sliding and reclining rear seats!
    Collector likes this.
  4. Collector
    24
    Illinois
    Thanks for the pictures with the cargo. It helps get a sense of scale.
  5. Quentin
    Quentin Member
    335
    West Virginia
    Should have snapped a pic last night after groceries and this weekend when we took the baby to my parents. Anything smaller (liftback, Cmax) simply would not do. Love the v.
  6. Quentin
    Quentin Member
    335
    West Virginia
