2010 Prius Grill Blocking strategy
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ken1784, May 31, 2009.
  1. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    check out the 2012 Ford Focus with SFE (super fuel efficiency) package with its computer controlled front grill louvers... looks like "somebody" was reading this thread!
  2. Turbobooster
    Turbobooster New Member
    Belgium
    BMW was years ahead : in the '90's they came in Europe already whith the E39 525TDS with thermostatic controlled louvres in front of the radiator grille .
    Now on the E90 , E91 and E92 3-series 320d Efficiênt Dynamics they have a simmilar system (maybe now electronicly controlled )
  3. markabele
    5,084
    1,782
    Nebraska
    A few questions: I bought some 1/2" insulation. Just squeeze it into one slot right?
    Also, what temps do I want to see on the engine coolant on Torque? What do I not want to see?
  4. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Yes, squeeze it in one slot.
    Scangauge tells me 191-195, usually 193. You can watch it drop like a rock on very cold days when ICE-off. Should be fine quite a way over 200, but if I saw over 195, I'd take a piece of blocking out. No need to work the fans and thereby waste wh's.
  5. markabele
    5,084
    1,782
    Nebraska
    Just blocked 50% of the bottom. Went much smoother than I thought it might. Looks decent too. Thanks for the help everyone!
  6. Tim Bender
    Tim Bender Member
    134
    44
    Pulled together a little bit of data from the past month (September 2012). Gen III no grill blocking. A lot of people have been talking about observed maximum temperatures and so-forth. I've been logging the data in the Torque App for Android, so here's what I've been seeing.
    Vehicle speed rounding in Excel using the equation "=ROUND([mph.xxx],-1)" - which rounds to the nearest 10MPH. Essentially, 20MPH = 20 +/- 5, or 15-25mph. 30MPH = 25-35mph, and so-on.
    ICEInverter by bendertj, on Flickr
    I'll probably start grill blocking this week, so I'll create a new chart later this winter with some of those results.
    Chazz8, markabele and ksstathead like this.
  7. rpg51
    rpg51 Member
    200
    Vermont
    Is the foam pipe insulation that fits in a single slot 1" outside diameter? I have a new Gen III so I am getting ready to buy some material and do some blocking. Previously I owned a Gen II that I blocked with black foam but I had to cut each section in half length wise to get it to fit well in the slots. Is there a foam available that will fit in a single slot without cutting in half like that?
  8. Tim Bender
    Tim Bender Member
    134
    44
    About to block mine for the first time today and still not sure which way to do so. Found a pic here of someone using 1 inch (???) insulating foam and apparently cutting it to wrap around the vents (click for pic CleanMPG Forums - View Single Post - New 3 generation Prius III).
    I think I'm going to try to squeeze them between the louvers like in this pic http://john1701a.com/prius/photos/Prius_GrilleBlocking_CloseUp.jpg (probably not a prius grill, but you get the idea). I think this is 1/2 inch
  9. ksstathead
    1,244
    245
    Kansas
    1/2" inside diameter is > 1" outside, compression holds in place.
  10. markabele
    5,084
    1,782
    Nebraska
    Yes 1/2" inside diameter works perfect. 1/2" will be the big advertised number that you are looking for on the packaging of the insulation when you go to the hardware store. Only other tools you will need is a utility knife and maybe a tape measure.
    TsKarma likes this.
  11. TsKarma
    TsKarma Junior Member
    82
    Hi Mendel Leisk,
    Do you have the image still? If so, then may I trouble you to post it again? TIA
  12. Mendel Leisk
    41,258
    Yeah, kind of frustrating. Here it is:
    TsKarma likes this.
  13. TsKarma
    82
    Thanks! I am going to try to replicate this.
    You mentioned that this insulation is about a foot, but is it the same diameter (1/2 inch inside diameter) as the ones you are using for the front grill blocking as well, or perhaps the diameter does not matter as you just sliced the insulation opened and used double-sided tape to keep it in place??
  14. Mendel Leisk
    41,258
    Not sure of your location, but in north america this stuff is sold as 3/4" pipe insulation. It has an inside diameter of roughly 3/4" (it's for insulating 3/4" dia pipe), and outside diameter of maybe 1 1/2"? It's pre-slitted the whole length, basically so you can just push this onto pipe. Very common availability, and this is the same stuff people are using for grill block at the front.
    The stuff in the pic requires no fasteners, just push it onto the lip, which is crimped sufficiently to hold it in place. The hood when it comes down presses against it lightly, too: you can see the hood indent in pic.
    TsKarma likes this.
  15. dPruis
    dPruis Member
    47
    26
    Cerritos, CA
    Im sorry I don't really understand about grill blocking. Could someone tell me why do we need grill blocking and in what weather do we need to apply grill blocking? I really appreciate your answer!
  16. TsKarma
    82
    Ahh, good to know. I have read earlier that folks were using 1/2" pipe insulation and was not sure if you were using the same. I am in southern California, but I hardly work with pipe insulation. However, now that you have mentioned the pre-slitting...it makes perfect sense. I was thinking of my kiddo's swimming noodles for some reason. LOL. Going to check out Home Depot/Lowes this wkend. Thanks!
  17. ksstathead
    1,244
    245
    Kansas
    Prius mileage stinks (relatively speaking) during warm up cycle. The blocking helps hold in heat, thus shortening warm up. Do it in very cold weather or in moderate temps with a tool like Scangauge II to monitor coolant temps.
  18. TsKarma
    82
    You should just read the first page and see if you are interested in gaining a small increase in your mpg. There are links to photos as well on the first page. Seems like for CA, we should be at blocking only on the lower grill. How much blocking depends on the weather.
    Good luck!
    ps-others have also attributed the slight increase in mpg due to an increase in aerodynamics...
  19. markabele
    5,084
    1,782
    Nebraska
    At super cold temps it is probably more that just a little increase in FE. I notice small increases even when the weather is in the 50's and 60's.
  20. markabele
    5,084
    1,782
    Nebraska
    Temps in F:
    86+ - 50% of lower
    64-86 - 75% of lower
    41-64 - 75% of lower and 50% of upper
    below 41 - 100% of lower and 50% of upper
    Above is Ken's recommendations from the very first post of this thread regarding grill blocking on Gen3 Prii.
    I have a few questions:
    Are those referring to average temps through the day or highs through the day or simply whatever the current temp is when you are driving?
    Is this for city driving only? Certainly highway speeds might have a little different recommendations, correct?
    Thanks!
