Cold air Intake? - Not a Joke or Noob question
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Daves09prius, Feb 11, 2012.
  1. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    - REALLY!? do you have more info on this?
    Daves09prius likes this.
  2. tf4624
    tf4624 Active Member
    527
    51
    the concept is based on the Cracking of Fuel.. yes you can do it, if anyone tells you "you can't" they either are lying or don't understand it.
  3. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    yes the Torque app can give you the intake temps.
    Heat wrap around the intake tube should help keep the heat at bay. I think the improved air flow compared to the stock air-box will be the biggest gain.
  4. tf4624
    527
    51
    you need to make a tube that runs off the stock box and have it go back toward the engine where the heat is being made then make like a hood for it to give it direction where to suck the hot/warm air
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    The idea I have is to create something like the below...
    Using Daves idea to create a template..
    Attaching directly to the throttle body keeping the MAF in the same 'location' by using the below adapter... having this welded onto the aluminum piping
    Figure its a prob less than $100 total to fab up..I'm will to gamble that if it works beneficially, others can do the same mod... I'm willing to risk it :)
  6. Daves09prius
    680
    161
    Gettysburg, PA
  7. tf4624
    527
    51
    [​IMG][​IMG][​IMG][​IMG]
    Your box/head mod should look like this
  8. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    So you've done this?? What kind of increase +/-MPG or +/-HP did you notice?
  9. tf4624
    527
    51
    if its hot enough you will see some saving by the tankful.. winter.. its good *but after car actually gets to heating running temps. and you did a full grill block also. Brings air about 20-80 degrees up from the ambient air around it. Cant say its the best mod unless i can get the actual exhaust heat *(400-2000 + degrees) to be recirculated, I wont get much. the new 2013 Prius + will have this and circulate the exhaust heat to the engine for more efficiency
    the mod is just a 1st, many revisions to come.. but i have better things then this.. where this is not technically necessary
  10. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    What about those in warmer climates....what do you think would be more beneficial? oh and Winter?? whats that? (SoCal) lol..
  11. tf4624
    527
    51
    work both.. if your car is warmed up quicker.. the computer then can run less fuel knowing that its gotten to operating temps quicker..
    Also consider indexing your spark plugs ..
  12. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    I always tried to do this...but didn't know that's what it was called.
    HubGarage.com - Indexing Spark Plugs, a Racer's Trick of the Trade
    So if hotter air is good for a (modest) ~5% mpg increase but has little/no effect on HP gain, wouldn't colder air be more beneficial to help with +MPG and +HP?
  13. tf4624
    527
    51
    You can side gap it then.. same results and much easier then drilling a hole[​IMG]
    [​IMG][​IMG][​IMG]
  14. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    What are the pictures showing?
  15. tf4624
    527
    51
  16. tf4624
    527
    51
    Done that years ago. LoL
  17. Daves09prius
    680
    161
    Gettysburg, PA
    No it's not silly, it's a good point. It's nice that we can all work together to develop something that might help improve the sluggish acceleration, and possibly improve the mpg! :)
  18. Daves09prius
    680
    161
    Gettysburg, PA
    Here's a pic of my quick and easy "warm-air intake"
    It's the rubber wide-sweep 90-Degree elbow from my original "cold air-intake" and a PVC 1.5" 60-Degree street-elbow.
    I'll report if there is any changes from the OEM intake with the resonator removed at the end of the week... Nope, didn't improve fuel economy. My mileage dropped from 47.3 to 40.4, I checked everything, the oil level was good, the tire pressure was good, I even raised the tire pressure to 44 psi in the front and 42 in the rear. My mileage slowly increased to 42.1. I thought it might have been the colder temps, so I blocked the grille - no change. Switched back to the OEM stock tubing without the resonator and mileage improved to 47.2 mpg.
    Justdidit likes this.
  19. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Looks hard to drown in fast floods.
  20. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    I thought this was a thread about cold air intakes. But go ahead and change the subject if it helps your argument.
    You've got bits and pieces of ideas, but nothing that fits together cohesively... stage one, two and three mods all in a big soup. Lots of missing pieces: exhaust header is good, but why no mention of high-flow cats or mufflers? And don't even think about fuel injectors until you've got everything else dialed in.
    The "spaghetti" approach to performance tuning only works to drain your wallet... this thread only illustrates your will to throw money at your car, and your willingness to fabricate results to justify your expenditures.
    One can port match intakes & exhausts with a Dremel if he has enough patience. Ignition kits are mostly plug and play, save the installation of the timing sensor. And some projects are as simple as removing a part and dropping it off at the shop for a day (header coating etc.).
    If you've never done it before, I can understand why you'd believe it's not DIY...
    Caps lock does not make your argument more persuasive.
    I'm not in the business of designing Prius mods, and if I were, I wouldn't throw away all the time and effort I put into R&D by giving my designs out for free.
    I've put almost 100 hours of work into mods for another car... I know what kind of effort it takes to make a real solution. Throwing drier hose under your hood might look futuristic, but once you actually research the dynamics of air flowing through a rough pipe, you'll find that you may actually be getting less flow through your intake as a result...
    I do have something to add, it's called a critical eye. Consider me the quality control.
