EV Mode Max Acceleration Amp Pull
Discussion in 'Gen 3 Prius Technical Discussion' started by Jonny Zero, Oct 13, 2012.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    What is the amp pull during the max acceleration in EV mode, when the HSI is maxing out the ECO area?
    The battery is listed as 36HP, but I suspect during this max acceleration it puts out more than 36HP, even just for a short period of time. Does anyone know for sure?
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The system limits battery current to protect the batteries. This means the maximum is a lot less than you'd imagine.
    GreenJuice likes this.
  3. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    36 HP is the instantaneous max power can be drawn from the battery.
    36 HP x 746W/HP = 26856W
    26856W / 201V = 133.6 A which is 133.6/ 6.5 = 20.6 or 20.6C of the rated C of the cells.
    Shig likes this.
  4. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    What does that mean? I am not a battery expert. Is it a heavy draw?
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Someone with Torque app can pull/monitor realtime with the custom PIDs.
  6. David Beale
    5,963
    1,989
    Edmonton Alberta
    Yes, a very heavy draw. It wouldn't allow it for more than a few seconds to protect the batteries. They are 6.5 A-Hr cells. If you purchased a 6.5 A-Hr NiMH cell you would find the max. current specified around 50 Amps. The Prius cells are a little special, with better heat dissipation, mostly due to their "prismatic" construction (rectangular vs cylindrical cells). They also have much better inter-cell connection devices, allowing less heating and more current. At any rate, heat is the enemy, and the Prius battery WILL heat up, especially at 100 Amps.
    You can test this by switching to "EV" mode and see it switch out to normal mode as soon as you get the current up (harder acceleration). It doesn't take much to cause it to switch. 36 HP isn't much when accelerating.
    As I keep telling people, the Prius is NOT an electric car, it's an electrically assisted gasoline powered car, even in the PIP garb.
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    The Prius 7.2V module is rated as 1300W/kg.
    NP2 battery module (in Japanese)
    So, the peak is 188 A.
    Anyway,
    JP PiP sales staff manual says the threshold battery power at the ICE kicking in is 38 kW on the PiP and 21 kW (EV switch on) on the liftback.
    So, the max amp is approx 104 A on the Gen3 Prius when EV switch is engaged.
    Ken@Japan
    Chazz8 likes this.
  8. macman408
    1,179
    368
    I've seen mine at somewhere around 100-110 A, when going up a steep hill with a full battery. It was a little ways into the PWR bar. Most of the time, I don't think it'll go that high.
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Is this in EV mode or normal with ICE running too?
  10. GreenJuice
    GreenJuice Active Member
    195
    127
    London, UK
    I get a reading of just over 30 amps using the ScanGauge BTA (battery amps) when accelerating up to the mid-point of the HSI, just before the ICE kicks in. Is that what you mean?
    I've not experimented with trying to find out the factors or dependencies that affect this reading.
  11. Muzzman1
    Muzzman1 Member
    82
    42
    So Cal
    In "EV" mode under max acceleration when the HSI bar is all the way to the right, I've seen momentary ~100A. In normal mode when accelerating to get on the fwy Iv'e seen 150A.
  12. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Wow, thats 36KW or 48HP. Quite a bit for a battery.
  13. macman408
    1,179
    368
    That was EV mode. Trying to burn off SoC from one long downhill while I was on a short uphill, before getting to another long downhill. :)
  14. ClintJ001
    ClintJ001 Junior Member
    Australia
    I watched it today with a parallel 8ah lithium pack. 126amps up a hill EV mode.
    I'll see if torque can record it.
  15. tracy ing
    tracy ing Active Member
    384
    173
    wash dc
    NOT FROM MY TESTING and daily use.
    I have a thermistor installed in each of the temperature wells of my 20 module prius insight conversion, I test in the mountains over several years
    Never have I seen ANY heat up from CLIMBING the mountain, only from DESCENDING
    The prius nimh is EXOTHERMIC on charge and ENDOTHERMIC on discharge.
    An exothermic process releases heat, causing the temperature of the immediate surroundings to rise. An endothermic process absorbs heat and cools the surroundings.”
    Best was to cool nimh is to LOAD it up and DRAIN it.
  16. AJ88
    AJ88 Junior Member
    Sacramento, CA
    2013 Prius Plug-in
    What does HSI mean?
  17. ChapmanF
    18,526
